From Satoh to Mitsubishi, evolution
   / From Satoh to Mitsubishi, evolution #1
Phil24
Hi everyone,
A few pictures to show how the small Satoh tractors for the Japanese markets, much alike the US 'Beaver' models, became Mitsubishi models after 1980.
These pics come from adverts on the Net (apart those showing my own St 1510D), I hope their authors won't complain about my using them.
Please react in order to complete this attempt.
PHIL24
Satoh ST1510D as imported from Japan
Mitsubishi D1500V: apparently totally similar, rebadged
Mitsubishi D1500V: new wheel rims & fenders
Satoh ST1510D
Mitsubishi MT372: openings in hood, hour meter on dash, modified grille+headlights surround+hood end
   / From Satoh to Mitsubishi, evolution #2
   / From Satoh to Mitsubishi, evolution #3
wushaw, I did the same seat mod to my S650G.
You sit a little higher lol :D
   / From Satoh to Mitsubishi, evolution #4
Yes and it didn't take me long to get used to it especially after I found out I could get more seat time without it killing my seat;)
   / From Satoh to Mitsubishi, evolution #5
hi phil
That's my Satoh ST-1510D tractor and Mitsubishi tiller you have there! That is, it's identical to mine to look at. I bought mine second hand from my next door neighbor recently for $1500 with slasher and carry-all and tiller. Chasing a manual at the moment; seems if they were re-badged Mitsubishi they used different model numbers. In the meantime can you help me...a dumb question I know but...can I use normal car engine oil in this little diesel tractor; and does the oil go in the oil level indicator inlet (ie where the level is shown on the dipstick).
Sorry for such simple questions' I'll try to ask smarter ones next time. Hope the aussie lingo doesn't confuse you.
By the way, the tractor's a little ripper!
Jamie
   / From Satoh to Mitsubishi, evolution #6
You need to use a diesel oil.
   / From Satoh to Mitsubishi, evolution #7
Jamie
Welcome to TBN Jamie, :)
Like Leonard said "You need to use a diesel oil. "
The oil used in diesel engines is API rated "C" as in CD or CF etc..gas engines have a API "S" rating : SL or SM etc. Some motor oils are rated for both gas and diesel engines..here's a more complete explaination I found on a car forum...Oil labelling explained: Motoring Technical matters forum
As to where the oil fill is located on your tractor..I'm not familiar with your model..hopefully someone else can help...
I would make a suggestion that you start a new thread in this forum with the heading " help with info Satoh ST-1510D " ..a member with a similar tractor will be more likely to check it out...also getting a repair manual will be a big help .
Good luck....
Good luck
2018 Deere 323E (A53317)
2018 Deere 323E...
RING 2 STARTS HERE @ 9:15 AM (A60430)
RING 2 STARTS HERE...
UNUSED FUTURE FT-ZDQ160 110V CONCRETE VIBRATOR (A60432)
UNUSED FUTURE...
10,000 PSI AIR HYDRAULIC PUMP (A58214)
10,000 PSI AIR...
UNUSED FUTURE SB45 EXCAVATOR HYD SILENT BREAKER (A60432)
UNUSED FUTURE SB45...
10 X6 MANIFOLD (A58214)
10 X6 MANIFOLD...
