Needed an easy way to pull fence posts
/ Needed an easy way to pull fence posts #1
PineRidge
Super Member
Northeast, Ohio
LS-MT242HC
Thought this might be interesting to other members that need a way to easily pull fence posts or the like.
Over the past summer I installed my share of fencing. In the process of finishing a homeowners yard that had just installed an in-ground pool and an ornamental aluminum fence a landscapers Bob-Cat operator got a little to close to and damaged the fence that I had just installed.
As a result it was up to me to make the repair. As it turns out the day that I picked for the repair was high humidity and over 90 degrees in temperature. I had to manually dig out an aluminum fence post that had been set in 120 pounds of concrete. As I dug that hole using a shovel and spud bar I decided right then that I was going to come up with an easier solution for the next repair.
After searching the Internet I found several variations of jacks that claimed to easily pull fence posts with concrete plugs still attached. The jacks sold for upward of $600.00 :eek:
The picture was my 1st attempt at a solution and used a farm jack that I had previously purchased from Harbor Freight, an old 3-point frame, and a set of wheels that came off an old chipper. It worked fair, but proved to be way to flimsy for pulling posts set in concrete.
I quickly learned that keeping the center of gravity as low as possible is a big advantage. The final design uses a hydraulic cylinder purchased from Harbor Freight and rated at 8 tons.
I used a hook on the lift arm so that a chain could be used to help pull the posts. I have used this jack and it is much smoother in operation. I have used it to pull 6 X 6 posts set in concrete without problems.
The main support post is 2" X 2" X 1/4" steel. It is made to come apart just under the point where the pivot arm attach駸 to it. Disassembling the jack makes it easy to load in the van or trailer without taking up to much space.
When pulling a post there is no weight put on the wheels which is a plus. Once the post has been pulled the jack can be tilted back and used as a dolly to transport the post.
I took an old pallet puller and did a little welding on it so that it could be used in conjunction with the jack. If a fence post is rotted or broken off at ground level the puller can be used to pull the concrete plug so you don't have to manually dig it out. My back is still thanking me for making this gadget.:D
The original pallet puller looked like the picture on the right.
Thanks for the complement Bird!
/ Needed an easy way to pull fence posts #6
You have a TC-40, did you try the loader and chain to lift them out? If no loader, consider the 3 pt. Place a drawbar between the lift links, lower the 3pt to the ground, attach chain and lift. It takes a tough post not to come out of the ground with a 3 pt. Most 3 pts will lift more than the tractor loader. Most 3 pts are rated to lift 24" behind the lift arms. This method puts the lifting power right at the lift arms and will lift significantly more than the rated lift. You can also use the tractor to move the post forward and back while you lift to loosen the post. Simple method-if you have a tractor and can get the tractor to the post.
If that doesn't work, get a bigger tractor. Our biggest tractor 3 pt can lift 18,900 lbs 24" back on the 3 pt.:D
I have no way to get my tractor to the job-site. My van isn't powerful enough to pull it and as a result I never purchased a trailer. The jack can be taken anywhere and is a LOT cheaper. :rolleyes:
/ Needed an easy way to pull fence posts #8
If you can't get the tractor to the post, then your invention should work just fine. The jack should give plenty of lift, just takes a little time. The portability of your jack is great. Good job making do with what you have!
/ Needed an easy way to pull fence posts #9
It is said, "Necessity is the mother of invention". Add to that the desire to avoid backache and sore muscles and you have a winning combination.
You are a winner Pineridge! You found that combination. Great job!
/ Needed an easy way to pull fence posts #10
In my quite recent BT days (before tractor) I've used an old steel wheel (the bigger, the better) and my truck to pull out posts. Wrap a strap or chain (I prefer strap in case something slips) around the post as low as possible. Run the strap over the top of an old wheel standing on edge like it would if it were on a vehicle, then attach the other end to the truck and slowly pull.
The wheel acts as a redirect changing the horizontal motion of the the pulling truck to a vertical motion. The larger the wheel, the more vertical lift you can acheive. You may have to reposition the strap further down the post once it starts lifting if the wheel is small or the post is deep.
As always, be careful when pulling as there is always the danger of something letting go all at once. That's why I prefer a strap to a chain. If it slips or breaks, there's far less of a chance of damage or injury.
/ Needed an easy way to pull fence posts #11
I once used the snow plow lift cylinder that was mounted on my pickup to pull out 4 x 4 posts that were 3 ft deep and set in concrete.
It would lift about 12" per cycle lift using chain that I would do a double wrap around the pole. Fortunately I had easy vehicle access. Two lift cycles and I'd back off dragging the post/concrete mess each time.
Recalled that we pulled out some 10 posts in about all of 30 mins.
Now loading the concrete mess into the pickup was another story as that was BTD (before tractor days), sure was heavy and hard to manage.
/ Needed an easy way to pull fence posts #12
Hi PR, and Merry Christmas!
Pretty sweet looking post puller you designed. I bet you could even pull a few saplings growing in the fence line.
I'm wondering, because of the distance from the hook to the shaft, does the slide ever get into a bind? I guess if it did, you could grease it.
Hi Bob, Merry Christmas to you also!
I'm not shure what you mean by slide? The piston has never jammed as of yet.
Piloon that an idea that I hadn't even thought of and a good one at that! I don't have a plow like you do but if I did could have saved making the jack.
/ Needed an easy way to pull fence posts #15
I had forgotton about that old classic method. I have heard of people using old, larger diameter truck rims and run the chain over the rim and then drive forward and lift out the post.
/ Needed an easy way to pull fence posts #16
While I've never done this with T posts, I've found that a bottle jack works great at getting post out of the ground. I have a 20 ton bottle jack that I keep in my truck tool box that will take out any sized post set in concrete, and a small 2 ton bottle jack that I've only used a few times, but it also worked.
The trick to using a bottle jack is attaching something to the post. I usually screw a piece of wood onto the side of a wood post and then jack it up from underneath. For pipes in the ground where I have to take the pipe and cement out, I cut a hole in the pipe with my torch and slide another pipe through the hole. Then put the jack under the pipe and up it comes.
I've never had to jack a post more then just a few inches to get it to break free. Then I can wiggle and work it out by hand.
For T posts, I'd think that a V shaped piece of steel welded onto a Pipe Coupling would probably work great. It would be light weight, easy to store and carry around, and easily have enough power to get a T post out of the ground. Just slide the V notch over the bumps on the side of the post and start jacking. Once it breaks free, it should come out by hand real easy.
With all the rain and moisture in the air, I might just build one. Can't do anything else outside right now. LOL
Eddie
Eddie
Eddie some of the best ideas are the simple ones. Make that gadget that you're talking about and get a few investors together to market it. Eddie = $$$$$$
/ Needed an easy way to pull fence posts #19
I may be looking at it wrong. I was thinking the horizontal bar with the chain hook on it travelled upward when you jack it.
Bob that bar is attached at a pivot point to the main support. The cylinder merely drives the arm upward it's really a pretty simple design.
My wife said the jack reminds her of me, simple. :D
2015 Kubota ZD1211RL 74in Zero Turn Mower (A64553)
2015 Kubota...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
1986 Trailmobile F71T-6UJA 40ft. 32 Ton T/A Flatbed Trailer (A64194)
1986 Trailmobile...
East Texas Gooseneck Trailer (A65563)
East Texas...
Manure spreader for sale / Excellent Condition / Make offer
Manure spreader...
2009 PALFINGER 11 FT SERVICE BODY (A62613)
2009 PALFINGER 11...
