Opinions on trucks
Status
Not open for further replies.
/ Opinions on trucks #1
canoetrpr
Ontario, Canada
Kubota M7040 cab/hyd shuttle - current, Kubota L3400 - traded
Not directly tractor related but I trust you guys and value your opinion.
I've pondered getting a truck off and on. I don't specifically have a need for a truck on a day to day basis but the odd thing does come up when you have a hobby farm and it would be nice to have one when you need it.
Most of the time it will be driven unloaded by me about 50 km each way to work so about 60 miles or so per day. The drive is highway - more like country road 50mph.
Fuel economy is important. I don't need more than a 1/2 ton but have pondered a 3/4 ton as they are available in diesel. After my tractor I've decided that I really like diesel vehicles!
I'm considering new and used so give me your thoughts on both and any particular model years that are good or to avoid.
Reliability is a must. I've had excellent reliability from my Hondas and not owned a car from the big 3 for a while but I am open minded and willing to consider that they are more reliable these days. Plus there are not that many import trucks anyway.
Would appreciate your thoughts.
/ Opinions on trucks #2
for your rare use of a truck, I'd suggest buying an old beater that's fairly dependable and keep the car for your commute. no way you'll find something with good enough fuel mileage to make you happy for a commuter.
/ Opinions on trucks #3
I agree, if you want fuel economy then you need a car. I have a 2005 1/2 ton Silverado 4wd, and average 15.5 mpg in the winter and 17.5 in the summer. I drive a mix of highway and back roads, and have a heavy foot. In 2010, GM is suppose to come out with a 1/2 ton Diesel that will get about a 30% improvement in mpg.
If you know how to wrench on a vehicle, my vote would be for an older beater truck and keep the car for work. Otherwise if you get a truck and want to use it for daily errands, get a crew cab. I have an extended cab and wish I bought a crew cab.
/ Opinions on trucks #4
might wanna consider a Ford Ranger(unless youll be towing your tractor).
Don't get me wrong here folks. I know a truck is not going to compare to a car in MPG. I currently drive our Honda Odyssey van to work. I get about 11L/100 km ~= 21 MPG.
If 18 MPG is possible in a truck then its not worthwhile to me to have an extra vehicle lying around that I have to insure and maintain.
I was really looking forward to the 1/2 ton diesels that were rumored. Haven't heard much about them. Not sure I'd jump into the first model year but I might with an extended warranty I guess.
/ Opinions on trucks #6
All 1/2 ton diesel projects are on hold or canceled by GM, Ford, Dodge, Toyota, etc. The new diesels with the DPF have lost all mpg advantange and the high cost of maintenance, repairs, fuel and higher purchase price make them a bad deal for the casual user. Only make sense for the regular tower.
I would say to get a 1/2 ton with a small V8. If you want used, a GM in 2000 to now. In ford the same. The Dodges with the hemi's that don't have the selective cylinder technology suck fuel down like a sailor on leave. All are able to tow in the 6000 to 9000 pound range depending on options, etc. The 2009's all have MUCH better mpg's than the older ones. The new ones are 20 on the freeway regularly where the older ones were 16-17.
The smaller than 1/2 ton trucks are all pretty good with the Toyota leading the pack, but none of them really get great mpg's.
/ Opinions on trucks #7
Bought 08 Tundra 1/2 ton but i use more like 3/4.Excellent power 15 mpg.
average.Drove Chevy's for most of 35 yrs.If you look at domestics try Fords
/ Opinions on trucks #8
My '08 F-150 gets 15-16mpg consistantly, 10-11mpg towing. I think that's pretty good. The '09's may get slightly more, depending on spec. I'm very pleased on the initial quality, though at only 7500 miles, I still consider it new. I don't expect any suprises over the long term.
I'll admit a long held bias to Ford, so I didn't try out all the brands, only Toyota.
/ Opinions on trucks #10
I have to agree with the others and say get 2 vehicles. You need a 5 year old 1/2 ton with a V8 and tow package. Very important to get the tow package because this usually includes a larger radiator, tranny cooler, heavier suspension in the rear, better gear ratio for towing, and hitch/wiring for pulling a trailer. For example my 2007 F-150 with these items has a 9,200# tow rating and I routinely pull 7,000# and upt0 9,000# with it. It does great with the 7K load and gets 11mpg but really falls off with the 9K load.
