Using a power steering pump for hydraulics
/ Using a power steering pump for hydraulics #21
Can you use one? Absolutely! They put out much more than 2 gpm that was listed. Well, to be accurate, many put out more. Some may only put out 2. I think most put out about 5-7 gpm at 800-1400 psi. But that's from my notoriously poor memory... The majority of ps systems ARE open center. The fluid just flows out and back at low pressure until the valve directs it agains a cylinder where it builds pressure and moves the cylinder. Only at the stops, it is against the relief. That's why when you hold the steering wheel all the way over it sounds different. It is also a bad thing to do as it heats the fluid up going across the relief. I would get some junk yard PS cooling loops and use them to help cool the fluid and add a large reservor for the fluid
A buddy had a $100 ford bronco with a rusted out body with a good 200cid straight six, a decent 4x4 driveline and most of a free jeep body, so he striped the bronco and put on the jeep front end and cobbled a cab up. In the back he used a 265gal oil barrel (also free) cut in half the long way to make a dump bed. He machined a 3" single acting cylinder out of pipe on his lathe for under 20 bucks and powered it from a PS pump. It would lift and dump a full load of oak or dirt with no problem at all and the engine at idle. It also powers a home made snow plow on the front. I did some minor help on the project and donated older tires for it. I think he had under $400 in the whole project.
By the way, he called it a "Beep" for half Bronco half Jeep.
jb
jb
Ok, finally something that makes sense!!!
I was wondering how you would cool the fluid if it were by-passing all the time.
I'm starting to think it would be better to use two pumps, one for steering and one for acc's.
Thanks, Tim
/ Using a power steering pump for hydraulics #23
Thanks, Tim
That's going to be simpler and safer than trying to split the flow from one open center pump.
/ Using a power steering pump for hydraulics #24
Yep, 2 pumps are better than one as they say. Uh, I'm not sure exactly who says that... but it's still true!
Typically, bigger vehicles have bigger PS pumps that flow more volume and at a higher pressure. It may make the bracket fab easier too if you remove the on pump reservoir and use a remote tank. They are pretty easy to weld up.
jb
Hurricane Power X3 Walk-Behind Debris Blower (A61572)
Hurricane Power X3...
UNUSED WOLVERINE HYD MINI STUMP GRAPPLE (A64281)
UNUSED WOLVERINE...
2008 Genie AWP-30 Single Manlift (A61572)
2008 Genie AWP-30...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
2005 Fontaine FTW5-8048SLW 48ft. 38 Ton T/A Piggyback Flatbed Trailer (A61573)
2005 Fontaine...
2016 Volvo XC60 SUV (A61574)
2016 Volvo XC60...
