Tree spade
/ Tree spade #1
SCOTCHERS
Fallston , Maryland
PT-425
For those of you that know where these tree spades are in a specific tread, I've seen a few on the forums. JJ I'm interested in a couple pics you had under home made attachements etc.
Do you have any others or did you make them yourself? How much ball park for materials.
Any and all information would be great. I'm a landscaper and this would be an awesome attachment.
I'm looking for a tree scoop,scrub scoop etc like that of a tree spade
Any and all pics would be great or home made ones that have been made
I own a PT425 in the Maryland area.
/ Tree spade #2
I own a PT in the Maryland area.
I have a bunch of pictures. I will see if I can find them. Most of them are made with 3/8 steel. I just purchased a Case skidsteer with a lot of attachments, including a tree scoop, homemade .
I would suggest that if you have the capability and material, to build your own, to match the capability's of the 425. A good metal shop can roll or bend that 3/16, or 1/4 steel to your specifications. If you are going to so the straight sided scoops, just have them cut the metal and you do the welding. There is a bunch of them on Ebay. They are not cheap. The white scoop, is mounted on the end of a fork. The third picture has a concave front to better cut roots.
The cost is related to the kind and amount of steel used, plus the workmanship of yourself or someone else. You can figure $200.00 to $1000.00 on material and labor. If you can find used, that would be good.
I did make a light duty scoop out of a bladder type water tank, by cutting it to shape, and bolting it to one of my forks. You can find those tanks for free.
/ Tree spade #3
I wouldn't expect the PT-425 to have enough weight or grunt for a brute force tree spade. I notice that PT doesn't make a spade for any of their machines. Makes me wonder why not?
/ Tree spade #4
I wouldn't expect the PT-425 to have enough weight or grunt for a brute force tree spade. I notice the PT doesn't make a spade for any of their machines. Makes me wonder why not?
I believe that it could push a light weight blade in the ground. One of the PT owners pushed their forks in the ground deep enough and were able to lift the PT off the ground. Most of the scoops are pushed in the ground by shifting the front end around until it is at the depth they want.
/ Tree spade #5
Perhaps a small PT could push a tree spade in the sandy ground typical of Florida but I don't think my 1845 would be able to push one in the clay/shale soils on my property in Pennsylvania!
/ Tree spade #6
You'd be surprised at what a PT425 can push into the ground... here's the technique I used to bend the heck out of my forks....
Point the forks down at an angle under the stump or whatever you want to force out of the ground.
Push the joystick forward until the front tires come off the ground a couple inches.
Wiggle the joystick left and right rapidly and it works the forks into the ground pretty fast.
Repeat until the forks are buried and the quick attach plate is flush with the ground.
Then use the curl/dump action left and right in conjunctions with your foot pedals to drive the tractor back and forth and bounce around furiously until you realize there is some monster tap roots under the stump and you are never going to be able to pop out a stump that big with the PT425! :D
Extract the forks from the ground by reversing the order above and notice the nice arc you now have in one or both forks. TAA DAA!!! Success. You have bent your forks without cracking the cross tube on your FEL arms if you are lucky. :)
But seriously, the PT425 could push a tree spade UNDER something, but it does not have the weight or traction to push THROUGH something like large roots. You will bend, spindle and mutilate something trying to force it.
It will work on small trees and shrubs and will also do well for digging holes for transplanting.
/ Tree spade #7
Here is mine. something I built myself. The really cool ones are the skid steer versions with the hydraulic arms. Problem is they weigh too much for anything but maybe the 1445 or 1460 You need at least 3000lbs worth of lift. - 1500 lbs for the device, another 1500 for the tree and dirt.
My bucket works OK, In the summer the ground is too hard, in the winter, the ground is too heavy with water. Not the worst implement, but does not meet my expectations.
