Kubota engine oil recommendation
/ Kubota engine oil recommendation #1
piller
Gold Member
Oakdale, TN
Kubota M8540HD ROPS
I've got a new Kubota M8540 tractor and was unsure which engine oil to use so I submitted a question using the kubota web site.
I received a call today from a service representative at Kubota headquarters in Atlanta, GA (I'm in Tennessee). I was told that I should use 10W-30 engine oil which has the CE or CF API rating. I was told not to use 15W-40. I was told that I do not need to use Kubota brand oil, I would not void my warranty by using another oil as long as it had the correct weight and API rating.
My operators manual says 10W-30 or 10W-40 with the CD, CE, or CF ratings. What is interesting is that I contacted two local kubota dealers and they both said to use 15W-40 which contradicts the operators manual and the advice from kubota headquarters.
So I went today and bought 3 gallons of Kubota 10W-30 engine oil, it has the proper API CF rating, actually it goes up to CI-4 I believe.
I was also told by Kubota headquarters not to use synthetic oil in the new motor, it had something to do with the rings. Kubota headquarters did not see much value in using synthetic oil but said if I really wanted to use it I should wait until the engine has 150 to 200 hours on it. I think I'll just stay with the standard oils which apparently are very good quality these days.
I have the hydraulic shuttle wet clutch transmission on my tractor and was told by kubota headquarters that I should use the Kubota SUDT fluid for the transmission/hydraulic fluid.
Finally Kubota headquarters also said I should use heavy weight 80W-90 gear oil in the front axle instead of the SUDT fluid. He gave me a tip on changing the front axle fluid, he said to open the drain holes at each of the outer hub gear assemblies and drain the fluid and then to use the front end loader to lift the front end a little and then to push down on the tire/wheel to tilt the axle to get more fluid to drain out.
/ Kubota engine oil recommendation #2
I have a L-4400, a couple of months ago I went on their web site and saw that CJ4 oil wasn't recommended, emailed them and received a reply that said the CJ4 oil was ok. They was a post here about it.
I've wanted to try the 5w-40 oil but my dealer didn't recommend it, said they only use 15w-40, when it's cold (below 40f the engine is very loud).
My manuel states 10w-30 or 10w-40 over 77f.
So I emailed Kubota and just recieved this email, Kubota does not recommend 5w-40 in the L-4400 but 10w-30 or 15w-40 is approved.
I wish Kubota and all their people would get on the same page, not much unity between anyone except they all seem to think the 10w-30 is ok below 77f.
I guess at this point I'll use the 10-30 in winter and 15-40 in summer but it would be nice to be able to use one grade of oil.
/ Kubota engine oil recommendation #3
Hi..
I am in southeast texas, so temperature is a factor here..
My dealer recommends straight 30w so that is what i have
been using, but again not much cold weather here...
I agree, Kubota and their dealers need to get on the same page and update their API rating and engine oil weight specifications. The guy at Kubota headquarters I spoke with told me that for my new engine and cold weather I should definitely use 10W-30 and not 15W-40.
/ Kubota engine oil recommendation #5
Darn, I just put in 15w40 kubota oil per dealer recommendation here in Sunny Vermont.
/ Kubota engine oil recommendation #6
I find it strange that they dont recommend the 15w40 - I thought that it was the 'standard' (ie most commonly used) oil recommended for almost all diesel engines - it seems that most ppl recognize 15w40 as being a diesel oil right off..
Brian
/ Kubota engine oil recommendation #7
I've been running Amsoil 15-40 in my L2250 for the past 23 years, and it's never failed to start yet. :)
/ Kubota engine oil recommendation #8
At 150 hours I switched from 10w-30 kubota oil to 5w-40 Rotella Synthetic. I'm sticking with this until spring. Then I'll go with the 15w-40 Rotella. The kubota tech I spoke with about 2 months ago said it was just fine to do that...off the record.
/ Kubota engine oil recommendation #10
i have been using 15-40 in my B2400 and no prolem and it does get could here in western ny, i just let it warm up good before using it, but that should be SOP for any tractor in cold weather.
/ Kubota engine oil recommendation #11
I guess my beef here is that we're all being told something different.
Even though we live in different parts of the country some of our temps are close to the same and the eastern half of Kubota is saying something different than the western half.
JD can use a 0w-40, are Kubota's engines that much looser that we should be using 15w-40 and can't use 5w-40? The oil weight difference doesn't seem that great that it would matter unless their worried about the high temps, but 40w should be the same on either oil.
When I got my tractor it was fine at start up, after the 50hr service the engine rattles for a few minutes after startup, it probably had 10-40 in it from the factory and the dealer did use 15-40.
In my area 15-40 is fine in the summer and I know it's suppose to be good down to 5+ degrees. If I use the 10-40 in winter and 15=40 in summer then I will be changing my oil about every 30 to 35 hrs, I felt that the 5-40 would do away with this is the main reason I was going to use it.
If it didn't make such a loud rattling on startup I really wouldn't say to much about this except for the fact that Kubota is giving everyone different answers.
