break caliper bolt - how to secure it
/ break caliper bolt - how to secure it #1
RancherSam
Hays County, TX
Case IH JX95 4x4
Hello everyone,
I recently changed the ball joints on my srw 2004 f350 diesel. Recently I found out that the rather sizable bolt that holds the brake unit in place came out ( this is the 2in by 1/2in bolt ). We had torqued it to 150 ft lbs but apparently that wasn't enough ( btw this is not the bolt that holds the brake pads - that one was fine ). I don't think I will be undoing this again anytime soon so I need it to stay! What do you all recommend I do in addition to torquing it again to 150.
/ break caliper bolt - how to secure it #2
loctite 262
you'll have to heat it to get it loose next time around
/ break caliper bolt - how to secure it #4
Loctite is what is used in that application due to the vibrations.
/ break caliper bolt - how to secure it #5
Hello everyone,
With all due respect , a 2X1/2" bolt tightened to 150* will take a bit to undo again . Are you certain it was not overlooked on assembly ?
/ break caliper bolt - how to secure it #6
Loctite. Mine '99 had factory Loctite on those bolts.
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63689)
2017 Cadillac...
2019 INTERNATIONAL LT625 T/A 6X4 SLEEPER TRUCK TRACTOR (A59912)
2019 INTERNATIONAL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2016 CASE TR340 Track Loader (A63111)
2016 CASE TR340...
2017 Ford F-350 Flatbed Dump Truck (A61573)
2017 Ford F-350...
Kivel Quick Hitch Mini Skid Steer Attachment (A61572)
Kivel Quick Hitch...
