What Did U Do Last Year ?
/ What Did U Do Last Year ? #2
Broke up and culitvated a lot of our property, put in a garden, hauled out over 100 years of old farm equipment and garbage. Planted a Deer Plot, cut up and hauled up
some trees, dug up some rocks and hauled them off. Cleaned up a lot of small rocks, had a big crop of those little ones.
Snow blowing and loader work with the little tractor, makes it nice to get into the small area where the big tractor can't go. Forgot a bit of mowing.
/ What Did U Do Last Year ? #3
Graded some roads, Put in some drives, Built some home pads, Dug some footings, Put in some UG Power, Moved some stucco sand, Screened some dirt for adobes, Loaded some tile roofs
Cleared some land for new homes
Other than that, Not to Much!!!
Terry
Looks like ya both got a lot done for the year.
Terry
Besides the usual mowing I.
Smoothed out some yard ruts.
Installed some 6 inch plastic drain pipe
Bought and set up a small 8 x 10 storage building which included running underground electric to it in a 137 foot trench.
Moved my pump and drum fuel storage set up out of my carport into the 8 x 10 building and upgraded the set up from a single 30 gallon drum to a dual drum system consisting of one 30 gallon drum and one 55 gallon drum.
Spread 3 ton of slag.
That's all I can think of for the moment.
L B
/ What Did U Do Last Year ? #5
Cleared snow from drive ways
Done a lot of mowing
Sprayed weed killer
Sprayed fertilizer
Leveled three driveways
Done prep work for a new drive way
Spread and leveled don't know how many tons of gravel
Moved a lot of dirt
Built a fence
Cut down and removed 6 trees
Bladed a drainage ditch
Vacuumed leafs
Moved a basketball goal
Raked and dragged a baseball field
Spread a compost pile
Tilled a garden with a borrowed tiller
Pulled a ZTR mower out of a mud hole
Broke up and removed a concrete pad
Pulled up fence posts
/ What Did U Do Last Year ? #6
bought mine:D:D
/ What Did U Do Last Year ? #7
bought mine:D:D
That's what I need to do. This past year I just rented a tractor for one day. Learned to use it and run the backhoe so that I could dig an 80- foot long trench for running electricical to the new garage. Then re-filled and smoothed it all back like new. That was one intense day! Lil' over 7 hours on the tach.
Going to the big Ag Expo in Feb (Tulare) this year by golly :D
/ What Did U Do Last Year ? #8
You guys are amatuers! We have 11 tractors, dozens of attachments, and 5 usual operators! We can't keep track!
Kyle
/ What Did U Do Last Year ? #9
Finally got the black walnut mantle put up and saw son graduate from NCSU with BA in turf management. Now for the hardwood flooring project early this year. I'd like to cut my own logs for lumber, but not sure that's going to be cost-effective. Looks like ya'll have been much busier than I have.
/ What Did U Do Last Year ? #10
Bought a small farm and then got a tractor.
Cleaned out the barn which had sat unused for 20 plus years.
Knocked some cedars over.
Smoothed out the rough spots in the access road.
Bush hogged ~15 acres that had not been cut in many many years.
Got a post hole digger and have been working on fencing ~ 17 acres to run a few cattle on.
I would still like to get a box blade, pto carry-all and some pallet forks for some work this year.
Warhammer
With Your Tractor
/ What Did U Do Last Year ? #11
Dang, I guess I need to quit restoring my old beast and start using it.
I added a 3 point hitch conversion kit, changed the intake/ exhaust manifold, rebuilt the carburetor, rebuilt the magneto, fixed the brakes, installed new front tires, rebuilt the 3 point lift cylinders and changed all the hoses.
I did run it up the mountain twice. :confused:
/ What Did U Do Last Year ? #12
Killed my Massy/ferg bought a ford 850 cleaning 10 acres of 3 inch Mesquite man that is killing me , used remedy some died some almost and some are just growing like weeds again , I rake after I shred (6 ft rake)also put up about 2000 ft of goat fence .put up a meter pole ,will have a well put in this year sometime this month will be building a 20x20 work-storage shed in feb weather holding !
/ What Did U Do Last Year ? #13
Brushoged (around trees) in old pasture not cut in 15 years.
Cleared leveled area for camper (love it!).
Dug septic system for camper colon.
Opened/cleared spring and piped water down hill toward camper.
Installed 12 and 16" conduits for creek crossing.
Leveled area for pole barn (not started).
Removed many trees with backhoe
Removed brush with grapple.
Made some 4 wheeler trails.
HAD FUN!!!:p
/ What Did U Do Last Year ? #14
2008
Augered holes to plant trees. (Rankin PHD)
Plowed the garden. ( 2 bottom plow)
Hilled rows for potatoes (home made hiller)
Rototilled the garden (Rotavator EM60)
Chipped up brush (JM-6)
Smoothed driveway and cut hiking trails (boxblade with gauge wheels)
Moved lumber and timbers around (front forks)
Raised 1 timber frame bent assembly (truss crane)
Skidded logs (3PH hitch and choker)
Plowed snow...lotsa snow (rearblade, boxblade and bucket)
2021 CATERPILLAR 306 CR EXCAVATOR (A64279)
2021 CATERPILLAR...
UNKNOWN  500BBL WHEELED FRAC TANK (A58214)
UNKNOWN 500BBL...
Electric Tricycle (A64194)
Electric Tricycle...
2006 INGERSOLL RAND SD100D SMOOTH DRUM ROLLER (A63290)
2006 INGERSOLL...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A59228)
2015 Chevrolet...
GMC 2500HD 4wd Service Truck (A63118)
GMC 2500HD 4wd...
