Jinma 284LE won't turn over
/ Jinma 284LE won't turn over
Shop said the starter drive assembly is bad. I ordered one so hopefully this will be it.
Mark H
/ Jinma 284LE won't turn over #82
Wait, now you really lost me now. Is this the same shop that just charged you $60 to "rebuild" the **** thing?
//greg//
/ Jinma 284LE won't turn over #83
Fix was premature. The starter will not engage every time and just spins. . And yes all connections are clean.
Mark H
Starter drive could / can cause that.
Ronald
Ranch Hand Supply
Yes it's the same shop. I had to plow some snow so I used the tractor. The solenoid pin came off and he said that may have damaged the starter drive assembly. The clip on top of the spring on the solenoid was missing when he took it apart. He said the shaft was a little loose and the clutch in the starter drive assembly may be damaged but wouldn't be able to tell until I put it back on the tractor.
Mark H
Got the starter drive assembly in and that took care of the problem.
This is my first utility tractor, I had a garden tractor before. I thought it was normal that the engine didn't turn over as fast a car,truck etc., because of the higher compression. Now it does turn over that fast, which is much faster than when it was new. As I stated in an earlier post this was after the first time I had the starter in and rebuilt.
Thanks to everyone for your help and suggestions.
Mark H
/ Jinma 284LE won't turn over #87
Mark H
You done real good Mark :cool: you have my respect for doing so much of this yourself, not that I'd want my customers doing the same,..:D
/ Jinma 284LE won't turn over #88
since this thread is about starters from china i have a question:
i have a nortrac tractor 25hp the starters keep going on me and they cost $200. is there another company or other starters that i can match up the code on the starter is as follows:
Wuyue qd100c3
seriel # 07128078
any help would be greatly appricieated
gregg
/ Jinma 284LE won't turn over #89
Starters should not "keep going on" you. Yes, they do go bad, but not one after another. That indicates some other problem underlying this issue.
Do you have adequate gauge wire going to the starter solenoid? Undersized wire would cause low voltage and that could prevent the solenoid from fully engaging, damaging the gears. If the starter is misaligned with the flywheel it could cause binding and wear out a starter more quickly. Undersized wire from the battery to the starter motor could cause low voltage and cause the motor to heat up.
Jinma, who makes the Nortrac tractors, has come out with a new design starter with compound gearing that is more efficient and more powerful. You might want to see if one of the new ones will work as a replacement for the original. Those who have used them think they're great.
I'd suggest you contact Tommy at Affordable Tractor Sales for advice and to see if the new-style starter will work for you.
Rich
2021 FORD F-150 STX CREW CAB TRUCK (A59823)
2021 FORD F-150...
2008 Ford Escape XLS SUV (A59231)
2008 Ford Escape...
2020 INTERNATIONAL LT625 SLEEPER (A59905)
2020 INTERNATIONAL...
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A55853)
2004 Pierce Tilt...
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
2022 FORD F-250 STV CREW CAB TRUCK (A59823)
2022 FORD F-250...
