Log Splitter hydraulic fluid
/ Log Splitter hydraulic fluid #1
KeithT
West Virginia
Kioti CK3510HST SE
I have a gas powered toro log splitter. Manufacturer call for 10-AW fluid or Dexron III. Can I use the tractor hydraulic fluid they carry at Walmart instead?
/ Log Splitter hydraulic fluid #2
I think they have their hydraulic viscosity rating mixed up with SAE engine oil spec's. If they call for a fluid with a viscosity similar to Dexron III then that would be a AW 32 or "SAE 10" viscosity oil. Most UTF fluids are around a SAE 10W/20 equivelant. You could use the UTF fluid since it's cold performance will be similar.
/ Log Splitter hydraulic fluid #3
Maybe you can get the fluid replaced for free... There's been a recall on Toro log splitters.
The Toro Company Information: Product Recall Information (4/4/2006)
That being said, here's a quote from my manual (Troybilt splitter).
Fill the reservoir tank with hydraulic fluid included with
this unit (if equipped) or approved fluids which include
Dexron® III / Mercon® III automatic transmission fluid,
a 10 Weight AW hydraulic oil or Pro-Mix AW-32
Hydraulic Oil.
/ Log Splitter hydraulic fluid #4
Looks like what I suspected, the 10 weight they refer to is SAE 10 weight.
/ Log Splitter hydraulic fluid #5
I did a 50 hour service on my Kubota L3830 and saved the old super UDT that I drained out, it looked like new. I changed the hyd oil in my logsplitter with it and it works much better than the wally world generic hydraulic oil. I have about 17 gallons of used super UDT so I can change the hyd oil in the splitter several times with it.
/ Log Splitter hydraulic fluid #6
Sorry to bump old thread.
I was thinking of doing this with my new splitter and using Super UDT.
Did this (used) fluid continue working 'fine' for you?
2018 MACK CXU (PINNACLE) (A67714)
2018 MACK CXU...
2011 CHANDLER TRI AXLE SPD-18 WATER HEATING TRAILER (A67714)
2011 CHANDLER TRI...
Generator Inverter (A64553)
Generator Inverter...
2019 INTERNATIONAL MV607 REEFER TRUCK (A67714)
2019 INTERNATIONAL...
2006 Isuzu NPR 16FT Box Truck (A66736)
2006 Isuzu NPR...
2017 Ford Explorer AWD SUV (A66738)
2017 Ford Explorer...