I picked up a 1999 Saturn SC 2 a year ago for $2850 and had to put a new exhaust and tires on it. It gets 38 on the highway and 32 in town. We already had 3 trucks, a 2004 F-250 4x4 diesel, a 2006 F-350 4x4 diesel, and a 2007 V8 4x4 F-150 so we were in the opposite situation as you needing a car. This little Saturn sips the fuel while the two diesels average 17 and can squeak out 23 on the highway while the F-150 gets 14.6 in town and 17 on the highway.
Chris
/ Opinions on trucks #12
I second the Ford Ranger suggestion. I have owned three. Get one with the 6 cyl. engine. They work a lot less than does a 4 cyl. and end up getting about the same milage. If fuel economy is important to you stay away from the diesels. I have a new 2008 F250 with the 6.4 PSD. It's a great truck and does not get bad milage on the highway compared with a half ton V8. When you start driving around town forget about fuel milage. It's so bad you will not even want to check it. With a combination of back road and a little in town I will get right around 14 - 15.
Are you thinking new or used?
Great comments so far. Keep them coming. I'm open to both new and used.
I'm not quite convinced on a having an extra vehicle - we already have two - one for my wife one for me.
She's currently driving a 99 Honda Accord. It does not get much use as she's a stay at home mom - so taking the kids here and there, groceries etc. It's got about 300000 km on it and is the one that will eventually need to be replaced by something.
I'm driving a 2005 Honda Odyssey van which is what she really should be driving. I drive it because the Accord is 5 speed and the clutch is like a ton of bricks. I have a bad back and the clutch bothers my back quite a bit. I love manual but its auto only for me unfortunately now.
I guess I could buy a 4 or so year old 1/2 ton gas pickup for her use and keep driving the Odyssey myself but really the mom needs the van more than I do!
Not sure on having a third vehicle hanging around with the cost of insurance and repairs. I've found that my vehicles tend to do best when I am actually driving them.
Sounds like a new 1/2 ton truck might not be a bad bet for my regular driver. 17 mpg is not far from what I am getting in the van right now. I get about 21 mpg on my commute on country roads - 50mph - maybe 23 if I go pure highway.
A real sipper FWD vehicle is out for me. If its not the truck then it will be a Subaru or something that is AWD. I've decided that there is no point not having the option of AWD with our weather in the winter. Does not sound like a 1/2 ton is that far from what I would get in a Subaru. I think that the Subarus are probably equivalent to my van in mielage.
I've pondered the Ford Ranger and Nissan Frontier but I figure that if I am going to get a truck, I might as well get a 1/2 ton. It didn't seem to me like they used enough less fuel to make them worth while. Not sure though - I will keep an open mind.
/ Opinions on trucks #15
In my diesel's I can do about 16 - 18 in 60 hwy/40 city and 20 all hwy driving in the 92', & 15 - 16 in 60 city/40 hwy and 17 - 18 all hwy driving in the 06. That said if it were me, I would stick with a 3/4 or above diesel until the 1/2 tons make it out. All the diesel's I have ever driven have outlasted and out-mpg'd any 1/2 ton gasser I've ever driven and I will never buy anything else other than the diesel option. But, for the uses that you state and the need of not really needing a pickup, a 1/2 ton gasser would probably work just fine for you.
/ Opinions on trucks #16
You can get a V8 4.7l (310hp) in the Ram 1500 that has been flex fuel ready (E85) since 2005 and it gets 18mpg highway. It still has over 1300lbs of payload and tow capacity of 6,000-7,100 depending on rear axle ratio.
On a side note, my 2003 Ram 1500 Quad Cab HEMI (75,000 miles) has been getting 15mpg average (50/50 city/highway) with a highway average of 16.7-17.0 mpg and towing average of 12.5-14.0 with snowmobiles and trailer (2100lbs +/-) and 9.5-11.0 with my tractor and trailer (7600lbs).
I had a Dakota before which is a great truck for someone who needs a bigger truck than a Ranger/S10 but does not need a full-size truck. It had a great V6 engine, 900lb payload and 4800lbs towing capacity (6100 with a V8). I believe the new Chevy Colorado is also a "mid-sized" truck also.