/ Tree spade #8
David,
I think there are at least two factors that come into play when thinking about the ability to use a tree spade on a small tractor like the PT425. First is soil condition--soils vary widely as I tried to point out in my previous post. Second is the size of the object you are trying to drive in the ground. The two pointed steel bars on a forklift drive into the ground much easier than a tree spade--just as a tree spade is easier to drive into ground than a regular bucket.
The mini-hoe for the PT is an 8 inch bucket with teeth and my experience is that it can be used in my areas of the clay/shale soils on my property but that it really can toss the 3500 lb 1845 around. I also find that it is not usable when I get into some of the harder shale areas on my property. All tree spades I have seen have a considerably larger contact with the ground than the 8 in bucket on the mini-hoe.
/ Tree spade #9
Bob,
I agree. I tried David's patent applied for stump removal technique once, and it was pretty clear that in my soils even the side roots weren't going anywhere. I've been dreaming of a diamond concrete saw to go after each root, or a hydraulic tree shear.
I probably just have to suck it up and rent the grinder and take them out. But I have a number of stumps on inclines that really are too steep for equipment. (Yes, Virginia, you can get the 1845 out on the 40 degree slope, but do you really want to be leveraging it around? Mowing is one thing, prying, pounding... I would opine is something else.)
All the best,
Peter
/ Tree spade #10
David,
I agree with you about soil type 100%. That is a major factor.
However, my forks are pretty blunt ended. The tree spades look to have a pointy tip and tend to be sharpened. I have an old tank laying around somewhere. Maybe I will mock up a small shovel over the winter and try it out. Won t cost me anything but time.
/ Tree spade #11
Carl, Did you make those bends in your tree spade, or have someone do it for you . Those guys at the metal fabrication shop can cut or bend or roll that metal in no time. All you do is give them the design and pay. Most of the time, you don't have to touch the metal until it is in your truck all cut and bent. I have a shop press, but can only bend small stuff. Straight cuts work better for me. . Just tack and weld.
On the 425 capability, I think if you down size the tree spade it will do a credible job. A sharp pointed spade might slip to the side of a root. whereas a concave one might cut through the root. 1/4 in thick might work. The spade that I just purchased is designed for a skidsteer, and weighs about 275 lbs. 3/8 steel.
/ Tree spade #12
Oh, yeah. I had it bent. I have NO skill with metal. Still learning. I took my plans to the metal shop, said I wanted to practice welding. They looked at the plans and asked why I had the bucket being made in multiple peices and not one peice bent. I asked how much, I think they said another $20 or so...
I do want to get a plasma cutter, and a mig (I have stick which is fine for ugly stuff).
Carl
/ Tree spade #13
David,
I just dug 9 post holes 4' deep through shale and clay layers, mainly shale using the 12" bucket on my Lackender 6' minihoe with my PT1850. The land had been previously scraped down to shale. I was quite impressed with how well it did. I had to make the holes longer than i would have liked in order to get through the shale but it only took 45 minutes per hole which i thought was quite reasonable given the conditions. By hand, it would have been a day per hole easy.
Ken
/ Tree spade #14
Have you seen this machine? It looks neat. Has me wondering for I am expecting to need a method in a few years to dig trees.
Know a little about the TP rig and my thought may be way off, if you could come up with a vibrating action to the tree spade would it not cut the roots better? So how to get that vibration? I know there are trenchers used to put down cables that have such and wondered today if there is any other option to operate a home made blade like on this unit. Can you buy vibration attachments or would you have to make such? Realize this is very crude but even wonder if you added a hyd motor with a out of round weight to the cutter if that would help. To operate a blade like this thought about hyd impact wrench. I have never used one but would assume it gives blows as does an air impact wrench. Hey mounting a hyd motor to the cutter with an unbalanced weight and it's normally shaking action from that might give a bucket enough action to help slice through the roots.
