Thatcher (dethatcher) for BX2200
/ Thatcher (dethatcher) for BX2200 #21
This is the JrCo...on my BX2350...
I run over the lawn horizontal and vertical with just dethatch - then I drop the dethatch and run the 60" deck and the bagger - works like a champ!
I drilled two additional holes in the mounting brackets to fit - but you should contact them directly - great guys - they sent me the mounting brackets free of charge to see if I could make them fit - it was a make them fit and pay for them or just return them...
Best part is raise and lower from the seat - cross the driveway, walkway, patio...without even slowing down :)
/ Thatcher (dethatcher) for BX2200 #22
Do you happen to have a part number for the mounting bracket? I always thought those JRCO dethatchers would work well on a BX. I do think they are around 4-5 hundred bucks, but it is designed for commercial use so it should be great for around the house.
/ Thatcher (dethatcher) for BX2200 #23
I must say, the JrCo unit looks very robust. It is wider than mine, and has two caster wheels. Very Nice unit. My cheap unit is adequate for my needs, and matches my storage space, but many folks on tractorbynet have big yards, and this unit you picked should suit them well.
/ Thatcher (dethatcher) for BX2200 #24
This is something I crafted for my Honda 4514 last winter. I love winter as it gives me time to think and design new toys!
I actually had to build a hitch receiver and mount it to the front frame to mount the thing. It does work very well too.......
Craig
/ Thatcher (dethatcher) for BX2200 #25
Does it clean the lawn out well enough such as the rotating versions?
/ Thatcher (dethatcher) for BX2200 #26
I've been looking for somethign like this!?!?! I wonder if this thing will fit my Massey GC2400? It seems that very few attachments are made for the Massey but plenty for the Kubota :(
6 1/4 INCH OD 90 DEGREE ELBOWS (A65643)
6 1/4 INCH OD 90...
2022 EZ-GO ELITE...
2016 Great Dane 48ft. T/A Refrigerated Van Reefer Trailer (A64556)
2016 Great Dane...
2016 INTERNATIONAL PROSTAR 6X4 T/A DAY CAB TRUCK TRACTOR (A67147)
2016 INTERNATIONAL...
Buckhorn Poly Bulk Feed Box (A66408)
Buckhorn Poly Bulk...
BRIGGS & STRATTON PORTABLE AIR COMPRESSOR (A64276)
BRIGGS & STRATTON...
