Need for Building Codes!
/ Need for Building Codes! #1
WayneB
Elite Member
New Hampshire
Kubota B-7500
The county inspector had JUST signed off on it.
Said it was "all he could do since it was a remodel".
/ Need for Building Codes! #2
OMG
Needs to be slit up some ... maybe three boxes.
This is a no brainer...Is that yours?
NO NO NO it is not mine! A friend of mine in the trades sent me a file with a bunch of code violations. One has to wonder how anyone would think that was safe!
/ Need for Building Codes! #4
WOW now thats a birds nest.:eek: I bet they could have got one more wire in though looks like plenty of room.:D
/ Need for Building Codes! #5
Well it seems that all that is missing is the cover plate and a light fixture...
/ Need for Building Codes! #6
at least they used wire nuts and didn't try to stuff them into the box and put a cover on it.
/ Need for Building Codes! #7
hey what are you doing in my crawl space...:)
/ Need for Building Codes! #8
looking for code violations - gotcha ya!!!
Well here is another clasic!!
Caption stated:
No need to ground this box. The cigar box is located under a kitchen cooktop. Fendrich was a
local cigar company here in Evansville, Ind. I would call this a classic case of Indiana frugality.
Note: I have no idea where these came from, who generated the first listing, but I do find some of them really interesting. When we bought our hunting camp there was a mobile home furnace in the main room. All wired up with 12/2 and looked pretty good, until I traced the wire through the wall and found out they had plugged it into an outlet in the bedroom! The fuse box was on the other side of the main room so it would have required climbing under the camp to run the wire, why do that!
/ Need for Building Codes! #10
That should be in a 3-4 gang box, have an extension on it (and clamps to hold the wires in) or split be into several boxes.
Aaron Z
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
AGT Industrial STSD10 QA (A60463)
AGT Industrial...
Toro z turn (A56859)
429970 (A61165)
429970 (A61165)
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
HYSTER S60FT STRAIGHT MAST FORKLIFT (A59823)
HYSTER S60FT...
