Getting Rid Of My "Backhoe Loop"
/ Getting Rid Of My "Backhoe Loop" #1
Ductape
Elite Member
Central New Hampshire
Kubota B3030HSDC
So I'm staring at my tractor's rearend the other day............ and I said to myself, "Self........ it would be so much cleaner without that loop hanging off the back of the tractor".
I came up with an idea, maybe its been done before? I'm picturing a steel hydraulic manifold, bolted to the bottom of my ROPS, just inside my right rear tire. It would have an "H" shaped passage(s) through it. In the center of the "H" would be a shut off valve of some sort........ a simple manual ball valve, an electric (12V) solenoid, or maybe even something pressure sensative? When the hoe is on, the valve in the center would be closed forcing the fluid through the hoe. When the hoe is off, opening the valve would complete the loop......... eliminating the loop of hydraulic hose that hangs off the back of the tractor now.
I would think it would be fairly failsafe on my tractor, since forgetting to open the valve with the hoe off, would cause a squeal from the pressure relief valve.
Since I'm fairly computer illiterate, I had to draw it out on paper and take a picture of my diagram. Hopefully it will give a reasonable visual of what i'm talking about. If such a device already exists, perhaps someone could just steer me in the right direction with a part number and a place to purchase this.
Thoughts??
/ Getting Rid Of My "Backhoe Loop" #2
Something like what you have drawn is exactly what I used one time when I had a backhoe on a small skid loader. It allowed the flow to bypass when the bh was not connected and then when it was connected I could close the valve for full flow to the bh. I actually just used threaded pipe and the ball valve, for my no money solution, but I am sure that there is a more elegant way to do it. I will await those with much more experience in this kind of thing to provide the definitive answer.
Mike
/ Getting Rid Of My "Backhoe Loop" #3
You could probably accomplish the same thing with a single spool valve. You'd want a valve without a spring return to center. You could mount the valve just about anywhere and then just run the hoses back to QD's attached to the ROPS.
I know valves aren't cheap, but I don't think a custom manifold with the built in valve is going to be any better.
This one from Surplus Center should do the trick. It has a detent to hold it in the open position.
/ Getting Rid Of My "Backhoe Loop" #4
I don't like the manual valve you have in your design. Seems like it could cause problems if it was accidentally closed when the hoe wasn't on the tractor.
One of my quick connects for the hoe is mounted to a bracket that is welded to the rops. I still have the 'loop', but it doesn't move around.
Vic
/ Getting Rid Of My "Backhoe Loop" #5
Keep the loop, and just mount the QD's to a bracket like the way JD does it.
/ Getting Rid Of My "Backhoe Loop" #6
I think in Ductape's current set up he has to connect the tractor side QD's to each other in order to complete the circuit when the backhoe is not attached.
In JD's setup, isn't there some kind of valve?
Correct. I find the loop irritating and occaisionally in the way. Shirley there is a better way than having a loop sticking out the back of the tractor.
/ Getting Rid Of My "Backhoe Loop" #8
You can see the quick connect bracket mounted to the ROPS on the right side in this picture.
The loop it makes when the hoe is off is small and is stationary.
Vic
Vic, does your 3 point not rub on the hose when its raised?
/ Getting Rid Of My "Backhoe Loop" #10
It doesn't rub with the two implements I have, but if I had to spread the lower links a little wider it would. The dealer welded the bracket to the ROPs when I bought the tractor. The bracket could have been attached a little higher which would have provided more clearance.
Vic
/ Getting Rid Of My "Backhoe Loop" #11
The hose loops for my hoes are very short and when the hoe is not mounted,
they are connected together and out of the way. The longer hoses are on
the hoe. I do it that way with my custom set-ups with or without AUX
valves. I like to have the M and F ends connected together versus
unconnected QDs that collect dirt or need caps.
The factory setup on my B21 also uses a short loop with only one hose, and
the other QD on a bracket. Clean and out of the way.
Have you considered using shorter hoses?
/ Getting Rid Of My "Backhoe Loop" #12
There is no valve, but the tractor side of the "loop" are mounted to a bracket, and there is a short jumper hose. A lot of Kubota's just have two hoses hanging free in the rear...so I assumed his was this way.
Ductape: Why not post a picture of what it looks like now so we can give better input?
/ Getting Rid Of My "Backhoe Loop" #13
I get it. Thanks. I had the "Kubota" floppy hose in my mind as the scenario.
You could about do the jumper hose all out of solid fittings. Put a few 90's together with a nipple or adapter in between and you've got your loop with very little obstruction, intrusion, or interferance.
This would work especially well if you're retrofitting since you could build the solid jumper and then adapt the bracket for the QD's to fit the span of the jumper.
2015 ALTEC AT200 MOUNTED ON 2015 FORD F450 XL SD (A67148)
2015 ALTEC AT200...
2022 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A64556)
2022 Chevrolet...
2006 Dodge Charger Sedan (A64557)
2006 Dodge Charger...
2025 IRanch IRTPL 10,000lbs. Two Post Automotive Lift (A64194)
2025 IRanch IRTPL...
HARGEE 18' BOGGIE AXLE METAL TRAILER (A63291)
HARGEE 18' BOGGIE...
2015 VOLVO P7110 ASPHALT PAVER (A65053)
2015 VOLVO P7110...
