Help with size
/ Help with size #1
John D
Johnson co. TX.
JD 5103
I had three of these fall in the back of my truck from work. They used to be hooked up to a field tarp lift and we did away with the lift so I snagged them thinking I will use one of them for a splitter. Can anyone tell me what size they are. Thanks
/ Help with size #2
I do not understand your question:confused:
/ Help with size #3
Did you write those sizes on the cylinders?
Are they indeed 2" ram with 4-1/2 OD and 24" long?
If so, then (I'm guessing) the wall thickness leaves a 4" cylinder with about 18 to 20" stroke.
Assuming 2,000psi for the hydraulic system pressure, that would give you a 12-1/2 ton cylinder.
If your hydraulic system pressure (psi) is more, you'd have more tons and visa versa if less, less tons.
Formula is [(pi)(r squared) x psi]/2000=tons of pressure.
Speed of the cylinders depends on the gpm (flow) of your hydraulic system.
I think that's right...
Rob-
/ Help with size #4
The correct answer is written on the cylinder, except for the pin size. Maybe 1 1/2 in
/ Help with size #5
If it's the tonnage your seeking, then these calculators will determine it for you if yo have accurate measurements.
/ Help with size
Thanks guys. I guess I should have ask what the lbs or tons were. I got these things free and figure some time down the road I could use them for something. Im just now trying to learn about hydraulics so bear with me. I did put the numbers on them and they have no stamp or markings. They did loose some fluid so does that hurt??
/ Help with size #7
If you mean they lost fluid out of the port holes while they are off ... no. No problem.
Just seal off the ports with a plug to keep debris and other crap from getting in there.
/ Help with size
Yes. And thanks. I did cap them off last night.
Cultivator (A62613)
Cultivator (A62613)
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2006 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A64194)
2006 Chevrolet...
New/Unused Heavy Duty Plate Compactor (A65583)
New/Unused Heavy...
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
2021 CATERPILLAR 289D3 SKID STEER (A65053)
2021 CATERPILLAR...
