Ironworker - V-block and blade
/ Ironworker - V-block and blade #1
scarlo101
Ontario, Canada
Kubota BX 1850, NH TN75
Hi everyone.
I have recently purchased a used 45 ton ironworker. I want to construct my own brake dies. Does anybody have any experience building a brake V-block and blade or where I can find such info. I am currently building a FEL for my BX1850 as well as many future attachments and this ironworker will be a great tool.
Thanks in advance.
/ Ironworker - V-block and blade #2
I considered a used ironworker for a while. The tools, dies, and punches
they come with (or not) are critical, as you have found out. Machining
a V-brake tool and die is quite doable, but it would be hard to duplicate
what the ironworker manufacturer provided, esp with respect to hardening
the tool steel.
I had a friend with a mill make me a V-brake tool and die for my HF 20T
press. It works OK, for a poor man's hydraulic brake.
What brand ironworker did you get?
/ Ironworker - V-block and blade #3
snip........ Does anybody have any experience building a brake V-block and blade ......snip.....
Snip........
press. It works OK, for a poor man's hydraulic brake......snip
Not sure what an "Ironworker" is but I think I may have made something similar to what Dfkrug has for his HF 20 T press?
Are you thinking of something like this but on a larger scale?
I have detailed pics of what it took to make this thing if interested. Or check out this thread....
Reply number 46, 47, 48, 50, 51, 52
Reply number 51 and 52
And this link reply 172 Where I made an anvil for TBN member JJ.
Larry
/ Ironworker - V-block and blade #4
That's great, Larry! I will have to go back and read your whole thread.
Is that the HF 20T, 35T, or 50T press you have? I can tell from your
video you have the pneumatic-over-hydraulic jack. The orange paint
is a give-away, too.
What kind of steel did you use for the finger (aka anvil or tool) of your brake?
Common A36 mild steel does not heat-treat well.
My approach for my finger brake was to make the finger the full width of
the press and the die was a piece of 1" x 20" x 4" piece of steel with a slot
cut into it. I use it for plates as big at 1/8" x 10" or 1/16" x 20". Thicker
pieces I just bend between the lower frame rails of the press. I have some
1.500" ID DOM tubing that fits perfectly over the business end of my press. I
will take a photo when I get to it.
Here is a link to Scotchman Ironworkers. They are basicly a hydraulic
cylinder with a force-multiplying arm and they are used primarily for
punching, bending, and shearing. Scotchman Metal Fabricating Solutions :: Ironworkers
Hi guys thanks for the ideas.
The ironworker I purchased is a 2005 45 ton Uni-Hydro. Pic here Model 45-14
I do not have it yet, I will be getting it in the new year. It is a trade-in. I will need to replace the motor with a single phase 220v motor. It comes with a full set of punch dies.
I am considering using some 1.5 X 2' solid block welded up in a C-channel for my bottom die for now. For the blade I will probably grind a sharper V on a piece of 3/4" keystock. The max length the ironworker will accept is 9".
/ Ironworker - V-block and blade #7
LOL yea right, it's 26 pages. Didn't I hear you say that once before?
Is that the HF 20T, 35T, or 50T press you have? I can tell from your video you have the pneumatic-over-hydraulic jack. The orange paint is a give-away, too.
Yep it's an el-cheap-O HF, the 20 ton model. I removed the standard 20T hand pump bottle jack and replaced it with a H/F 20 T air over hydraulic bottle jack. Oh man does that make it a pleasure to use now.
What kind of steel did you use for the finger (aka anvil or tool) of your brake? Common A36 mild steel does not heat-treat well.
The only thing I know for sure is the steel is cold rolled that I picked up at metal mart. As a test of hardness I used a spring loaded center punch before heat treating, then again after. The after punch mark was not as deep as the pre-treatment, so I guess it must have hardened at least some.
OK, now I know what an "Ironworker" is, definitely not a tool for sissies, that thing is awesome, I now remember seeing a similar one in action shearing 3/8" X4" angle iron, nice machine, I am now envious of Scarlo having his own personal one - nice find and congratulations! What are you going to make with it?
