Temperature gauge on a 2210
/ Temperature gauge on a 2210 #1
CFHartman
Keyser WV
John Deer 2210
Has anyone put a temperature gauge on a 2210. If so were did you mount the gauge and where did you put the sending unit in the block.
/ Temperature gauge on a 2210 #2
Yes, Drilled and tapped the plug on the opposite side of the T stat housing.
Thanks Labrat that look's good
/ Temperature gauge on a 2210 #4
Hi
I have been lurking a while here, can you tell me what the cable to left of your temp gauge is
Thanks
Chris
/ Temperature gauge on a 2210 #5
Labrat - What sort of carpet did you use for your floormats?
Any benefits (reduced sound etc) other than keeping the floorboards clean?
Is the carpet attached in any way?
thanks
Brian
PS - See this is what happens when you post pictures.. LOL
/ Temperature gauge on a 2210 #6
Chris,
The lever you see is the cable to adjust the chute deflector on the snowblower..
Brian,
The carpet is a runner from Home Depot I also put it under the seat. The reason was to reduce the size of the cutouts for the pedals and levers to stop some of the wind from blowing in the cab. Oh, no glue just laid it in..
/ Temperature gauge on a 2210 #7
That's a fantastic addition to the tractor LR... thanks for the pics. :)
/ Temperature gauge on a 2210 #9
Chris,
Is that a JD part, if so do you have part #
Thanks
Chris
Here it is:
LVB24958 KIT 1
REMOTE SPOUT CONTROL (ALSO INCLUDES 19M7139, (2) 24H1685, M90887 AND E64256)
You will have to get a price from the dealer though...
/ Temperature gauge on a 2210 #10
If I remember the kit was just over a hundred bucks but that was 5 years ago. I think it consisted of 2 kits. 1 was the kit shown above and the other was the mounting bracket for the side of the dash because the main kit was for a 4110 and the bracket kit was for the 2210. That may have changed by now.
