L-225 Clanging noise in transmission
   / L-225 Clanging noise in transmission
Tell you the truth, it's been a lot of fun. I grew up working on cars, and after being in software for the last 25 years it's nice to get my hands greasy. A tractor is a dead simple thing in terms of electrical systmes, engine, drive train etc.
I'm currently undergoing chemo treatment, so I'm taking a few weeks off to get this done. I fgure as long as I've got it apart, I mght as well do what I can so it last another 20 years.
I'm thinking Ill be finding a chipped gear somewhere in the tranny or the differential, with the noise it made. I'll rebuild what I can, and clean it up a bit too - it will be much, much more than a "dupont" restoration. Today I'm taking the clutch into the dealership to see about getting it resurfeced, and replacing the disc. I'll probably pull of the flywheel and get that cleaned up too.
Well, I think I found the problem today. I popped open the rear end, and low and behold - the spiral bevel gear is all chewed to bits. I pulled off the right axle case, and the shaft differential gear bearing is totally shot. So at least it's new bearings for the shaft differential, and a new bevel gear. If you check out the link I have above, I've added pictures showing this. I reckon it will be monday before i can call around for parts.
To whomever suggested the spur or buldog gear (which I'm assuming is the same as the differential shaft gear) - you were the closest! I don't know if the bearing went first, and that caused the bevel to get chewed up, or the other way around.
   / L-225 Clanging noise in transmission #13
Good grief, that looks nasty. Hows the pinion look ?
Willl, the pinion looks in really good shape. Really, the only thing that looks bad (so far - I haven't pulled them out yet) is the bevel and the differential shaft bearing.
   / L-225 Clanging noise in transmission #15
That much damage to the ring gear usually means damage on the pinion too. Look close for cracks and worn profile. It's a lot of work to do twice.
yeah. I went in and ordered parts today - new bearing and oil seal for the differential shaft gear; new differential bearing race. What I cannot get is a new ring / pinion, so I'm going to have to hit up the salvage yards. Anybody have a recommendation? I hear there's a place out in kentucky or somewhere that has a lot of L225's. I kinda hate to use salvage parts after all this work to get here; but I'm open to options.
I've updated the link (http://www.facebook.com/album.php?aid=60021&l=6180b&id=577472985) with a few more photos. I haven't pulled out the pinion gear yet, I'll wait to see how things go trying to find a matched set pinion / ring; I'm hopefull that I'm done dissasembling, and all there is now is cleaning, painting and reassembling.
With a word to painting, I'm thinking of sticking with the stock kubota color scheme, although I really don't like the blue. It makes it hard to see if anything is leaking. I'm open to suggestions, though, as I'm not terribly clever when it comes to color.
BTW, so far I'm about $500 into this for parts - ~$300 for the clutch assy, and ~$200 for the bearing race, diff. shaft bearing and seal. I'll be into it a bit more for the ring / pinion, but with the exception of gaskets (differential gasket set) and replacement O-rings for the hydraulics, that should be it.
   / L-225 Clanging noise in transmission #17
BTW Softwear geek, how's the treatments going for you? I hope you're much better. How about the tractor repair? Did you get all the parts yet?
Thanks for the thoughts! Coupla things - cancer treatment is going well. More of an annoyance than anything else, but I'm bald as a cue ball.
Got the new ring and pinion, and have assembled them. I've put the engine and tranny back together, had to re-jigger the clutch a bit - the new clutch is more "inset" than the original, resulting in a lot more release bearing travel, which messes up the linkage.
I'm still waiting on some bearings, seals and o-rings from the dealership. I'll probably pick those up this tuesday, and get them on on wednesday. My HOPE is to have it all put together by this weekend - it depends on how much screwing around I have to do to ensure the ring & pinion are meshing properly. New pictures are up on my facebook site at the link below.
I'm taking the opportunity to make this look purdy, doing a lot of cleaining and painting. I'll be doing a lot more. I've attached some pics - also one of all the broken bits and metal filings I pulled out of the differential case.
   / L-225 Clanging noise in transmission #19
I'm thankful to hear your health is improving. I am highly interested in your "rebuild". The engine and transmission look good! It's amazing what cleaning and painting will do.
I can imagine that the whole thing will look like a new tractor when finished. My tractor only has 1200 hrs, but it obviously has sat outside it's whole life. It also has some hood damage, as if something fell across the front of it. It has some bondo on it. The thing runs good though, so the looks don't bother me. My only problem is that the transmission gets crossed up once in awhile and I have to take the shifter plate off, and line everything up. I'm not sure what is worn that casues this. Any ideas?
   / L-225 Clanging noise in transmission #20
Hi IRNCTY - sometimes this is caused by the little detent balls that travel back and forth in a drilled passage between the shifting rods. The balls stick into rod grooves so only one rod can move out of neutral at a time. But as the rods and balls & passages wear, the accumulated clearance can allow two rods to move at the same time, putting the transmission into two gears at once (just a lock-up if you are lucky - gear tooth breakage if not).
John 4 x 4 cart (A50323)
John 4 x 4 cart...
2006 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A51243)
2006 FORD F750 XLT...
2006 Ford F-150 Pickup Truck (A48081)
2006 Ford F-150...
2020 CHEVROLET W4500 16FT REEFER BOX TRUCK (A51222)
2020 CHEVROLET...
2017 Claas Jaguar 860 Forage Harvester (A52128)
2017 Claas Jaguar...
2021 CATERPILLAR 299D3 XE SKID STEER (A51242)
2021 CATERPILLAR...
