TRUCK AND TRAILER TEAM.
/ TRUCK AND TRAILER TEAM. #112
/ TRUCK AND TRAILER TEAM. #114
/ TRUCK AND TRAILER TEAM. #116
LB,
Are you close to buying a truck and trailer yet.___only 113 replies.
Hain't even close to finding either the trailer or the truck let a lone buying anything.
Yes, have you come to a conclusion on EXACTLY what you want?
Kyle
Yeah but locating either one may be the big challenge.
They don't seem to be growing on trees.:D
/ TRUCK AND TRAILER TEAM. #118
:D:D:D
LB,
If you want to buy used have you checked out.
"Equipment trader.com"_____"truck trader.com"
/ TRUCK AND TRAILER TEAM. #119
Mr Brown that setup should really work for you, I tow a 7000lb 16 ft trailer with brakes at all wheels with a Dodge Dakota v8 with trailer package and haul my ck20 loader and backhoe all the time with absolutely no problems, drew the Kioti home to Ontario from Tenn. this past summer . Have drawn cars at various times on the trailer and a large playhouse just had to load it on some 6x6's to clear the fender's then tie it done well. Now that I have the ck I could USE but don't need a little longer trailer and my next one will be a tilt but a 16 footer will suffice for your bx with hoe attached no problem as I had lots of room on the 16 ft for my B6200 with hoe and loader. If you want a small dump on the truck your are likely better to go for at least a 3/4 ton, but be aware as you raise your overall weight depending on the rig you end up with, you may get closer to regulations concerning licencing, annual inspections ,and daily inspections. Gary
Looked at a 16' car hauler yesterday for a $1000.
Guy used it to haul his stock cars.
He said a racing buddy had an older Ford F250 4wd pick up for $1350.
1974 Ford F600 Grain Truck (A61307)
1974 Ford F600...
205196 (A52706)
205196 (A52706)
10 X6 MANIFOLD (A58214)
10 X6 MANIFOLD...
2019 John Deere 460E Articulated Dump Truck (A60352)
2019 John Deere...
ATTENTION! PLEASE READ (A60462)
ATTENTION! PLEASE...
2023 FORD F750 CAB & CHASSIS (A57880)
2023 FORD F750 CAB...
