L295DT W/FEL
   / L295DT W/FEL #1
dan c
Ione, Ca.
372D Mitsubishi
I'm looking at buying this tractor. Its runs good. Looks like ****.
FEL has alots of re-welded areas.
What should I look for with one of these? Advise?
$6,000.00 purchase price.
   / L295DT W/FEL #2
Many un-restored examples of these early '80s models are now getting ugly cosmetically. Many are still fine mechanically - but the weld repairs on the loader may indicate it's been beaten by more than the weather. Is the loader a Kubota 1720? Does it have an external pump at the front of the tractor? These loaders have very rugged frames so if it has been broken I'd look the tractor over carefully for other signs of abuse or neglect. There should be no oil leaks, air filter should be completely intact, hydraulic oil clean, loader pins reasonably tight, hoses intact, etc. Maybe you could post some pics?
   / L295DT W/FEL #3
I have one of these and they usually look like ___ but work pretty well. 6grand is a bit steep for one that doesnt have any attachments. I bought mine withe a gillian hours for that with a backhoe that was leaking like a pig also loader in good shape. Leaks, welding all over, but tranny and motor worked pretty good. all ptos worked front leaked (oring). Good tractor though
If it has a BH and a loader that is a good price, loader only nope, no attachments worth about 2k. box scraper and backhoe buy it now. But plan on fixing it and putting a few hundred in parts.
   / L295DT W/FEL #4
if it were me id buy a little newer before i got my new 7040 i could have gotten a mx5100 with fel 4x4 500hrs for 12500 best of luck to you
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
CAT 573 FELLER BUNCHER (A51242)
CAT 573 FELLER...
2014 Ford F-150 Pickup Truck (A50323)
2014 Ford F-150...
2011 JCB 541-70 TELESCOPIC FORKLIFT (A51242)
2011 JCB 541-70...
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
Toro Workman Cart (A50322)
Toro Workman Cart...
