Snow Help me ballast my 2210 for snow work
   / Help me ballast my 2210 for snow work
Nope, not a single manual even though I asked. I've found them on line of course, and read the entire thing, but the ballasting section did not sink in until I got tippy.
I hear you on the filled tires not being removable- I was figuring that it was a cheap way to add weight is all. I'd like to be ballasted without the blade as I can't even turn around on my road without burying the blade in a berm right now. I guess I could always pick up a ballast box if I take off the blade, so maybe that's a better option for me.
No tool box or storage of any kind is annoying too- I've got to work on that problem soon.
Anyone know what the max oil pressure on a 2210 would be? I'd like to add some gauges, when I can figure out how to mount them without it looking bad.
I may build a pod for just in front of the steering wheel. I'd like an Amp meter, volt meter, oil pressure and water temp at least. Maybe a clock and air-temp if space allows.
Looks nice. Whatcha got in it?
   / Help me ballast my 2210 for snow work #26
'm a new 2210 owner, and don't yet have the tractor in "ballance". It has the 210 loader, and a RB2072 rear blade. The first night I owned it I was pushing back snow berms and ran up on one and crashed the blade in to the pavement. The next morning I noticed the top link was bent.
Just a thought.
The 3ph is (by design) made to pull the load, rather then push. I try to avoiding the temptation of pushing my 3ph rear blade is reverse. Most 3ph rear blades do not have the spring blade trip feature of a snow/front blade setup. Much better to pull the rear blade and leave the pushing to the front loader. Good luck!
I'll keep that in mind- I can reverse the blade around, but I have been pushing it backwards a little too. JD wants $110 for the end of the top link that is bent, where I can get an entire new one from Northern Tool for $25. So I have that and lights on order, and will try to straighten my bent one later on.
After much thought and research, I caved in and used the beet juice in the tires- $80 total for both tires from Less Swab, so not bad. Weight of each tire after the fill was 148 pounds. I forgot to weigh them pre-fill.
Bent link:
Here it is with the tires back on, and the new chains on:
   / Help me ballast my 2210 for snow work #28
Z:
That took quite a bit of force to bend that top link. You can push with your rear blade; but do it with loose dirt/snow and at slower speeds.
   / Help me ballast my 2210 for snow work #29
Z:
It did, but keep in mind that having that much thread exposed on the link also makes it vulnerable to bending. I know that is what it took to adjust where you wanted it, but it makes it vulnerable. Farm and Fleet around here carries the links. You could probably go to a racing parts store and get and end link for it too. JD is really proud of theirs!
   / Help me ballast my 2210 for snow work #30
It's my understanding that Zephrant was going forward when he bent the link. He just went up a steep incline, and hit the blade on the pavement behind him when it bottomed out.
2009 Sterling Acterra Altec DM47 TR Insulated Digger Derrick Truck (A55973)
2009 Sterling...
2015 Peterbilt 389 T/A Sleeper Cab Truck Tractor (A55973)
2015 Peterbilt 389...
2005 Chevrolet Impala Sedan (A56859)
2005 Chevrolet...
2014 INTERNATIONAL PROSTAR (A58214)
2014 INTERNATIONAL...
Steel Work Bench 24" x 60" w/6" Irwin Vise (NO CONTENTS) (A59076)
Steel Work Bench...
2014 International Derrick Digger Truck (A55973)
2014 International...
