08 F550 V10?
Status
Not open for further replies.
/ 08 F550 V10? #1
3500DIESEL
PA
2006 Kubota BX2350 with canopy
I was driving by the ford dealer and a truck cought my eye its a used 2008 Ford F550 reg cab with 9ft dump it also comes with a 9ft fisher X blade for $28,000 I priced on of these truck on the web and its a $40 truck its got 12,000miles and a 6 speed stick shift does anyone think its a good deal and is the V10 a good motor for the F550?
/ 08 F550 V10? #2
The V10 is a very good motor but a bit of a gas hog. My uncle has one in his 05 F-350 with a auto. It gets 12 mpg best and usually around 10. He has 4.10 gears and its a 4x4 and he has a Boss V plow on it. He had a 2002 F-250 I believe with the same motor and he has never had a single problem with either.
There were reports of guys blowing the spark plugs out but I think that is all hype. Probably a few idiots cranked down on the wrench and stripped the threads then popped the plugs. The diesel would be my first choice in any truck but the Ford V-10 has good power and torque and has proven itself a reliable bullet proof power plant. And with the prices of diesels going up and up along with the fuel I will consider a V-10 on my next F-350 purchase.
Chris
/ 08 F550 V10? #3
I have also noticed the price of used, smaller dump trucks being pretty low. The must deprciate pretty quick. I have seen ones that are 10 years old, with maybe less than 50,000 miles, selling for around $10,000 or less. Diesels seem to command a little more money. I thought about buying a lower priced one just to have around, but I think the maintance, insurance, license fees etc scared me off more than anything else.
/ 08 F550 V10? #4
3500- you asked if it was a good deal- it sounds fair depending on the condition of the bed and plow. Does either show heavy use? For being a year old- neither should show much wear depending on your location and how busy the guy was. I wouldn't consider a stick shift for plowing parking lots, plowing roads is different. The previous owner of this unit may not have been able to make it fit into his operation or his company just didn't do enough business to keep the truck. You may be able to get an "honest" salesman to tell you who the previous owner was or maybe the service dept can tell you more about the truck. A V-10 isn't a bad engine, just doesn't pass many gas stations, the 12 MPG seems resonable- I have read the V8 does about the same MPG w/o the torque.
You could call a local truck equipment shop and find out what that plow and bed sells for new, then figure what the cab/chassis sells at the dealer and go from there.
/ 08 F550 V10? #5
Chris
Chris, give it a break, it's more than just a rumor. Take the blue oval sunglasses off, read this article and tell us "it's just a rumor" :rolleyes: Everyone knows Ford didn't machine enough threads in the head for the spark plugs.
A Reputation Wrecked
The mighty F-series once enjoyed a reputation as solid work trucks that were dependable and capable of almost any task.
Ford truck owners, however, continue to tell ConsumerAffairs.com that the V-10 and 5.4 liter Triton V-8 are so poorly designed that the spark plug in the number three cylinder of both engines can -- and often does -- blow right out of its socket.
Some Ford truck owners have experienced the problem more than once. Some have replaced the expensive all-aluminum cylinder head only to have the plug blow out again down the road. Others have had the same problem in more than one vehicle.
"I have a 1999 F-150 and just blew a second spark plug on December 31, 2005 while traveling to Nevada," Paul wrote. "I was shocked to learn that my truck will cost $2,800 per head."
Ford refuses to stand behind the product, even when the owner has purchased the expensive extended warranty. Ford insists the problem is with the spark plug and says that spark plugs are not covered by the extended warranty.
Todd heard that explanation from his Ford dealer in Ohio.
"The local Ford dealer told me that there is no problem with the design and my extended warranty does not cover spark plugs so it would cost me $3,850 to put a new head in," Todd wrote. "What I do not understand is the fact that the spark plug did not break, it blew out of my engine! How is that not covered?"
Groovy? Not Quite
Mechanics who have worked on Ford engines damaged by blown spark plugs say there are too few threads machined into the number three cylinder spark plug hole inside the aluminum cylinder head.
