4n1 buckets recomendations
/ 4n1 buckets recomendations #1
P.L.
Member
I want to buy a 4n1 bucket for my ck 25 tractor with a kl130 loader. I am going with a wr long bucket because I already have one of their grapples and like it very much. The question I have is should I go with the HJ2 or the UJ2. I like the HJ2 because it weighs less. The UJ2 opens 12 inches wider though and seems more durable. I know some of you have a bucket already so I'm looking for your opinions.
/ 4n1 buckets recomendations #2
I have the UJ2 for my DK40se. If I were you (and committed :confused:to getting a 4n1), I'd get the HJ2. The UJ2 is considerably heavier as I recall and is really designed for bigger loaders. Your loader is rated by Kioti at the pivot pins but WRLong rates their 4n1s by mid bucket lift and I think the KL130 would come in at less than 1000lbs mid bucket lift. I believe (haven't checked) that puts you right into the HJ2 range.
The CK30 is a heavy tractor and I would be concerned about the HJ2 in dozer mode as it is possible to bend that lower edge by hitting a submerged rock or stump. That is a disaster for a 4n1 as it won't close properly after such an injury.
You may have seen some of my posts about my experience with the 4n1. I am lukewarm about these implements especially for people who already own a standard bucket and a grapple. There is almost nothing the 4n1 does that is not done better by the other two implements. If you spend half or less of what a 4n1 would cost and get a box blade then there is nothing at all the 4n1 really adds except the Swiss Army knife factor.
I do like using the 4n1 when I am using a BH to dig out stumps because the 4n1 can lift out a single stump with no trouble and can then be used to clean up the hole very nicely. However, you could do the same with a regular bucket and a chain or with the grapple and a shovel. Hard for me to justify the near $2K price for a new shipped 4n1 frankly. I got mine used off ebay for dirt cheap so I'm happy with it but I'd be disappointed if I'd spent that much (considering I already have standard bucket, grapple and box blade).
Thanks for the info. The main reason for wanting one of these buckets is the ability to pick up loose material. I do a lot of lawn installs and move a lot of material. I feel that would help pick up small piles of rocks and debri that would otherwise need to be shoveled into the bucket. I'm not looking for the a world of difference just a little less hand work.
/ 4n1 buckets recomendations #4
Try one out to see if it works for you. I've not gotten very proficient at doing the rock/debris pickup task but partly because whenever I try it I end up needing to get off the tractor to get that last bits anyway. I find it hard to get a lot of material into the bucket using the clamshell technique compared to the traditional float bucket straight ahead loading. The clamshell works very well for picking up a post or cinderblock etc but for lots of loose debris I have not been very successful saving time.
Thanks for the help. I think I'm going to order a standard bucket instead. For every good thing I hear about the I also hear a negative. I don't like the idea of adding More weight and I also don't like the idea of more hoses and moving parts, just more to break or go wrong. Thanks for the help.
White 5409 9ft. Disc Mower (A65640)
White 5409 9ft...
2020 Cat 302.7D Mini Excavator (A64047)
2020 Cat 302.7D...
2022 EZ-GO ELITE...
White 18' Disk (A66408)
White 18' Disk...
2018 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A65053)
2018 CATERPILLAR...
Pallet of 3 Large Electric Motors (A62679)
Pallet of 3 Large...
