TC25D - Fuse #5 Blowing
   / TC25D - Fuse #5 Blowing #1
gz07g2
Having trouble with my 30A fuse #5 blowing when in the glow plug heat cycle. Pulled the preheat relay and can crank over tractor all day without blowing fuse. Pulled NGK glow plug lamp timer relay and bench tested per previous threads and didn't light up at all with a test light - therefore suspect this is bad. Will this timer cause this 30A fuse to blow after a second or two of preheating the glow plugs? I verified power at the buss connection of the glow plugs for that timeframe until the fuse blows. New timer appears to be about $60-70 so wanted to make sure I didn't ruin it if something else was wrong. Looking at the wiring diagram it almost looks like this timer relay only controls the display light on the dash and doesn't shut off power to the glow plugs themselves. Does anyone have a better wiring diagram for this timer relay - NGK model no S81NF? Any better sources than the NH dealer for this part? Thanks for your help.
   / TC25D - Fuse #5 Blowing #2
The original timers often go bad, but the replacement I put is has worked just fine. I think blowing the 30 amp fuse is a different issue. The ignition switches also burn up on these machines. I think the starting circuit needs to be modified to really fix it (but that's what I always say!) I have a diagram if you want it.
   / TC25D - Fuse #5 Blowing #3
Steve, I'm in total agreement with you, the ignition circuitry for at least the TC33D needs some tweaking. Other than I have been very happy with my New Holland!
gz7g2, My original timer failed after a few years, I had a new one in for about a year without any issues. I also agree that your timer issue is probably not related to your 30 amp fuse blowing. Is your battery in good shape?
Tim
   / TC25D - Fuse #5 Blowing #4
May be of no help at all, but if my lights are turned on when I try and crank, it blows the fuse every time also. Probably not your problem, but for what it's worth. Good luck
   / TC25D - Fuse #5 Blowing #5
Not familiar with what your #5 fuse is for. I'm guessing for the glow plug circuit. If so and its not your timer or relay it is possible one or more of your glow plugs may be shorted causing a high current draw enough to pop a fuse. Check the glow plug resistance individually without the buss bar connected. I have a different tractor but had hard starting problems in winter and it turned out I had 2 of 3 bad glow plugs. One was shorted to ground, one was an open circuit, leaving only one working. If you have access to a DC amprobe you could clamp it around the hot wire that feeds the plugs and check current draw. If its close to 30A the plugs are probably at fault.
After more investigation this weekend using your suggestions, I tested each of the glow plugs but didn't really notice any difference by my meter. However, when I powered each individually one was blowing the 30A fuse while the other two hooked up individually and in parallel did not blow the fuse. Thus, I am now waiting on my dealer to get a new glow plug.
As for the glow plug timer, I'm sure its still bad but for $60 I'm going to go without for now since from what I can see it only controls the display light.
SteveInMD....If you have the wiring diagram available - I would like to see it.
Thanks for everyone's help/suggestions.
   / TC25D - Fuse #5 Blowing #8
I can only speak for the TC33D; my recollection was that its glow plug timer does indeed control the powering of the glow plugs to pre-heat. If I'm remembering mine correctly when my timer failed on my tractor, it was hard to start, especially as it got colder outside.
   / TC25D - Fuse #5 Blowing #9
gz07g2,
Can't help with the exact schematic for your tractor but here's the one for my different brand and model tractor. The principles are the same though your wiring may be different. It should give you an idea on how your timer and relay connect to the glow plugs. You can test the glow plugs individually with a simple ohm meter. One probe to the top of the plug, the other to ground. The one you tested that blows the fuse is probably shorted to ground which would create a high current draw exceeding the fuse capacity.
   / TC25D - Fuse #5 Blowing #10
Sorry for the delay - I've had family in town and haven't been keeping up here.
Ever since I changed my starting circuit as in the attached diagram I've had no electrical problems at all.
  • TC33DStartingCircuitWithNotes.pdf
   / TC25D - Fuse #5 Blowing #11
I should point out that this fix is not something I dreamed up. It's a standard method of making starting circuits more reliable on equipment with complex starting circuits such as lots of safety interlocks or very long circuit runs such as yachts. I don't know exactly what is wrong with the original design, but I do know that I've not burned up any more fuses, ignition switches, or glow plug timers since I made the change.
   / TC25D - Fuse #5 Blowing #12
It's been awhile since you had a problem. Could you send the wiring diagram? I have a 2003 TC33D that keeps blowing #5 fuse.
Thanks,
   / TC25D - Fuse #5 Blowing #13
Here is the wiring diagram for your TC 33. I had the same issue that started for no apparent reason. Retracing my steps prior to the repeatedly blowing the 30 amp fuse, I found I had removed the ignition key and reinserted it upside down and that is when the problem began. I now have it marked with a top and bottom and have not had a blown fuse since. Other suggestions for the problem is a self-resetting circuit breaker in place of the fuse and possibly gong to a 40 amp fuse that the later models have. BUT FIRST check the key.
   / TC25D - Fuse #5 Blowing #14
View attachment 384612View attachment 384613
Can you explain how the orientation of the key causes the fuse to blow? I am researching a repeated blown 30a fuse on my TC25 and came across this thread.
In my case I went to start the tractor last week and had no power like a dead or missing battery, no lights, nothing had power. Last time the tractor ran and I put it away without incident. After locating the cause (or so I thought) I got a replacement 30A fuse and installed it. When I turned the key to energize the glow plugs the fuse popped in less than 2 seconds. It was cool (about 50°F) that day. So two blown fuses with no apparent reason I am looking for answers before I put another fuse in. I've had the tractor a couple years and never popped any fuses, don't understand why now without warning this fuse blows.
   / TC25D - Fuse #5 Blowing #15
I can not explain why the up-side-down key makes a difference and can not see a noticeable difference in one side compared to the other, but it obviously makes a difference in the start switch. I do know that if I tried to start the tractor today with the key up-side-down, it will blow the 30 amp fuse. I went through a box (5-6) of fuses before I retraced my steps and reversed the key.
   / TC25D - Fuse #5 Blowing #16
I will have to experiment and see if this holds true for my TC25.
Can you tell me which way is up (as silly as that might sound) on your key?
What about other Ford/NH keys, did you have the same problem using other
keys.
   / TC25D - Fuse #5 Blowing #17
I only have one key and ended up marking a top and bottom on it. It has been in and out many times and I have not had an issue with the fuse since.
2017 Ford F-550 Bucket Truck - Power Stroke Diesel, ETI 40 Boom, 45 ft Working Height (A56438)
2017 Ford F-550...
2017 BX2680 Sub Compact Utility Tractor (A56438)
2017 BX2680 Sub...
2010 CATERPILLAR 320DL RR EXCAVATOR (A60429)
2010 CATERPILLAR...
159119 (A60430)
159119 (A60430)
DEUTZ MARATHON...
2007 FORD F-150 XL TRITON (A58214)
2007 FORD F-150 XL...