The mechanics report that there are sometimes as few as three revolutions of grooves and that is probably not enough to hold the plugs when they are under stress.
"I have a 2000 Ford F-150 5.4 Triton with approx 85,000 miles on it," John wrote us from California. "It has launched a spark plug from the right rear cylinder and there are no threads left."
Ford dealerships are charging between $2,000 and $5,000 to repair the damage caused by the blown spark plug, according to consumer information and complaints.
Despite a petition detailing the issue, federal regulators at the National Highway Traffic Safety Administration have declined to address the problem.
Other than to deny the warranty claims, Ford has no comment on the issue either.
A federally mandated recall would have devastating financial implications for Ford because 17 million SUVs, pickups, Crown Victorias and Mustangs are potentially involved.
Recalling the vehicles to fix the cylinder heads would generate the largest, most labor intensive and perhaps most expensive recall in automotive history.
Source: Consumer Affairs. com
/ 08 F550 V10? #6
Believe what you want. All I know is there are more F-150 sold each year than any other vehicle, most with 5.4L engines, and if that were the case you would see the road sides lined with them. I have owned F-150's since 1996 with 5.4 engines, 5 total all worked very hard. My dad and brother-n-law have had another 8 F-150's or Expeditions and my friends have owned probably another 25 total and never one problem. The only common failure is the #? has had the COP go out due to it being located very close to the exhaust and heat kills them at 45,000 miles or so on the early trucks.
Again this is all internet hype. I could get the same type of negative info on any engine though google, even your beloved Dmax, in 10 seconds.
Again another vehicle/engine you have never owned that you are now a expert on.
Chris
/ 08 F550 V10? #7
There is a LOT of misinformation on the V10 Triton on the Internet. Rather than believing one negative post I'd suggest you go to this site Modular V10 (6.8l) - Ford Truck Enthusiasts Forums
And then post some questions to people who actually own and use trucks with the motor in it. They'll be more than glad to discuss the pros and cons of the motor - and more to the point, they can do it from actual experience.
/ 08 F550 V10? #8
Wouldn't one think that opinions registered from a "Ford truck enthusiasts" website might be just a bit slanted in favor of Ford?
I would trust findings from a "consumer affairs" based forum over the opinions of a Ford truck enthusiasts forum.
I actually like the V-10, but it definately has a documented plug-spitting problem.
/ 08 F550 V10? #9
Chris
Why does someone have to own something to be an expert or have knowledge on it?
You said yourself that you've owned a bunch of Ford Superduties, but it took me, a GM truck owner, to teach you what front axle was in your truck.
So are you an expert on your own truck? No, you most certainly are not.
Right, but we're not talking about other engines, we're talking about the V-10. Your denial that the Triton V-8 & V-10 spit plugs is making you look like you're in denial.
Are you telling us the Consumer Affairs article is pure BS?
/ 08 F550 V10? #10
My confusion of the front axle was just that. I have owned 3 Ford SuperDutys at one time, all different. When I made that mistake I confused my 2006 F-350 with my 2007 F-150. Either way there was a difference between the 2004 and the 2006 SD front axle. Shoot me, I made a mistake.
I am not in denial on anything. I know they have had a few spit plugs but I know my uncle works both of his very hard and has had zero issues. He pulls 25,000# with his current truck, gets 5 mpg doing it, but works it hard. Never pulls that load more than 30 miles.
I don't claim to be a expert on anything, there is always room to learn. I have owned 5 F-150's, 3 F-250/F-350's, 1 GM 3500 Dmax, and 1 Dodge 2500 Hemi. All the HD trucks were from 1999 to current and the F-150's go back to 1997 models. bought the first in 1997. So I have been around the block with this generation of trucks.
Chris
/ 08 F550 V10? #11
To get back on track
I had a F250 with a V10, 6 speed stick shift.