/ Opinions on trucks #17
I used to have a '99 F150 supercab with the 4.3L six cylinder. I only kept it about a year and a half and only put a little over 12k miles on it during that time (it had nearly 50k on it when I bought it). But since I keep spreadsheets and complete records on my vehicles, I know that it averaged 18.114 mpg with a mix of city and highway driving, and I do believe in using the air-conditioner.
I now have an '01 Ranger supercab with the 4.0L six cylinder (for those who don't already know it, the Ranger comes with a 4 cylinder engine, a 3.0L six and the 4.0L six). I bought it with 36k on it and it just now rolled over 60k. All power and air and automatic, 2WD, and by far mostly city driving now, and it has averaged 18.554 mpg (slightly better than the F150). I do have the load distributing hitch platform and I made a few 65 mile round trips with a 17' aluminum bass boat with a 50hp engine and I made a few 30 mile round trips with a 4' x 8' trailer with a little ZTR mower on it. I think it's only rated to pull 5,500 pounds.
So . . ., as I see it,
1) the F150 will pull a heavier trailer, if you need that,
2) the Ranger will get a little better gas mileage,
3) the Ranger is just the right height for me to sit down or stand up from the driver's seat, while I had to step up a bit to get into the F150,
4) the Ranger, being smaller, takes less space in the garage and is perhaps a little handier parking in parking lots, and
5) the F150 rides a little smoother. The Ranger has a good suspension for hauling a pretty good load, but that makes it a little rough riding. I have hauled all the limbs I could pile on, even standing on a ladder, to the landfill after pruning trees and that was only enough load to make the ride smoother. But when I hauled over 1,300 pounds of concrete stepping stones, that was actually a little too much. I didn't have any problems with it, but it lowered the back end considerably, and I only had to go about 10 miles at 35 mph in town.
/ Opinions on trucks #18
I have tried all the methods mentioned thus far...
I always liked having a spare vehicle in the event one goes down or is in the shop. Granted it is a luxury, but since it is a truck it has its uses. I always buy a used truck cause I use it like a truck. I drive it till it dies, fix it and let it die again. Don't wash it, don't vacuum it, drive it in the woods with branches scratching it. Since I have to dress up a bit for work and occasionally cart co-workers around, I use the car. But when not commuting, it's all truck time. Stay at home mom has the SUV. With three of the kids in sports and me coaching, I could haul all the gear and the dirty kids without trashing the other vehicles - plus I could leave the gear in it
Since it is an extra vehicle, it is a full size, quad cab (have 4 kids), 8' bed. My current one is a 3/4 ton diesel, and avg 17 - 20 mpg. But even if it was pretty enough to take to work, rolling around downtown in it would be cumbersome. I still have my old '95 F350 (gas) - this is what the teenagers drive :D. Just can't bring myself to get rid of it - and two trucks comes in handy more than I ever expected.
So it really depends on how you intend to use it - and you will probably find, like with your tractor, that you will use it more and for more things than you originally thought.
If you decide to go with just the two vehicles definitely go quad cab, otherwise you will miss your car's trunk and back seat. Diesel will give you the ability to get a "real" truck with good gas mileage - but take into account that not all stations carry diesel (possible issue on commute route) and those that do are pretty messy around the pump - so if you're a shirt/tie guy going to work, might get messy
Hey DMACE, what's my truck doing hooked to your tractor?
/ Opinions on trucks #19
Ha Ha, sometimes I wish I had a diesel and 8ft bed. Guess what, I have an old red Ford F350 too! Nice choice of trucks! :D
1994 F-350 IDI Diesel (non-turbo, non-powerstroke), 59,000 2 owner miles and 4 speed with OD tranny. I love that diesel, it pushes my 9ft plow around like a toy.
Nubota - what year is your Dodge 2500? Have you been happy with it vis. a vis. reliability? I have heard good things about the Cummins engine but then not so good things about chrysler transmissions.
Then again a buddy of mine has a 1500 which has been great for 250k km now.
I think that so far the responses are telling me that if I really want to get a diesel, it might as well be one that is a few years old.
Status
