Acceptable Cantilevers
/ Acceptable Cantilevers #1
yooperdave
Marinette, WI
Tool Cat 5600, LS XJ2025H, Branson 4215HC
I have a bed extender for my pick up which lets me haul 16' long lumber routinely. The lumber cantilevers about 4' beyond the bed extender support.
As long as I put a red flag on the end of the load, I have never been pulled over.
If hauling a load on a trailer, what is the maximum cantilevered length extending out the back of the trailer?
Initially, I am concerned that the load might bottom out, as the trailer would sit lower to the ground than the bed of the truck.
I have a couple of W10 x 68 x 30' long steel beams, and I did not want to cut them in half to haul. Maybe I need to hire a semi.
Yooper Dave
/ Acceptable Cantilevers #2
I know that it varies by state, and I know that you can legally get a pretty long overhang if you flag it. You need to call up you highway patrol and ask.
In Oregon, I remember talking to an officer about that and he said that the power company carried poles on trailers of some sort, where they had 10' or more of overhang and that was OK with a flag.
/ Acceptable Cantilevers #3
Not sure but here is a funny story. Seems I see all the crazy's out there. So I am going to my sisters house on I70 a few years back and I see a Suburban in front of me with something hanging below it. It was 40' or better sections of guttering. The guy had a ratchet strap supporting them off the hitch in the rear, the tow hooks in the front, and one in the middle going to the door handles on the back doors. He also had rope supporting the very ends front and back to the luggage rack on top of the SUV. He did have a flag on the front and rear. I swear it was only 6" off the ground and was sticking out 10' front and back. I followed him for a good 20 miles and he had no issues. We have a place called Aluminum Products and they will custom make any length of gutter you want so I guess that is what he did. Myself just call the gutter guy and he comes out with a truck and a gutter maker in it. He makes what you want on site, any length.
Wish I had my camera that day.
I guess the moral of the story is just be careful and strap it down good and they will leave you alone.
Chris
/ Acceptable Cantilevers #4
Last year I purchased a fiberglass in ground pool and had to bring it back from Kentucky to Michigan since the pool was over 10' wide I had to get oversize permits to haul it back(big pain in the butt) however if my memory is correct I was allowed a 4' overhang off the rear 2' in the front. I think most police are looking for unsafe loads if it looks unsafe you can plan on getting stopped. All the weigh stations I stopped at didn't even want to see my stupid permits. Only time anyone said anything was when the tail of a strap came undone and was hanging on the ground but I couldn't see it because of the shape of the pool other wise they just waved me through
/ Acceptable Cantilevers #5
Yooper Dave
Put a coupler on the front of beam hook it to ball
Put the back on the trailer with say 2' over hang on the trailer with a red flag
Tie it down straight extend the light wires
thats how I got some telephone poles home
I did have to adjust the tie down on the trailer because it wasent straight and was tracking to one side
tom
/ Acceptable Cantilevers #6
I once hooked one trailer behind another to haul a 30' x 36" culvert. Block it up and tied it down right over the axles so it would move around in turns. I didn't have to go on any main roads.
Dan
/ Acceptable Cantilevers #7
Yooper Dave
Built a head board on the front of the trailer and let it go out over the truck
Each beam is over 2,000#.
One small slip up, and my new truck is going to the junk yard.
This brings to mind of that old show Tool Time (Home Improvement) where Tim Taylor dropped a steel beam on the roof of his prized car.
Yooper Dave
/ Acceptable Cantilevers #9
YOOPER, I had to haul a bunch of I-beams for my house, and one of them
was 30-ft long. I rented the longest flatbed bobtail truck in the San Jose
area....it had a 24' bed, and I rented it from a Ford truck dealer. It cost
somewhere around $100 or so for a half days' use. It had the turning radius
of an aircraft carrier. Worked well, and only 6' of overhang.
I was able to pull each beam off the truck with my tractor.
/ Acceptable Cantilevers #10
I don't know about other states, but in Texas your load is not supposed to extend more than 3" from the left side, 6" from the right side, 3' front the front, and 4' from the rear. There's an exception for vehicles designed to go on the back of a trailer to be used for loading and unloading (in other words, those forklifts you see mounted on the back end of truck trailers). Those can extend 7' to the rear.
/ Acceptable Cantilevers #11
Fed DOT laws state that you can have a load extending no more than 4' from the taillights. where I work we commonly carry loads on a trailer with more than 20' overhang, we have a lightbar straped to the load no more than 4' from the end... flags can not replace the lightbar, I was riding in a truck thats trailer was rearended with just a flag and the 1st thing the officer asked was where is your lightbar.
Chris
/ Acceptable Cantilevers #13
I've always heard you can have 4ft hanging out the back and be legal. After that, you'll probably open to debate with the officer that pulls you over. What I'd worry about is if they say you cannot continue driving with the load and you cannot leave it there. Things could get real expensive if you have to hire somebody to come get it from you on the side of the road.
Eddie
/ Acceptable Cantilevers #14
I own a set of those lights for personal uses. they tended to fall off the fenders of my utility trailer.
One of my coworkers was pulled over one night for not having a light on his trailer he only had a flag and anouther truck following "closely". the DOT cop was concerned that someone would hit the trailer... so the driver says to the cop that he was tailgateing so no one would hit the pole... officer said "I will pretend that I did not hear that, if I were you I would get back in your truck." lol.
Chris
2007 Chevrolet Silverado\ Silverado Classic Pickup Truck, VIN # 1GCEK14X27Z181945 (A61165)
2007 Chevrolet...
2018 Kia Forte Sedan (A61569)
2018 Kia Forte...
Adams Tender / Magnolia Trailer (A61307)
Adams Tender /...
2015 Ford Transit Connect Cargo Van (A61573)
2015 Ford Transit...
REDDICK 300 GALLON SPRAYER (A63291)
REDDICK 300 GALLON...
2004 Chevrolet Silverado 1500 Pickup Truck (A61573)
2004 Chevrolet...
