Chains BX24 Tire chains question.
   / BX24 Tire chains question. #1
fred98050
Member
Pacific NW
BX24
Hi,
I am looking at these 2 link spacing Vbar chains for the rear tires of the BX24: 26-12-12 Tire Chains
Has anyone use the same setting on their BX24?
Any specific problem, clearance etc...?
Thanks you.
Fred
   / BX24 Tire chains question. #2
They look like the ones I have on my BX24 and no problems. I have wheel spacers (new this year) which puts the middle of my wheels nearer the lip of the fender and I was worried about that but so far no problems. Just make sure you use the chain tighteners or something similar. I use 2 HD bungees on each wheel to keep 'em tight. I have R4s by the way.
C6rider,
Thanks for your reply.
I don't have the spacers on my BX24, I was worried that the clearance behind the tire might not be enough. With spacers this might help.
I was looking at these:ATV Garden Tractor Adjuster
for chains tighteners.
I have spent some time on this forum for the past 24hrs and looks like most people had good things to say about Tirechain.com
This forum has so much great info, it is sometimes a bit overwhelming.
Also, I have read something about putting a pvc pipe on the FEL edge to avoid digging in too deep when using the FEL for snow removal, do you know where I can find some info about that?
THanks
Fred
   / BX24 Tire chains question. #4
Fred,
I have used 3" pvc cut the length of your blade and then a slit cut length-wise in the pipe so you can slide it on and off your blade. It has worked on gravel with no snow and then great on gravel with 4" or so of snow. It stays on even with the blade angled.
Wow! I would have never guessed that it would stay in place just by sliding it on the blade with no other means of attachments....
I guess I have all the info I need , blade, tire chain and blade protection, now it's time to have fun in the snow.....
Thanks a lot for the tip.
Fred
   / BX24 Tire chains question. #6
C6rider,
Also, I have read something about putting a pvc pipe on the FEL edge to avoid digging in too deep when using the FEL for snow removal, *o you know where I can find some info about that?THanks /\/\/\/\/\/\/\ /quote]
* D0 A search rite here on good ole T B N .
2020 MACK P164T (A58214)
2020 MACK P164T...
2008 Ford F-150 Ext. Cab Pickup Truck (A55852)
2008 Ford F-150...
2015 Ford Taurus AWD Sedan (A54815)
2015 Ford Taurus...
2016 FORD F-250 SUPER DUTY (A58214)
2016 FORD F-250...
UNUSED WOLVERINE SB-12-72W 72" HDY SCREENING BUCKE (A57193)
UNUSED WOLVERINE...
Brazen Cattle Shute (A56469)
Brazen Cattle...
