Logging Hitch
/ Logging Hitch #1
teach
Rhode Island, USA
After viewing several threads about logging, I came up with this idea. My buddy who is getting pretty good at welding, heped me create this logging hitch. I have a B7500 w/FEL and as a property manager for a 200 acre parcel, I get to use it to carry out the forestry plan. This logging hitch works great! We used it this weekend for the first time. I just back up to the logs, hitch up the chain, lift up the 3 pt hitch, and off I go! We also set it up so I can put a 3000# electric winch on the back of the reciever hitch, between the tractor and the logging hitch frame (haven't tried it yet though). We started with a set of 3 pt forks, then cut off the forks, then started welding! The hitch is multi-functional, it serves to skid trees, it has a trailer hitch, and we cut some new angle forks to put in the 2" receiver slots in both bottom corners so I still have forklift capability.
/ Logging Hitch #2
We need a picture. Sounds great.
Chris
/ Logging Hitch
Pics, tried posting them the first time, it didn't work. Let's try again. There are four hooks across the top of the hitch, which is two pieces of 2" angle welded together to make a piece of 2" tubing. The big middle hook that is upside down is to hold the pully block for the winch, which will mount down low, in the back of the receiver hitch. Depending on the size of the trees, I probably can't drag more than two or three trees, but I can drag some decent size trees out, the drag is about 1/4 mile. Some of the oaks are just too big to lift and drag, and my buddy drags them out with his 68 horse Bota with an actual logging winch. My setup however, costed me less than $200, his cost a couple thousand (I do realize we are not comparing apples to apples). Now we are looking for another Bota project to weld up! Any ideas?
teach
/ Logging Hitch #4
Congrats on a nice looking job for a modest cost.
For newbies here that don't know it, always insert the chain UNDER the log or object first and then wrap the end back over the log (or bumper or whatever) and THEN hook the clevis to the chain. A snapped or slipped chain under tension will then recoil into the ground and not up and directly back into the tractor operator's face.
Before someone clued me in I took my truck back window out years ago. Kept finding glass until the day I sold it. Just my two cents.
/ Logging Hitch #6
Very nice setup.
Thanks for sharing.
/ Logging Hitch #7
All of the commercial ones have an expanded metal shield which catches the hook and wire rope from the electric winch after it slips off a log and comes flying at your head.
You could consider making one of those for your next project...
/ Logging Hitch
CurlyDave,
Good idea, but I won't need it. My winch won't be operated from the seat, it has a wireless remote, which I will use from a save distance off to one side. Also, my winch (if it works out, as I haven't tried it yet) will only be used to pull trees up to the tractor from a short distance away so I can line up the butts without moving the tractor around so much. I won't use the winch cable to skid the trees out with, I use the short chains in the top hooks for that. That being said, even if the winch doesn't work out, this set up was well worth the time. I spent about 6 hours today cutting and skidding and it works like a charm. I can get three decent size red oak butts up about 12" off the ground to drag them out. Tomorrow I'll use the tow hitch on it to tow a woods trailer in to get the log-length tops. I love school vacations!
Teach
/ Logging Hitch #9
just curious, what is the make, model etc for the wireless winch?
I saw one at the store who shall be nameless..
2K of load and small....
Later,
J
/ Logging Hitch #10
Look closely at the box in the first picture :D:D-- Chicago (harbour freight) 3000 lb wireless winch. I have that winch on a receiver mount and plug it in using a heavy duty lighter socket. So far it works fine -- the only annoying feature is that it does not immediately stop -- the drum continues to wind about 6" of cable. Nice to be able to stay out of the way though:eek:
/ Logging Hitch
That's the one! Mine doesn't stop immediately either, annoying, but what do you expect for $69.00? Just finished exending the wiring and added small battery clamps, will try it tomorrow or Wed.
Teach
/ Logging Hitch
Here are some more pics of the hitch in action. Full size trees get skidded out and the tops are taken out in log length in the trailer. Also a pic of Boomer enjoying the fruits of my wood cutting labor.
Teach
/ Logging Hitch #13
I have that same winch, and noticed the same thing abut it not stopping on command. Gotta watch out for that. I mounted mine on a plate that slips over a 2 in ball.
/ Logging Hitch #15
Nice Teach! I'm starting to collect "parts" for my future Frankenwinch. I think I'm going to go with a hydraulic winch, although I may go with electric due to the overload "safety" feature. Hydraulics don't stop.
PS - I hope you installed a lock pin in that lift arm draw pin in photo #2!!
/ Logging Hitch #16
cool set up i am awlays pulling logs out with my ford 8n and would love something better than that drawbar! Love the pics too:) In the second set of pic's it looks like the lift arm has no pin to hold you logging carryall on? just wondering??:confused:
thanks
--taylor
/ Logging Hitch #17
That's a better woods wagon than I have. (4x6 trailer with outboard tires) Long and narrow is certainly better to at least get by what my 4' wide tractor can get through.
What town in Rhody are you in?
/ Logging Hitch #18
Good Mornin Teach,
Very nicely done ! That thing looks like it would work great ! Good idea on notching out the larger logs for the chain.
BTW your missing a lynch pin on your lower arm !
/ Logging Hitch
Thanks Scott. I am aware of the hitch pin too. Already took care of it, I always keep a couple under my seat in the tool box.
Arrow, I am in Hopkinton, RI.
Teach
/ Logging Hitch #20
Good Mornin Teach,
.....BTW your missing a lynch pin on your lower arm !
Are guys on this board great or what? What an observant catch.
2002 FREIGHTLINER CST120 (A60736)
2002 FREIGHTLINER...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A61307)
Adams Load Out...
2018 CATERPILLAR TL642D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
2014 Jeep Grand Cherokee SUV (A61569)
2014 Jeep Grand...
2018 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2018 FREIGHTLINER...
2008 GMC W4500 4X2 14FT BOX TRUCK (A59906)
2008 GMC W4500 4X2...
