BX24 Landscape Rake
/ BX24 Landscape Rake #1
MDCINVA
Kubota BX24
Own a BX24, 2 years now, has FL, BH, MM mower, great machine, looking to buy a landscape rake, need something to disturb the soil prior to planting a new lawn, know zero about 3 point hitch attachments, looking for some help on size, make, model and performance. Also looking for a rear plug aerator to attach to the BX, have not been able to find anything on one of those, or if its even something thats available.
/ BX24 Landscape Rake #2
Welcome to TBN. I currently have a 4' LandPride LR05 series rake. Don't get that one for the BX24! My BX bends teeth on the rake regularly and I did add hydraulic angle and modified the rake for cat 1 to match my other implements. IMHO the 05 series rake is way too light duty and small for serious raking projects. :(
The LR05 series have 1/4" x 3/4" x 12" high teeth and the LR15 series have 5/16" x 1" x 16" teeth (much heavier)
My next rake might be a LandPride LR15 72" with gauge wheels. If the rake is too big for the BX, I'll just remove a few teeth. :)
Carl
/ BX24 Landscape Rake #3
I bought a 6' Landpride for my BX2200 and it pulled it fine. Also used it on my BX1500 and did fine. Also used it on my B7800 and now use it on my BX2350 and L3240. There was/is one problem with it on BX's. When on a down hill slope the 3pth won't lift it high enough to get it off the ground. If you have level ground you won't have this problem.
Thanks for the info, I looked some up on the web today, looks like if its a category 1 it will work w/my BX, however there are several sizes, 5', 6' and 7', any idea how big I could go without something too big for the tractor?
Also, is the local Tractor Supply store the best option for buying new? Any on-line options for buying new or used to save some $$$'s?
/ BX24 Landscape Rake #6
I have the KingKutter XB rake. It fits fantastic on the BX, which it better, because it is made for it. I found the rake to be MUCH more useful after I put their gage wheel kit on.
/ BX24 Landscape Rake #7
I would recommend the Woods estate series. It is a 5' rake sized to fit the BX. I bought the wheels and would recomend them as well.
Will
/ BX24 Landscape Rake #8
I have the woods 6' rake with the wheal kit and my BX 2350 does real well with it. It is made for a bigger tractor but I just turned the pins in and pay attention to the sides when I get close to things.:D I have had it fore over two years and have used it to pull out manure from behind the horse barn, level top soil and level gravel drives. I have never bent or broken a tooth in that time!:cool:
/ BX24 Landscape Rake #9
Welcome to TBN. Land pride and woods are both well built rakes.Little to pricey$700 to $1,000. Going to built one soon. Good luck. Framer
/ BX24 Landscape Rake #10
I have a BX24 and have a 7' rake with guage wheels. The 24 pulls it well.
/ BX24 Landscape Rake #12
I bought a turfvent aerator 48" for about $600 from gemplers. It is a 3pt and that is definitely the way to go!
/ BX24 Landscape Rake #13
I have a 5' Farm Force with gage wheels from TSC. I bought it last spring I think I gave $425 for it. It is fairly heavy built, after I had it for a weak I noticed that one of the casters was bent (welded wrong). So I called Farm Force and in three days I had a new one. Other then that no other problems. I went with a five-footer because I can get it through all my gates and between most trees easy. The landscape rake has become one of my most valuable tools I am always finding new uses for it.
/ BX24 Landscape Rake #14
I have a 5' Farm Force as well. I don't suppose you could post a picture of the gage wheels, could you? I'm curious to see how they attach to help decide if they would be useful for me. Thx.
/ BX24 Landscape Rake #15
I have the same rake with wheels. Here's a pic of it. Oops, wheels are cut off in the 2nd pic, but yo can see how they mount in the first one.
Edit: I should add the wheels are height adjustable. Looks like they're in the middle position in the first pic. To adjust the height, you have to remove the top pin, slide the wheel off, then move the spacers above or below the horizontal shaft holding the wheel to the rake, reinsert the wheel from bottom up and reattach the pin.
/ BX24 Landscape Rake #16
I had a BX23 and used a woods 5' rake with wheels. The rake worked well in disturbed soil but won't make an impression on existing turf because it is just too light. Where are you located?
/ BX24 Landscape Rake #18
Singlecoil, Here are some pics. of my gage wheels on the Farm Force rake.
/ BX24 Landscape Rake #19
Thanks CHDinCT and ActionAJ for the pics.
Mine looks just like CHD's. It looks like the wheels would be a snap to install. I'll be adding those to the wish list.
