Stuck in cold, no block heater
/ Stuck in cold, no block heater #21
In northern MN the logging equipment have ports on the raidiator hoses.
Drive into the woods, run a couple hoses from the vehicle you drove in with to the machine you want to start, open the valves, drink coffee, shut valves and disconnect hoses, climb into easy starting and warm machine..
/ Stuck in cold, no block heater #22
I heard about the heater hose trick but wonder how hard that is on the block of both machines,-20 to 180 is quite a shock !
/ Stuck in cold, no block heater #23
A guy I work with talks about his son in Alaska with a diesel truck that has a mechanism to start it and run it every 3 hours for a few minutes to keep it warm.
I guess it quit working once when they were caribou hunting in temperatures below -40 F. The rest of the story involved something about split batteries and propane canisters in sleeping bags.
/ Stuck in cold, no block heater #24
Some of the big $$$$ remote starters have that feature. Simple as programming the times in, and you are off.
http://www.commandoalarms.com/itm30032.htm
/ Stuck in cold, no block heater #25
I have seen LP block heaters on off road well drilling rigs,looks like a pretty good answer.
2022 EZ-GO ELITE...
2018 CHEVROLET SILVERADO 2500HD (A65643)
2018 CHEVROLET...
TITAN 84RAKEV2 - 84" HYD LOG GRAPPLE (A64277)
TITAN 84RAKEV2 -...
2020 VOLVO EC200EL EXCAVATOR (A64279)
2020 VOLVO EC200EL...
Landhonor 8' x 6' Metal Shed (A66408)
Landhonor 8' x 6'...
Ingersoll Rand DD-24 Tandem Smooth Drum Roller (A64553)
Ingersoll Rand...
