755 How hard to change tach cable?
   / 755 How hard to change tach cable? #1
Dave1801
Scottsville, NY
How hard is it to change the tach cable on a 755?
Dave
   / 755 How hard to change tach cable? #2
Can you get to each end of the cable easily? That should determine how much trouble it will be.
Steve
   / 755 How hard to change tach cable? #4
I just changed the tach cable on my 855 and found that removing the outside locking bolt and rotating the alternator provided better access to the engine end of the cable.
Nikko,
Thanks for the intelligent reply.
How did you get to the tach end of the cable?
regards,
Dave
   / 755 How hard to change tach cable? #6
With a little difficulty. I was able, with hood up and a side pedestal panel off, to use small needle nose vise grips to break it loose. I don't think it has to be too tight on reassembly. Anyway, mine is doing fine
   / 755 How hard to change tach cable? #7
Dave, good luck with changing your tach cable. Being sarcastic isn't going to win friends here. You need to drop the attitude pronto.
Steve Jenkins
Steve Jenkins
Who was sarcastic, The one making intelligent comments.
grow up.
pronto this...
Hi Nikko,
Thanks for your help. That's what I wanted to know.
regards,
Dave
2007 Ford F-350 Stakebody Flatbed Truck (A51692)
2007 Ford F-350...
2017 CASE IH 580 QUADTRAC ARTICULATING TRACTOR (A52705)
2017 CASE IH 580...
2012 Chevrolet Impala Sedan (A54815)
2012 Chevrolet...
2018 CATERPILLAR 745 OFF ROAD DUMP TRUCK (A52705)
2018 CATERPILLAR...
2016 Toro Groundsmaster 7200 Zero Turn Mower (A55851)
2016 Toro...
Toro Workman MDX Utility Cart (A51694)
Toro Workman MDX...
