47" blower mod to change discharge shute angle
   / 47" blower mod to change discharge shute angle #1
acs55812
Duluth, MN
I thought I saw a thread awhile back with a cable type setup to change the angle of the top of the discharge chute, (distance snow is thrown away from tractor---not the left/right angle)----but I have searched with every term I can think of and can't find it.
Can anyone steer me in the right direction?
Thanks
Dan
opps cant edit misspelled title :(
   / 47" blower mod to change discharge shute angle #4
Just a thought, but--
With proper leverage, would a fellow not be able to use a car parking brake cable? in a push-pull manner like used on the walk behind blowers?
Have toyed with this idea and might just try it myself except that in my case snow placement is not critical I just 'blow wide open'.
   / 47" blower mod to change discharge shute angle #5
I have the factory kit that was over a hundred bucks. When I put it together I found that I could have made a couple of brackets and bought a tow truck pto cable for less then half of what I paid..
   / 47" blower mod to change discharge shute angle #6
Pretty well what I thought of doing(see above post).
But then how does it work? do the job?
   / 47" blower mod to change discharge shute angle #7
Piloon,
Search "Chute Deflector" and you will get all the information you need....lots of variations of electric and hydraulic deflectors. Dyer, retired
   / 47" blower mod to change discharge shute angle #8
Thanks
Dan
Yep, John Deere sells a kit specific to your tractor its called a chute deflector kit I have it on my front mounted 47" snow blower and also had it on my previous one. It cost about $125 dollars. but well worth it. Hope this helps.
2003 HYSTER H55VM STRAIGHT MAST FORKLIFT (A51406)
2003 HYSTER H55VM...
202479 (A54757)
202479 (A54757)
2021 CATERPILLAR CB2.7 DBL DRUM TANDEM ROLLER (A52705)
2021 CATERPILLAR...
PROPARTS 82" ULTRA SERIES (A54756)
PROPARTS 82" ULTRA...
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATES (A54757)
UNUSED LANDHONOR...
2012 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Versalift SST40 Boom (A55302)
2012 RAM 5500...
