New L3400
/ New L3400 #1
redsmoke641
Abilene, KS
2008 Kubota L3400HST, LA463fel
Hi all, I was formerly on here as Redsmoke (dissatisfied JD 4300 owner). I just traded that nightmare for a Kubota L3400HST and I am a happy man. Only have 10 hrs. on it moving sand, box blading, and rototilling. No issues at all. I have all the equipment for it, although reading this forum has made me start thinking about a grapple.
/ New L3400 #2
Nice looking rig you've got there! Welcome back.
/ New L3400 #3
You'll get many, many years of hard work out of it. Nice tractor and good luck.
/ New L3400 #4
Just picked up a 3400 HST myself. Great machine- hope you enjoy it!
/ New L3400 #5
Just curious. How smooth is the 3ph on your tractors?
/ New L3400
It's not silky smooth, but I probably wouldn't have noticed anything wrong if I hadn't seen all the posts about the jerky 3-point. (That's not to say that the problem doesn't exist). From bottom to top, it goes up smooth. It hops a little when I raise it in increments, but I like it when I'm box blading because I have a better feel for where my blade is at. Does that make sense? Only have 10 hrs. on it and I am lovin it. The JD4300 I had was the tractor from ****, but most of them out there are good tractors. So, just because I like my tractor, I'm sure there some of the same that are nightmares. I hope anyone who is having problems is able to get them resolved.
/ New L3400
Yes, I adjusted the 3-point lowering speed and it works just fine.
/ New L3400 #9
I would have to say the same thing. We got our 3400 this summer & still only have 30hrs on it, but I haven't felt like the 3PT hitch was overly jerky. I DID notice it being jerky recently with just a drawbar on it when I was moving a trailer but with any weight on it, it works fine.
/ New L3400 #10
Most people will not notice anything wrong with the jerky 3ph, in fact, it's great for getting dirt off a post hole digger. One of my problems with the jerky 3ph was trying to removing heavy objects out of a trailer with a boom pole. Bouncing the tractor around was one thing, but banging up my trailer was another... :mad: It was unsafe for anyone to try and steady the load on the boom pole as it swung wildly.
If you don't use a box blade much, you will not notice it either but I've put in a couple of roads on my property and you need to make fine adjustments with the box blade to do it right... before I got my valves replaced, I ended up using a friends tractor, early 90's? L2050DT... since it was much better then my brand new tractor.
For mixing up chemicals in my sprayer... I sure do miss the old valves. :rolleyes:
78in. Skid Steer Bucket (A65640)
78in. Skid Steer...
1999 Van Hool Transit Bus T2100 Bus, VIN # YE2TC63B3X2043319 (A65563)
1999 Van Hool...
2012 PETERBILT 386 (A65643)
2012 PETERBILT 386...
2023 Takeuchi TL6R Compact Track Loader Skid Steer w Low Hours (A63689)
2023 Takeuchi TL6R...
2020 KOMATSU D65EX-18 CRAWLER DOZER (A65053)
2020 KOMATSU...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
