DK 45 or DK 55?????
/ DK 45 or DK 55????? #1
nedly05
Adk. Mtns. NY
Kioti DK55
I am thinking of trading my skid steer for a tractor and I would like to go with a Kioti DK45 or a DK 55. The way I figure it I can afford to get the 45 with a cab, or a 55 no cab. I probably will only be able to afford the 45 with no cab, that seems to be how it always works:rolleyes: So what do you all think, whats the best option for me, or should I just keep the skid steer?
/ DK 45 or DK 55????? #2
Can you give us a little more information.
What will you be using the tractor for ? What are you using your skid steer for?
Do you want/need a cab ?
/ DK 45 or DK 55????? #3
I personally think that the DK45S with a cab is an ideal setup. I have never read anything going wrong with the DK45S. I would look at tractorbarn.com for several Kiotis with cabs. With you being so far north, a cab would be great in the winter if you must plow snow. You didn't say what you would be doing with the tractor, so if for general use, and not strictly farm, baleing hay, plowing I would think the DK45S would be the etter deal. Remember that the 12/12SS on the DK45S has three gears in low range which are below 1mph. This is ideal for snowblowers. Plus the DK45S has a rear 3pt hitch adjusting arm. All in all I still think its a fantastic tractor, even though I purchased a NHTC48 with the 18LA loader. I just loved the 18LA loader. I wish many other manufactures, especially NH would have offered a 12/12SS transmission with lower than 1mph gears. Lowest I have is 1.13mph. I would gladly swap two of my faster gears for a few slower ones. Also unless you are on flat road, in top gear, the tractor gets going almost too fast. The NHTC48DA is suppose to top out at 18.5mph I think, and I must say it really gets rolling, feels faster, almost like 20mph. Good luck with your choice, the Kioti is an excellent tractor. :)
/ DK 45 or DK 55????? #4
I would tend to agree that a DK45 without a cab is ideal! That there is self-supporting rationalization. I'm up her on the eastern edge of the 'Dacks, and right about now I could sure use a cab for plowing snow. But next week, when I head off into the woods to get more firewood, I'll be glad to not be surrounded by fiberglass, plexiglass and/or glass. Also, I will be clearing miles of trail from a logging operation, and have to get tons of stone out for my foundation facade. Already I have cracked my sushade just plowing snow.
As was mentioned, you haven't gave us a glimpse into your intended uses. That would be a big help.
It would be used for getting firewood, driveway maintenance, snow removal, things of that nature. I am sort of leaning toward the DK 45s with no cab, just for the fact that I will most likely go someplace that I will smash a window or something (like getting firewood). It would be great to have a cab in the winter though so.....maybe starting off without it would be the best, then look into a nice cab down the road??? Thanks for the quick responses!!
There is a brand new DK45S on tractor house, but there is no price, and it has the 8X8 trans. What would a DK45S with no cab, a loader 4X4 and 12X12 go for??
/ DK 45 or DK 55????? #7
SS has its place and can do everything you stated you wanted to do however, if a new tractor is what you're looking for, & bear in mind I am not running with the "Pack", but I'd be hard pressed to justify the HP you're looking at (extra$$) for those tasks. I think (lead dawgs correct me here) a CK series in the 30-35hp class would do you just as well and give you some dollars for attachments. Throw-in the cheap financing/free loaders etc... and I'd be slightly jealous of your significant savings over my own rig. If you were haying or doing commercial work my $.02 opinion would be different.
/ DK 45 or DK 55????? #8
have you considered a dK35?
same frame, still get the set of rear remotes and skid steer compatible loader, but about $2k less than the DK45, and there are some good dealers here on TBN that will give you good advice about tractor size and wants vs. needs.
I do similar things to what you say and had one suggest I look at the DK35 or the CK30, one being "more than enough" to meet my needs, and the other being "capable and very affordable"
good luck!
/ DK 45 or DK 55????? #9
2YD makes some valuable points. Another disadvantage to such a large machne is its nimbleness "around the house". For instance, I can't drive over my septic tank, pump tank, or leach field, where I could with my former Jinma 284. This removes 50% of my yard, including my basement walk-out, from access.
The reason I got the DK45 was for the remaining 250 acres of woods and 150 acres of ag lands. I needed size and power to efficiently create & maintain ditches, mow idle pastures, mow, bale and transport hay, etc. For that it is barely sufficient, but affordably efficient.
Sure, a DK45 does all the thinks you desire, but so did my Jinma. Unless you have some serious heavy lifting or need to process faster, a tough little CK would do nicely. Yes, big implements are quite expensive, and rarer to find used.
You've come to the right place, and I'm sure other folks will help you much more than I.
/ DK 45 or DK 55????? #10
good luck!