native plants,oregon plants,ashland natives,nursery stock,holmac treedigger,plant oregon,wildlife gardening, bio-remediation,bird habitat,bonsai maples,landscaping trees,siskiyou bio-region,rootpruner,riparian restoration, rogue ecosystems,treespade
/ Tree spade #15
Wow! That looks like a very specialized and expensive piece of equipment. The digger moves left right, up down, in out and the tracks even move wider or narrower and the whole unit weight shifts forward and backward on the tracks. I'll bet it's 50K or higher! :)
As for a tree spade on a PT, remember, the 400 series can only lift 800 pounds at the quick attach plate. You hang a 300 pound attachment out there a few feet in front of the quick attach plate and you will only be lifting root balls that are 2' across and a foot deep MAYBE in wet or heavy soil. The larger units have more lift, of course.
I think a tree spade on it's own wheels that is just transported, positioned and powered by the PT would be a better choice for small units. Something like the Vermeer TS-44A comes to mind. Find something like this with a blown engine and you are set to go.
Vermeer TS-44A
/ Tree spade #16
Vermeer TS-44A
Moss, that Vermeer weighs 5390 lbs. A 400 series machine could not tow or position it properly, certainly not safely, even on level ground. It will extract an 1100 plus lb tree from the ground. I hate to think what could happen with the tongue end held down by only a 1400 lb or less PT, even with the moment arm advantage.
I think another solution is in order.
/ Tree spade #17
I would second your comments. MR the vermer is a neat attachment, but probably not up to even the red tractors. I had some sphincter moments moving a vermer powered chipper around on an incline, where it started pushing the PT.
Sometimes you have to learn to live within the limits. The PT spade is never going to dig up 1T balls, but it is probably OK to dig up bushes.
All the best,
Peter
/ Tree spade #18
All the best,
Peter
I think you also must consider soil conditions. In "sand-country" where JJ lives, for example, a tree-spade may work OK. However in hills of East Tennessee, you typically are dealing with issues like clay soil, perhaps slate rock or limestone underneath it, or if you have good, loamy topsoil, it often has glacial, rounded, "mountain stone" mixed throughout...
In a nutshell, based on my experience in using the minihoe with a 9" bucket, I question how deep a light-weight PT can push any kind of cutting blade into the ground... it's all too easy to lift the front of the PT off the ground just trying to push the 9" bucket into the ground -- it must be done with curl most of the time, and not with down-pressure.
I think a tree-spade would have very limited value for me, though I am considering cutting down my now-unused HD rock bucket to make more of a "grubbing bucket shape" for use in making/clearing ditches faster than I can with the mini-hoe. I have no illusions of being able to use it as a tree-spade however, unless the soil conditions (dampness, compaction, etc.) are almost perfect...
/ Tree spade #19
In reference to post # 2.
I see no reason why you can not build one similar to the ones in the pictures shown, on a cut down version. We are only talking about the depth of tree roots. The cost is not that much to build, I am sure that you have a bucket, and they make a tree spade or digger that bolts on the front of the bucket.
No matter what the situation, you may run into obstacles, the goal is to get the job done using whatever is available. If you run into rocks, and you can not go around, bust them up, dig them out, or whatever it takes. I would say go ahead and build it, use it, and report back on it's usefulness. There are several ways to do things, the right way, your way, and whatever.
/ Tree spade #20
Yeah, I didn't look at the weights and all, but you guys understand the theory behind it at least. A small PT can only lift 800 pounds. A small root ball can weigh that much. But if you had some sort of attachment that could get it out of the ground and support the weight, the PT could move it around. Smaller attachments for smaller tractors, bigger for bigger, etc..
AUCTION STARTS HERE @ 9AM (A62129)
AUCTION STARTS...
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A61307)
2020 Takeuchi...
2012 International Prostar (A61307)
2012 International...
2019 KENWORTH T800 (A60736)
2019 KENWORTH T800...
TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET FOR...
2019 CUSHMAN HAULER PRO ELECTRIC GOLF CART (A58375)
2019 CUSHMAN...
