Rake Cost of Woods gauge wheels for rake?
   / Cost of Woods gauge wheels for rake?
hey sixdogs, do you think the Woods medium duty rake is worth the extra price they fetch for their equipment? I'm looking at leinbach and they're like 1/2 the price of Woods or Landpride, but they might also only be 1/2 as tough. Any thoughts? Did you look at "cheaper" brands before you bought?
I looked at a lot of rakes before I bought--and have owned several--so I knew I wanted a heavier one. For me, weight is important in a rock rake. Otherwise they tend to "bounce" and ride over things that should be swept up.
Same is true of a grader blade. I paid top dollar for my used 8ft Woods LR108 medium duty rake. It is heavy enough. Also found a used medium duty 7ft KMC rear blade that I wish was heavier.
I looked at cheaper brands and did not buy. In a sense, even though money is less, the cost is more because they often won't do the heavier jobs or will bend under duress.
It has taken me 40 years to learn but I have found if I buy the best I can afford I get the results I am looking for.
   / Cost of Woods gauge wheels for rake? #12
I know what you mean by "money is less, cost is more". I'm leaning towards the more expensive & heavier rakes, too.
   / Cost of Woods gauge wheels for rake? #13
I bought a heavy duty Landpride 7 footer rake and really like it. I shopped all the others and this was the only one I could find that would off set to either side which is really handy to rake out ditches and get close to banks and still keep the tractor wheels on track.
It's plenty heavy and works real well without wheels. I've made a set of great wheels to go on the scraper blade that slide into a std. 2" receiver, but I haven't used them on the rake yet as it suits me so far without wheels. I do have top an tilt which is essential for establishing level or tilted operation on the fly. Wheels would be more helpful if one doesn't have what I think is an essential feature (TNT).
   / Cost of Woods gauge wheels for rake? #14
Very helpful! Thanks.
Would you suggest a top-n-tilt for the 3pt over a rake with a power angling and power tilting feature?
I only have 2 remotes to use, so i want to make the best of them.
I would think the T&T would be better since it could also be used for a blade, but I wondered about a future quick hitch or using a 3pt bush hog and how the T&T would interface with them.
   / Cost of Woods gauge wheels for rake? #15
We recently purchase a Land Pride LR1572 Landscape Rake. We were getting tired of manually removing stones that cause the box rake from working correctly. I was considering purchasing the King Cutter 72 rake at our local Tractor Supply on sale for $437.20 but the quality can't be compared to Land Pride. My dealer priced the LR1572 at $750. So I went to do a face to face cash deal at my dealer and purchased if for $625 out the door. I know I paid $187.80 more but what a product. We used the rake to remove stones and help shape our drive way in the making. I am not convinced the gage wheels are worth the extra $300. I am pleased on its performance without.
   / Cost of Woods gauge wheels for rake? #17
I have a Woods 72 inch rake with and without gauge wheels. I bought it with the wheels but use the rake mostly without the wheels. If I were doing a final lawn prep or something like that I might conceivably reinstall the wheels but for general raking I find it easier to do without.
I do like and use a hydraulic topping lift with the rake. I don't have hydraulic tilt.
   / Cost of Woods gauge wheels for rake? #18
I need a 7 or 8 footer. Do you think a top/tilt would make yours a lot more versatile?
nice rake (and tractor) !
I am sure it would be a great upgrade but it's not in the budget. That is an expensive kit to purchase.
   / Cost of Woods gauge wheels for rake? #19
As with a lot of 3pt implements, hydraulic "TnT" has extreme advantages. As in that you can make constant adjustments vs with manual adjustments you tend to use one adjustment and call it good enough. Once you've had hydraulic top/tilt, you could not imagine working without it.
As far as a landscape rake, I suggest that you be sure to get one that will be strong enough to hold up to your tractor. I had bought a Mid West rake, thought that it would be fine, after all, it's only a rake. Well, I bent it after only a few times using it. So if you like throwing your $$$ away, buy cheap, otherwise buy what is right for your size tractor.
Just my opinions with what I have experienced. ;)
W can share a secret here in that the landscape rake is one of the most important pieces of equipment out there. It will even PLOW SNOW better than a blade. Beats me but it works.
Island Tractor--if you ever don't want them, sell me your Woods rake wheels.
I think I'm going to get the top 'n tilt setup. Sounds like a must-have
2013 International WorkStar 7400 Altec AM547 50ft. Bucket Truck (A55852)
2013 International...
2008 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A55745)
2008 DRAGON 150...
2022 Haybuster H1135 Tub Grinder (A55314)
2022 Haybuster...
Mohawk 12,000lb Two-Post Electric Auto Lift (A51691)
Mohawk 12,000lb...
2014 INTERNATIONAL DURASTAR 4300 26FT NON CDL BOX TRUCK (A56138)
2014 INTERNATIONAL...