You may want to consider the dk40, it has the basically the same powertrain as the dk45 only a little less hp 41. The dk35 has a smaller powertrain and is only a little less in price than the dk40.
There's a kioti dealer on this site Wallace that you might want to contact. Rick will help you even if he knows upfront you plan on buying elseware. Not many dealers that do that. Good luck with your buy.
/ DK 45 or DK 55????? #11
Guys let me help out here...
First off it looks like he is look at the DK45S not the SE.
The DK45SE is not available in a 12x12 trans it is hydro only.
The DK45S also has a larger frame and a self leveling loader.
Nedly05 just a little heads up the DK45S you saw advertised with a8x8 trans had to be a typo it is only a 12x12
Thanks, Guys!!!! great fast responses. My reasoning for wanting to go with a bigger tractor is that I work for my father in his excavating business, and I am used to being on big iron for 10-12 hrs a day, so for 1 I think I would quickly get frustrated with a CK. We have a DK65 and its been a good machine for us or I wouldnt even go this route. Secondly, I want to be able to use this machine for getting out firewood with a farmi winch, and not have it take too too long, then be able to load the wood into our 1 ton or our 5500 to take it home. Thirdly, there are times at work when we could use another tractor, mainly when we are doing road maintenance, and nothing less than 45HP would be effecient, so I would have a chance to make a little money with it too. I also wouldnt mind getting set up with a brush hog and making a little side money cutting fields.
Rick Wallace is working with me to work up a number for my trade and see what it would cost me to trade for a DK45 s with a farmi. He seems like a great guy, and from all of the positive talk on here I have no reservations about working with him! I do have a Kioti dealer 45 Min. from me that we deal with so I might have to give him a shot too, but I am not devoted to him and wouldnt mind working with Rick instead.
/ DK 45 or DK 55????? #14
I had no idea sunshades were rated to plow snow.
(Tongue firmly planted in cheek)
Don :D
Well.....I'm a creative stunt operator.....I find ingenious uses for all surfaces in every orientation possible. It's just the way I roll.....:D:D:D
/ DK 45 or DK 55????? #15
Soooo.....you've been holding back on some information...I knew you wouldn't last long under the intense interrogative techniques of these ruthless professionals....:cool:
Now that you've come clean :D, it seems the DK45 would fit the bill. For me, it gets stuff done faster, and then a whole lot more to boot. I've done a few side jobs with mine. Although I had my reservations, the KL451 self-leveling loader is quite handy for material handling, especially with pallet forks.
I'm looking into a flail mower for cutting my fields, A rotary cutter is OK, but a flail would appear to work much better for fields.
I gave my local guy a shot, but he refused to even come within a few thousand of Rick. He would not sell me a Woods backhoe, only a Kioti backhoe, despite the fact that he's a Woods dealer too. Apparently some dealers do not want to sell tractors. Rick does.....and he will service what he sells, where he sells them.
Good luck, and good deal!!
/ DK 45 or DK 55????? #16
Currently the incentives are a little better on the DK45S htan the rest of the line. you can get 0 for 72 months or a bigger cash rebate on that model than the others.
I'm wondering if its the same dealer that I just talked to, sorta halfway between the two of us?? I'm looking forward to hearing back froim Rick!!
/ DK 45 or DK 55????? #18
I'm now in the third winter with my DK45SC. The cab is great (nearly essential) for winter work and nice for field work in the summer. I find it nerve-wracking to head into the woods with the cab, but so far I have managed to avoid bashing anything into it (well, not hard enough to break anything, anyway).
This unit is just about right for my uses, but marginally powered for serious work (whether snowblowing, mowing or whatever). It will do these jobs, but slower than a bigger unit would. I wish I had a big snow bucket; the 451 standard bucket is too small for moving snowbanks that the blower won't bite into.
I especially appreciate the way it has always started for me, even in the coldest weather.
BOB
/ DK 45 or DK 55????? #19
Actually, no. This one was east of me. But the dealer you mentioned had a used DK55 with a Woods BH9000 backhoe, and he wouldn't make a deal I could couldn't refuse.
Rick will kick a**.
We will have to see, I would really love to work with Rick, but its all about who has the best deal!!!!
2014 Sullair 185DPQ 100psi Towable Air Compressor (A61572)
2014 Sullair...
2026 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2026 SDLANCH...
Caterpillar 245D Excavator Service and Parts Manuals (A63117)
Caterpillar 245D...
2007 Generac 005421 Quiet Source 45kW Generator (A61572)
2007 Generac...
Safety Basket Forklift Attachment (A61572)
Safety Basket...
UNUSED 1RANCH 1RET13 ELECTRIC TRICYCLE (A64280)
UNUSED 1RANCH...