/ Kubota engine oil recommendation #12
Boy, those sure do seem to be some hit or miss answers you guys are getting!! :confused:
I can't imagine any of the excellent 5w-40's out there causing a problem in your 'bota's. One of the guys who works here has a B7800, and has been running RTS 5-40 in it since 50 hrs, with zero issues. As I, and a bunch of other guys who've switched from 15-40 to 0 or 5-40 have noticed, cold starting is much improved over the 15-40's, while giving up nothing to the 15-40's in hot weather. ;)
/ Kubota engine oil recommendation #13
My M7040 manual has 15w40 listed right in it even below 32F. Been running Rotella 15W40 in it since the 50 hr service.
/ Kubota engine oil recommendation #14
The additive in oil that makes it multiviscosity also causes the piston rings to stick in the grooves after long term use. More of this additive is needed for 10W40 oil than 15W40 oil. I know it has been recommended to not use a 10W40 oil for this reason. I will bet that if you look at your owners manual it will show to use a straight 30 viscosity oil when temperatures do not fall below about 70 degrees. Synthetic oils are more viscosity stable so I would not be concerned about the piston ring sticking problem. The piston ring sticking problem is not something I have read about lately but I do know it has been a problem.
This link on the kubota web site:
Kubota Tractor USA - Lubricants Schedule
does not mention 15W-40 anywhere. The link says 10W-30 is good up to 77 degrees F, above that it recommends 10W-40.
My kubota operators manual also says 10W-30 or 10W-40, it does not mention 15W-40.
The person at Kubota headquarters in Atlanta, GA that I spoke with said to use 10W-30.
Yesterday I changed my oil and used Kubota 10W-30.
/ Kubota engine oil recommendation #16
just make sure you use oil that is for diesel engines..
I use the rotella 15w40, cause thats what we put in all the Powerstrokes, Cummins and Caterpillar diesel engines where i work..
/ Kubota engine oil recommendation #17
I just checked my MF1250 owner's manual and it says to use straight 30 oil OR 10W30 oil when the temperatures are above 78 degrees F. It is well documented about the additive used to turn a single viscosity oil into a multi-viscosity oil causing piston rings to stick. I first read about this in Popular Mechanics some 20 years ago. Equipment owners need to be aware of this issue. Of course in the winter you have to run a multigrade oil but why would you run a winter oil in the summer anyway after all what do you think the W in 10W 30 stands for? The synthetic oils probably do not have this problem due those oils being more viscosity stable. I have taken too many engines apart with the rings stuck in the grooves. Read what Bob is the Oil Guy has to say or just google piston ring sticking and multiviscosity oils.
BMCNO Motor Oil 101
/ Kubota engine oil recommendation #18
That may be true with older oils and the low end products but today's polymer technology has come a long way. Many are not even the shear prone straight chain molecules anymore. Science has brought us the almost indestructible star polymer. They tend to be 12 point linked molecules that expand and contract with temperature variations instead of the coiling up and straightening out like the older straight chain molecules.
It's been a good many years since I have seen a failure analysis that indicated any type of VII polymer formations on piston rings and lands. The culprit in most failure analysis I see these day's are due to varnish and gum deposits caused by lower quality base stocks and the increased operating temperatures today's engines run. Even this type of long term failure has greatly decreased over the years. In the power generation turbine world varnish problems have greatly decreased over the past 5-10 years due to lubricant improvements.
I would have no problem suggesting a 10W/40 oil to one of my customers. I would however suggest the use of a 15W/40 diesel specific oil. The additive package in a diesel specific oil is much more robust than that of a automotive type oil. Greater anti-wear package and usually a much higher TBN. For cold weather operation I would suggest a 10W/30 diesel specific oil. About the only straight weight diesel engine oil I sell anymore is for 2 stroke Detroit Diesel engines. And since the introduction of API CJ-4 oils many of my 2 stroke DD engine customers are now using multi-viscosity CJ-4 rated oil. Upon scheduled tear downs they are finding the new lower ash CJ-4 oils work fine in the old 2 strokers with no indication of increased deposits.
/ Kubota engine oil recommendation #19
Are the new CJ-4 oils using the new star polymers?
/ Kubota engine oil recommendation #20
Many are, usually higher quality products. The problem with using multi-viscosity oils in DD engines isn't the polymers but the increased ash content. CJ-4 oils have a much lower ash content than any previous 4 stroke API rated oil and are getting close to the ash limit of 2 stroke oils. The ash limit was greatly reduced because these oils are designed to be used in modern diesel engines with particulate filters. The previous 4 cycle engine oils had a higher ash content (non combustible elements) that can plug up a particulate filter.
2006 FREIGHTLINER COLUMBIA T/A 6X4 DAYCAB TRACTOR TRUCK (A59912)
2006 FREIGHTLINER...
2016 MULTIQUIP DCA-25SS1U4F PORTABLE GENERATOR (A63276)
2016 MULTIQUIP...
Caterpillar C18 Industrial Diesel Engine - Serial N8F01121 - Power Unit - Pump Takeout (A63689)
Caterpillar C18...
2005 Peterbilt 378 Day Cab w/ Wetline 834826 (A62613)
2005 Peterbilt 378...
KBH Tank Trailer (A63688)
KBH Tank Trailer...
PALLET OF MISC METAL (A63291)
PALLET OF MISC...
