Hydraulic problem
/ Hydraulic problem #1
Knight
CT
Kubota L3400
I just completed my grapple install. I used a 12 volt solenoid open center, spring centering valve mounted on a DO3 sub-plate. The grapple drifts rapidly down as soon as power is removed. If I quick disconnect the cylinder, you cannot move the grapple, so I would say cylinder is fine. Could air in the system cause this? I tried to cycle the cylinder a few times to remove air. Does it sound like a bad electric valve.( maybe dirt)
Is there something I am missing?
/ Hydraulic problem #2
Welcome to TBN:D
Can you provide a link and/or a part number for the valve you used? I suspect it's a motor control valve and the work ports are not "blocked in neutral"
/ Hydraulic problem
Thank you for the welcome. Maybe I selected the wrong valve. There is another valve that is similar. Here is the link to the valve.
Northman Fluid Power Hydraulic Directional Control Valve 16.8 GPM, 4500 PSI, 3-Position, Double Solenoid, Open Center Spool, 12 Volt DC Solenoids, Model# SWH-G02-C3-D12-10
Power Solenoid | Valves | Hydraulics | Northern Tool + Equipment
/ Hydraulic problem #4
OK, here is direct link to that valve: CLICK HERE
From the description:
As a spring-centered valve, it will remain in its home position with all-ports commonly connected until shifted electrically to one of two positions to either extend or retract a cylinder, returning to home when the power is removed.
This is the wrong valve. You need the work ports blocked in neutral, and these are open thus letting the fluid escape the cylinder. This valve would be used for a motor but their description is sure misleading saying it can used for DA cylinders.
Edit at 4:33 EST in case you read my reply! I linked a closed center valve!
I actually can't find one on the N T&E site that looks like the right one, I looked at them all!
Take a look at THIS valve from the Surplus Center, notice the "work ports blocked in neutral" in the description-that is what you need.
/ Hydraulic problem
kennyd
You have been a huge help to me. Thank you and have a Merry Christmas!
I will post a picture of my grapple soon. It is different in the way it stays on the loader arms and not the bucket. It can be used with forks or bucket.
/ Hydraulic problem #6
Your welcome:eek:
Please do post pictures of that grapple, it sounds very interesting!
/ Hydraulic problem #8
I am not 100% sure-it never says the work ports are blocked. Maybe you could check with the manufacturer?
Can you just return the one you have and get the one I linked? You already have the DO3 plate plumbed so the swap will be easy...
/ Hydraulic problem
I called Northman today. This is what they recommended. I like the way electrical connects. It looks cleaner than hirshman connectors. We'll see when it arrives.
c6 has a diagram, but I don't know how to read it completely.
http://www.northmanfp.com/pdf/DCVSpools.pdf
What does Tandem center mean?
TANDEM CENTER VALVES
Tandem center valves when in a neutral position by passes the flow of hydraulic oil to the return line. This is used to hold the cylinder/piston in position with no load on the pumps. When this system is the pump is running constantly to keep a ready supply of hydraulic oil, but as long as the cylinder/piston is not in operation the pump is working under no pressure or load. This system keeps wear and tear on the pump down to a minimum.
OPEN CENTER VALVES
Open center valves are the same as the tandem center, except that in the neutral position all lines are connected back to the reservoir. The primary use of this system is to prevent "shock" loading when the valve is placed in neutral. This takes pressure off the motor. This system is used in situations where the operating device needs to be moved by hand.
/ Hydraulic problem #10
Excellent! Please don't forget those pictures:D
/ Hydraulic problem #11
I used a similar looking Hyvair valve when doing my first installation on my Kama.
I used the Surplus Center Vickers valve when doing my wife's installation because it was a lot cheaper (at the time) and does the same thing as the Hyvair valve but requires the Hirshman connectors like you said. I see that Norhtman valve is just like my Hyvair valve and would have used it if I knew about it.
That's a very good price for that valve.
/ Hydraulic problem
I don't understand the difference....tandem or open???
What concerns me is ........what happens when I operate this electric cylinder, will I still be able to move a down stream cylinder. Will P and T still be open when this valve is moved?
/ Hydraulic problem #13
It IS very confusing...
I just copied this from a google search of "tanden center hydraulic valve":
OPEN CENTER VALVES
CLOSED CENTER VALVES
This type of valve is used in a hydraulic system where the valve blocks the flow of oil from the pump into an accumulator. The accumulator (see below) is used to store the oil under pressure. This valve takes the pressure off the pump and in neutral locks the cylinder in place with no load on the pump.
So to me it appears to be different terminology for the same thing...Tandem Center is what you want by this description.
Yes, it will be fine because your cylinder cannot take the full flow of the pressure port, so the rest will flow through.
/ Hydraulic problem
Somewhere along the way I picked up the term "open center" as opposed to some other machines having "closed center" valves and decided this is what I needed...live and learn.
I also found a good explanation here.
CHAPTER 10: Directional Control Valves, part 3
Thanks for the help.....back to installing Christmas lights before my wife catches me
/ Hydraulic problem #15
I learned something new also:D...
I have been using the term "open center" also for years while recommending valves, I guess the "proper" term is "tandem center"
UNUSED SDLANCH SDLGC80 ELECTRIC GOLF CART (A62130)
UNUSED SDLANCH...
UNUSED IRANCH MINI SEMI-AUTOMATIC QUICK CHANGER (A62131)
UNUSED IRANCH MINI...
2020 INTERNATIONAL LT625 48" SLEEPER (A62613)
2020 INTERNATIONAL...
UNUSED KUBOTA B2366 PIN ON QUICK ATTACH (A62130)
UNUSED KUBOTA...
New/Unused Pallet of 5 Binders and 10 Chains (A61166)
New/Unused Pallet...
UNUSED PAIR OF 76" SLIP ON FORK EXTENSIONS (A62131)
UNUSED PAIR OF 76"...
