Septic Fun
   / Septic Fun #21
If the smell did not start until after they roto rooted the root out I would call and ask if they cleaned the lines back towards the house. There is a chance that they broke through something cleaning those out. I would probably call them back and tell them to bring a camera and see what they broke
   / Septic Fun #22
I had my septic go down. Had to dig it up and repair part.:mad: But I did get a new tractor out of the wife to do it.;)
   / Septic Fun #23
Been plumbing for 25 years, park the tractor,
Been some interesting answers,open all the windows,You should be able to locate smell right off,
I would bet you have a bad seal on toilet,or dry trap or open pro vent,
pull the toilet & check your seal, good luck
   / Septic Fun #24
What is an open pro vent? I see you agree with me to park the tractor, unless you can figure out how to use one to pull a toilet.
   / Septic Fun #25
I like the toilet idea. I have seen a few pipes that were broken outside the house and really caused some problems. There is a spot in many toilets for waste to get under and around then sit. If you are not sure about the plumber then talk to him about the smell. From there, talk to neighbors they probably have had same problems. Sometimes they use the same builders. We have a T outside the house so we can open the line and stick a router into it. Do you have PVC or metal pipes?
Call other plummers. I like the ones that are small. Usually there wife is their business partner and they like to talk shop. They can give you ideas that would not be typical.
   / Septic Fun #26
Another thought, if it's an old out, sometimes it can be a pipe that backed up into the wall. Or it might be the washer. They back up on the ground and under them.
I had to dig up my whole system during the summer. It was a really fun time. At the end of the summer I knew more about my system then I really wanted too.
   / Septic Fun #27
Last year we had an outside break with the smell in the house. It was where the pipe went through our foundation had broken 2 inches outside. Most of the "fluid" continued on to the tank but some of it went down to the drain tile and the smell came from the sump pump. It was diagnosed over the phone from a very experienced septic man. Take off the clean out in your basement and look out towards the tank. We could see the break clearly. Just make sure no one flushes while it is open!
   / Septic Fun #28
If all your lines drain, then it's not the septic tank or leach field. If they didn't drain, that would be a totally different issue.
Like mentioned so many times already, you have a leak in your pipes or seals. Since you haven't noticed a leak, that doesn't mean you don't have one. Is the house on a slab or pier and beam? If pier and beam, you need to do an inspection under the house. It's not fun, but it will tell you allot if there's a leak.
Pinpointing the source of the odor will take some time. I'd open every window and close every door. Then go room by room to determine where the smell is the strongest. Some old vent pipes are cast iron and will leak between the seals. There is no fluid in them, just air. If it's a good sized crack, you will smell it in the wall. Fixing it can be a real pain to get to, but it really doesn't matter, you have to do it.
Don't forget the attic. It's not unheard of for a vent pipe to join other vent pipes from the wall and then become just one pipe as it goes through the roof. Where they join could be the cause of the smell. This might also explain it if the smell is all over the house and not just in one spot. Especially if there is little insulation in the attic.
Good luck,
Eddie
   / Septic Fun #29
$%^^ happens in the tiolet. So I still think starting there is the best. But also check under the washer.
   / Septic Fun #30
Could be a dead mouse also.
2022 JOHN DEERE 624P WHEEL LOADER (A52707)
2022 JOHN DEERE...
Toro z turn (A56859)
2011 DOOSAN G25KW GENERATOR (A58214)
2011 DOOSAN G25KW...
LIGHT TOWER (A56857)
Ford F450 Bucket Truck with Altec AT200A Boom (A56435)
Ford F450 Bucket...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A56438)
2006 Magnolia Dry...
