Ignorant 3-point hitch question
/ Ignorant 3-point hitch question #1
bruski
rural Missouri
Kubota b2400HSD
I seems to me that my lower two points used to "lock" and would not rise or be able to be lifted by hand. Now they can? Was I dreaming that they couldn't be lifted by hand or has something happened? Tractor is a Kubota b2400.
Bruski
/ Ignorant 3-point hitch question #2
Dreaming --- the lower lift arms are free floating. Raised and lowered by the vertical lift links attached to your upper lift arms. The uppers can't be raised or lowered by hand.
/ Ignorant 3-point hitch question #3
Wake up:D Very few 3PH's have the ability to apply downpressure or "lock" the arms.
Bruce:
This I would agree with...
That I will dis-agree with...it can raised or your implement would not "float"
Bruce:
Thanks. I was worried because I can raise the upper links by hand by lifting on the drawbar attached between the lower links. I thought I was done hallucinating in the '60s. Guess not . . . .:rolleyes:
Bruski
/ Ignorant 3-point hitch question #5
There is a rod connected to the rockshaft that is rounded that slips into the piston that is conical on the inside. This rod is free from the piston allowing the arms to lift independent of the piston.
/ Ignorant 3-point hitch question #6
I agree with Kenny.. on most tractors there is no downpressure.. thus you can freely lift the upper and lower lift arms ( they are linked! )..
soundguy
/ Ignorant 3-point hitch question #7
My Kubota has a valve which basicly regulates the rate of flow to the 3pt. I can shut it off entirely. I never checked it out, but is it possible one could "lock" the 3pt because if the valve is closed the cylinder is locked on one side? I do know it will not go down if the valve is shut. Never tried it pulling up.
/ Ignorant 3-point hitch question #8
There is NO hard coupling from the 3pt lift arms to the HYD piston. ther is usually a dogbone that is loosly coupled to a cam on the 3pt rock shaft, and the other end of that dogbon rides in the cup shaped head of the piston.
As you've been told.. you should be able to lift the arms UP.
the 'lock' for the 3pt merely prevents oil from exhausting from the lift cyl.. IE.. if the lift piston seals leak.. the lock is not going to even hold the arms up long.. etc.
soundguy
/ Ignorant 3-point hitch question #9
Bruski,
You may be remembering correctly that you could not lift the arms buy hand.
Due to paint or rust on the pivot points of the lift arms. I have one that will freeze up to hand lift it allowed to sit for a while. So I learned to keep them oiled. If you used a spreader it could be residue or chemical reaction going on.
/ Ignorant 3-point hitch question #10
Right on. Lifting the arm will retract the ramrod away from the piston hence allowing it to move up. The opposite is not true if the the hyd fluid is allowed to return to the reservoir thru the spool valve.
JC,
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63689)
2017 Cadillac...
2022 EZ-GO ELITE...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61574)
2021 Mercedes-Benz...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
JOST FIFTH WHEEL PLATE (A64276)
JOST FIFTH WHEEL...
LOT LOCATIONS (A59914)
