955 transmission leak
/ 955 transmission leak #1
geggle
My hydrostatic transmission is leaking at the seal where the rocker shaft enters the housing (actuated by the forward/reverse pedals) Anyone have experience with this. What do I need to do to fix it? Does the whole thing need to come out? It looks like it.
Or should I leave this to the dealer mechanics at God only know what cost.
/ 955 transmission leak #2
I would say it depends on how bad it's leaking. I know on my 755 that the area is wet, but it doesn't dip. If you're is wet I'd say leave it alone, but if you're leaving a trail of oil behind when you drive the tractor you probably should get it looked at.
I took a quick look at jpparts and there is a seal and a trunnion you could replace pretty easy by the looks of it.
Jason
/ 955 transmission leak #3
Did you fix it yourself or have a dealer do it? My started leaking today in the same spot.
2010 Dodge Charger Sedan (A61569)
2010 Dodge Charger...
DRAGON 500 BBL FRAC TANK (A58214)
DRAGON 500 BBL...
30 Yard Dumper (A61166)
30 Yard Dumper...
120 GALLON WATER TANK (A62131)
120 GALLON WATER...
UNUSED RAYTREE RMA42 HYD AUGER (A62131)
UNUSED RAYTREE...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63118)
2023 Unverferth...
