Have You Ever Weighed Your Truck?
   / Have You Ever Weighed Your Truck? #41
my 85 C30 is 6200 empty
i had 11,000 with a load of sand in it per elevator scale
   / Have You Ever Weighed Your Truck? #42
What's the best I could haul in a Single rear wheel 1 ton ?
with and with out a dump bed.
Thanks LB.
I'd like to stay away from dual wheels.
To keep things simple it's reasonable to say a 1-ton SRW regular cab truck can haul around 4,000 pounds. The MGVW's on these trucks are right around 10K, maybe a hair over/under depending on make/model. 4wd capacity will be a little less than 2wd, etc, but the difference is almost insignificant. If you add a heavy dumper body vs. regular pickup box you will have to allow for that. With a dually figure you can load an additional 1000-1500 lbs.
   / Have You Ever Weighed Your Truck? #43
1*If you add a heavy dumper body vs. regular pickup box you will have to allow for that.
2*With a dually figure you can load an additional 1000-1500 lbs.
Thanks for the info.
1*I'm thinking a light weight flat dump bed with removable sides and front boards as well as a removable tailgate hinged both at the top and bottom.
These would only need to be 10 to 12 inches high.
2*Around 4000 pounds is just about right for me so a dually isn't necessary.
   / Have You Ever Weighed Your Truck? #44
FWIW, I've hauled two pallets of pellets (one ton each) in a 2007 dually (4 door C-3500 4WD diesel). It handled it fine BUT I could feel that the front end was a little light. It's not something that I would want to drive regularly over long distances. YMMV.
Ken
   / Have You Ever Weighed Your Truck? #45
Ken
Sounds good to me as I would not be hauling that much that often that far, but it would be available if/when needed.
   / Have You Ever Weighed Your Truck? #46
Ken
With the 4-door cab it is more difficult to keep weight on the front end when loaded heavy. Even if you place the 1st pallet all the way forward in the bed it's still a lot farther back from the front wheels than it would be with a regular cab.
   / Have You Ever Weighed Your Truck? #47
You are correct but I don't think it makes much difference. I'm pretty sure that the bed on any 8' bed is balanced over the rear wheels. IOW, the weight is all over the rear axle, no matter what's in front of the bed. With a 4 door, you actually get the engine and cab weight levered more forward (percentage wise) than you would a 2 door.
Ken
   / Have You Ever Weighed Your Truck? #48
This is one reason why I want a long bed standard cab.
   / Have You Ever Weighed Your Truck? #49
Ken
Is it possible a dump bed on a 4 door would lift the front wheels when the bed was raised to dump a couple of tons of gravel?
   / Have You Ever Weighed Your Truck? #50
I would think that the longer wheel base and having the heavy engine weight further from the back end would make that less likely to happen. The "moment arm" is weight vs. distance and the distance is longer on a 4 door.
Ken
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A55301)
Koyker Loader...
2018 Ford Fusion Hybird (A53424)
2018 Ford Fusion...
20 UTILITY TRAILER (A55745)
20 UTILITY TRAILER...
2017 Kenworth T400 T/A Aquatech B-15 Combination Sewer Jetter Vacuum Truck (A55852)
2017 Kenworth T400...
2004 Volvo XC90 VAN (A55853)
2004 Volvo XC90...
