Need ideas for hearth floor
/ Need ideas for hearth floor #1
arrow
Super Member
Wakefield, RI
Mahindra 3016
At one point in time, our woodstove was in the living room. We moved it to the cellar so the kids wouldn't break their little heads on it about 30 years ago. Now, this new woodstove which I automatically placed in the cellar when we first got it 3 years ago isn't cutting it down there to heat the entire house as did the old Timberline which you could dump a whole wheelbarrow full of wood into. This new stove allows about 6 chunks of wood so I got to get it where we are and out of the cellar. (That in itself should be fun moving 500# up 13 stairs) At any rate, the wife does not want the same hearth floor as we had which was an 8" raised floor built out of Connecticut stone. She wants it flatter like 2" high at the most. I do not know what is available to go with the hearth wall which are mortered randomly placed stone. To build the floor out of the same stuff would be too high as the stone is 4" thick and pretty uneven. The floor will be 6'by 4' . I was thinking about 2 hunks of slate but at 2'x6' and 2 " thick, I'm thinking I'm not getting that into the house by myself or maybe 4 other people. To get the slate into smaller squares would not go with the look of the granite stonework that the hearth wall is made of and was told if I attempt to bust up the slate to get random pieces, the slate would flake and crumble, so I'm open to suggestions as to what is out there and how to handle this. Thanks
Lou
/ Need ideas for hearth floor #2
I made one out of fieldstone once, looked great! mortared the joints with a bag and my finger. Very cheap too. Only problem I had was I had to shim the stove legs because the stone was slightly uneven. I formed the edges with 2x2's and wrapped that with sheetmetal painted with stove black. Put in a bed of mortar and tap the stones till they're level. Then grout.
/ Need ideas for hearth floor #3
If you can get it cut to 2x6, can't you get 2x3 also? Is that too small? I would think you could move that with a furniture dolly and a set of helping hands.
Chuck
/ Need ideas for hearth floor #4
Have you looked at ceramic floor tile? It's available in a variety of colors, patterns, and sizes up to a handy 12" x 12" square. Matching bull nose and outside corners are also available, to trim it out, should you desire.
Then, you could use wooden framing, if desired, to shape it any way you'd like....
Our zero-clearance fireplace has tile facing and matching hearth... looks quite nice.
I did actually and matching the color seems little problem but the visual uniformity of the square tiles is just not going with the random stone vertical part of the hearth.
/ Need ideas for hearth floor #6
When I made my hearth years ago I bought a man made stone product (can't remember the name) which was about 2" thick and was styrofoam balls impregnated with concret. It comes in 2' by 2' blocks and weighs only a few pounds each.
I bought it at a store that sold woodstoves and I believe you probably cam still find it. It was also a lot less expensive than slate. It also came in about 10 different patterns.
/ Need ideas for hearth floor #7
Arrow,
If possible, can you put up a pic or two of your hearth/chimney you are trying to match?
/ Need ideas for hearth floor #9
Have you seen those ceramic tiles shaped like broken slate? They probably come in different colors. A friend used them in his entrance hall. He and his wife put them in and they came out looking very good. (Sometimes I wonder if that was why less than a year later they split up :( )
Chris
/ Need ideas for hearth floor #10
Have you looked at the large, square cement hearth stones? They are about 18 inches square and smooth on the top and sides. Just set them on a bed of mortar and grout in between them. Five or six should give you a nice hearth.
For a fancier look, flagstone rock can be cut straight with a saw using a diamond blade designed for masonary. I do this when building or repairing patios and walkways. In those cases, I cut halfway through the stone and break it off to give it a more random look.
For your situation, you could cut it all the way through and use that cut edge as the finished look.
Brick is always very popular. With a bazilion choices of color, size and shapes, it should be pretty easy to find a style that compliments your rock.
Eddie
/ Need ideas for hearth floor #11
on the wood stove we jsut put in, we had custom made a single piece of (not sure the name of it but I can get it for you) marble resign. they make bathtubs and sinks out of it. it's black and the guy who did it put the white lines in it to make it look like real marble, and it is only about 1 inch thick
/ Need ideas for hearth floor #12
The top of our hearth is Ubba Tubba, I think I have the spelling correct, granite. The granite is black the hearth is the same brick on the exterior of the house. We like it. :D
Granite comes in all sorts of colors and can be cut to shape.
Another option would be soap stone.
I have seen flat products made for hearths. Very thin stuff.
You could put down cement board and then attach ceramic tile, granite tile, marble tile, thin brick, etc. Gives you lots of options of matching the wall.
Later,
Dan
/ Need ideas for hearth floor #13
When I installed an old coal burning pot belly a few years ago, we used a piece of marble from an old restroom stall. was about 4' by 4' and 1&1/4 thick. Worked well. cut with a diamond blade in an old circle saw slowly. Could move into place with a 2 wheeler, and a friend. At that time the marble was a give away from a tear down. I would think you could still find something you would like, reasonable. Part of a cut off from another job at a counter supply store.
/ Need ideas for hearth floor #15
they make slate tiles that are pretty reasonable in price. Only about 1" think, on top of a piece of durarock, with some thinset and you're under 2"
BOX OF MISC (A63745)
(INOP) CATERPILLAR 518 LOG SKIDDER (A63745)
(INOP) CATERPILLAR...
1100 GAL PLASTIC STORAGE CONTAINER (A63745)
1100 GAL PLASTIC...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
1999 CORN HUSKER ALUMINUM HOPPER BOTTOM TRL (A63290)
1999 CORN HUSKER...
Kubota B21 TLB (A60462)
Kubota B21 TLB...
