L304 vs L364
/ L304 vs L364 #1
lawn_master
Just bought a b2620. Originally I purchased a bx2660, had buyers remorse and upgraded slightly to a 2620. I am getting a brand new (Leftover 08), no hours, Tractor, 60" mower and L304 front loader for 14,500. If I want the L364 it is going to run me about 500.00
Is it worth it??????
/ L304 vs L364 #2
An extra 130 lbs lift capacity.....you will be paying about $4 per extra pound of lift capacity. No help there.
In terms of bags on concrete.....you would be able to carry 2 extra 80 lb bags of concrete (8 vs. 10) in the higher capacity FEL.
The lift capacity affects break out force...do you plan to add a digging bar and dig into hard soil?
Do you have lots of large rocks to move that exceed the capacity of the lesser FEL?
I would not think that the smaller loader would impact the usefulness of the machine (caveat - unless the lesser FEL comes with smaller bucket).....and if it would I would think that you should have moved up to the bigge B or L model.
Use the $500 to by another nice attachment.
/ L304 vs L364 #3
Does the 304 (for the 2320) even work with the 2620? Perhaps it does, but it has a 48" bucket which isn't going to cover the 2620 width. The 364 bucket is 50".
/ L304 vs L364 #4
I would pay the $500 and get the 364 and still consider it a good deal. Plus I would feel better about having the correct loader that matches the tractor.
/ L304 vs L364 #5
When I purchased my 2620 the dealer advised he wont even sell a 2620 w/ the 304 loader. Its not the perfect fit like the 364 is. I would pay the extra money myself. Tractor, loader (364) and MMM for 15k is a good deal.
/ L304 vs L364
Thanks to all. I got him down to 300.00
B2620
L364
60" mmm
14,800 OTD
/ L304 vs L364 #8
B2620
L364
60" mmm
14,800 OTD
Even better, Not sure if this will be your primary mower or not? What kind of tires did you get? I dont mow w/ mine so I got my rears loaded w/ rim guard its a big help w/ stability when using your fel. If you dont load them make sure you use some kind of ballast on the 3pt when working w/ heavy FEL loads, I actually use both methods when moving heavy materiel. Good luck
/ L304 vs L364
Tires will be filled
R4's
I will be mowing (Hill)
Caterpillar Tech Manuals (A63117)
Caterpillar Tech...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2006 Mack Granite CV713 Dumping Flatbed (A62679)
2006 Mack Granite...
2025 GIYI GY-P45 Hydraulic Breaker Mini Skid Steer Attachment (A61572)
2025 GIYI GY-P45...
2018 Bell B30E 30 Ton Articulated Dump Truck (A64194)
2018 Bell B30E 30...
UNUSED IRANCH IRGC40 HIGH END MINI GOLF CART (A64281)
UNUSED IRANCH...
