Grading Blade for B2410
/ Blade for B2410 #1
boothill
What size rear blade is advisable for a B2410. Is a B2410 robust enough to handle blading jobs? Is grading hard on the HST. Thanks
/ Blade for B2410 #2
60" to 72" should be fine. I bought a 72" for my B3030. I wish i had bought a 84". You want it wide enough so when you angle your blade your tire tracks are covered.
/ Blade for B2410 #3
A 4ft or 5ft would be what you need. As far a the HST it will do fine in low range. You might want to put some weight on the blade itself it might work better.
hope this helps
/ Blade for B2410 #4
What size rear blade is advisable for a B2410.* Is a B2410 robust enough to handle blading jobs? Is grading hard on the HST. Thanks
*Even the little BX1500s are.
That said I'm sure a B2410 is.
I'd be using a B2410 today If i had not discovered the BX23 before i finalized the deal on the B2410.