It was a fine truck, low is a granny, real nice when towing, etc.
empty it got 13mpg, towing it got about 7mpg
An F550 (that probably weighs 2000/3000lbs more than a F250) is going to be underpowered. And towing it's going to be a dog. (and terrible gas mileage)
Can you imagine this truck full of a load of dirt?
Plus, plowing with a stick shift, is just painful,the truck doesn't make sense.
The best way to get good mileage out of a V10 is to put a stick behind it, but to plow you really want an auto.
I'd pass, there are better deals out there.
There should be tons of "contractor dumps" out there for good deals by people cutting way back that make a lot more sense than this one.
/ 08 F550 V10? #12
It's cheap because it's a gasser...
Not a lot of demand for 350's, 450's, and 550's unless it's a diesel...
I would pass...
/ 08 F550 V10? #13
The OP didn't tell us what he wants to do with the truck. I own an '08 F-250 V-10 with 6 speed and average better than 13 mpg empty secondary roads. No significant highway or city use, no trailer towing- just my pickup for hauling everything I need, including loam, manure and whatnot. It sees about 3000 miles a year. (Otherwise i economize by driving Mustang GT or riding my Harley bagger, depending on needs.) For what i use mine for, the only drawback to that F-550 would be the higher cost of registration and maybe insurance.
On the spark plug issue, i believe that by '08 with the 3V vs. older 2V motors, there are more plug threads to fix the early problems.
/ 08 F550 V10? #14
Why so much concern on MPG. The truck I assume will only be used as a work vehicle or "tool" and if the "tool" is working it's making money. It's not like it's going to be a daily grocery getter.
I bought a gas guzzler V10 ( btw not that painful as one would suggest ) anyway, I only use it to make money. OH YA I could make an additional $5.00 if it was a diesel, BUT the diesel option was another 8k, so I bet I'm ahead of the MPG / Fuel price ratio since that 8K I saved will buy be about 25K worth of mileage.
/ 08 F550 V10? #15
Chris
Chris, BTW: I don't "love" my DMAX, I like it. Haven't found a diesel engine that I would say I loved, but a DT466 or a 5.9L Cummins would be close.
I actually like the Allison and the 11.5" G-80 rear more than any other parts of the truck.
/ 08 F550 V10?
Well it will be a main truck which i dont know if that will be the best,but it should make up its money in plowing and also plowing with a stick shift isnt that bad if your use to it. I will trade my 5.9 cummins 6speed with plow on this I love the diesel and all but I dont really need the diesel the most that I will tow with my truck is a Cat tracked skid steer so the V10 should do just fine. The F550 is geared up with 4.30 rears i belive so it shouldnt be that bad if i have a load on the back.I was talking to the dealer about why the truck was returned and just so happen the guy that use to own it was there he told me he just wanted a auto for plowing its easier on his knees so ya. I think i got everything.might be getting some pics for ya'll too I asked if he had any pics of it and he said on my computer so i gave him my email and he said he would send one or so.
/ 08 F550 V10?
just got a pic from the guy check out this beast. looks like the pic is from the summer.
/ 08 F550 V10?
LOL im sure it will be used for that if i buy it.
/ 08 F550 V10? #20
Chris
25,000 lbs behind a gas powered pickup for 30 miles????
Sorry man, but I gotta call you on that one. That's just too hard to believe.
My IH4800 struggles pulling 25,000lbs and that's a 60,000 GCWR dumptruck. :rolleyes:
Status
John Deere 320P (A64126)
John Deere 320P...
2009 Arco Trailer 6,000 Gallon T/A Tank Trailer (A61568)
2009 Arco Trailer...
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
Deutz F3L914 3-Cylinder Air-Cooled Diesel Engine - 54 HP - Pump Takeout (A63689)
Deutz F3L914...
2023 CATERPILLAR 150 AWD MOTORGRADER (A63276)
2023 CATERPILLAR...
2021 Caterpillar 303.5E2 (A64126)
2021 Caterpillar...