Larry
I have been keeping an eye out for one of these for some time.
I am currently building a FEL for my BX. I want to make it a quick attach bucket. I will be making forks also. In the future I would like to make a fertilizer spreader, possibly a front mount generator and a rear log splitter. I would also like to do some odd jobs in the neigborhood. (Also have other projects as well, working on an invention and prototype)
Guglio, it looks to me that you are from Minnesota? That state is where many ironworker manufacturers are located. I think it was invented in that area of the country. You should be able to find some good deals on some used ones.
Scarlo
/ Ironworker - V-block and blade #9
What does A36 stand for ? In Europe, the most common steel is St.37.2 in the old DIN system, or Fe360 in a newer standard and S235 in the latest European standard.
Fe360 means Ferro (latin for iron) 360 means the break strength of 360 N per square mm.
In the newer standard, the practical use is taken as reference point, at 235 N/mm2 plastic (as opposed to elastic, non-permanent) deformation starts to occur.
I guess A36 is pretty much the same as Fe360, alias St.37.2 or S235 ???
/ Ironworker - V-block and blade #10
The full designation A36 is really ASTM-A36 and the ASTM stands for American Society for Testing and Materials. The 'A' in front of '36'
stands for AISI, the American Iron and Steel Institute. This is a mild
hot-rolled steel with a 36K PSI minimum yield strength. The tensile strength
is 58K-65K psi.
Others can add to this (or correct me if I am wrong).
I don't know how these designations relate to the international designations
you refer to. It is hard enough trying to find any metric SIZES in the US.
/ Ironworker - V-block and blade #11
I read most of it! I was pretty long, so if I missed some answer you already
gave, I hope you don't mind re-posting. The videos really show how
effective your design and fabrication was for the brake and the rake.
I got a HF air-over-hyd 20T jack, too, but I have not used it with my 20T
press. I think I should have gotten the 35T or 50T press, but the one I have
has worked well and I have used it tons. (Don't you hate it when you
should have bought bigger?)
These ironworkers come up on Craigs periodically and I lusted over them
for a while, but I decided that I do not want to dedicate the floor space and
pay the cost. I paid a guy with a real old 40T unit to punch a bunch of
holes in 1/2" plate for me. 1-1.5" holes are a real drag to drill. Now I have
the biggest drill press I could find and use plasma where I can.
/ Ironworker - V-block and blade #12
Those machines are very handy, I used to write programs for a Whitney 45ton plasma punch.
Keep in mind that there is a limit to what you can punch though (hole diameter vs. metal thickness combined with shear strength of the metal. You can bust or blow up the punch or die by coupling the wrong size punch with too thick/too high of a shear strength metal. Always check your chart or calculate it if you are unsure.
Punches are limited in compressive stress to 300,000 psi or less - 250,000psi used for safety and good punch life.
A good formula to know is Sc = (T x Ss X L) / A
Where; Sc is compressive stress in the punch
Ss is shear strength of material being punched
T is thickness of material being punched
A is cross sectional area of punch
L is length of cut (circumference of hole being punched)
Shear strength of some common materials is:
(based on about 80% of ultimate tensile strength)
Aluminum 6061-T6 29,000 psi
A36 steel 60,000 psi
Corten steel 64,000 psi
cold rolled steel C1018 60,000 psi
C1050 hot rolled steel 70,000 psi
316 stainless steel 70,000 psi
304 stainless steel 70,000 psi
Have fun but be careful and keep safety in mind! This stuff can hurt ya' !
Frank
2015 Teupen TL54J Crawler Articulating Boom Lift (A61572)
2015 Teupen TL54J...
2017 Bobcat E55 (A60462)
2017 Bobcat E55...
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63689)
2006 Cadillac GM...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2025 Greatbear Rachet Tie Down & Flatpack Tool Box (A61567)
2025 Greatbear...
Hydraulic Fire Plow Attachment (A61572)
Hydraulic Fire...
