BX2200 Heater Installation
/ BX2200 Heater Installation
Excellent.
Just got the first chance to try mine out....had to turn it off half the time cause it was too hot :)
I'm thinking we will have a very mild winter because of our heaters....that's fine too :)
JohnnyB
/ BX2200 Heater Installation #33
FYI the BX 2200 bypass line hose is 3/8" not 1/2". I put a T in the 3/8" line and then ran one hose to the heater with the other hose in a T in the top radiator hose. I already had the T installed in the radiator hose and the other line above the thermostat. I did not get heat unless I really worked the tractor with this set up. I hope this set up works better. I could not finish the install I am waiting for NAPA to get a 3/8" to 1/2" adapter to fit the 1/2" to 5/8" adapter to the heater hose. I hope to finish the job on Saturday.:D
/ BX2200 Heater Installation #34
TOM,
Am i understanding correctly,you have one hooked to the bypass hose and one in a radiator line?Did you install a shutoff in the small line that you teed?If you need one i can send you mine.Iguess there are multiple ways of hooking it up,iused just the bypass line,dataway used the lower radiator hose ,and put a fitting in the thermostat.You could use both large radiator hoses too i suppose.Iknow you have had the cab for a few winters now,you didnt have heat?Mabey i do recall an electric one?
ALAN
/ BX2200 Heater Installation #35
Alan,
I had heat but not great heat, it was warm but not hot unless I really worked the BX to get the temperature up. I have a shut off valve, thanks for the offer. I have an extra T for the lower radiator hose but never used it, it looked too tight to fit it into hose so I never installed it. I never thought of using the bypass hose until I read your post. So after 3 seasons perhaps I will have too much heat in the cab.:D By the way your cab project has been interesting reading, I admirer your craftsmanship. What is next on your list???
/ BX2200 Heater Installation #36
Alan,
Tom ,i had a tire sent out for repair when it gets back tommorow im gonna take pics and post about my chute control setup utilizing the power and beyond that runs my hoe.KENNY D helped me on that one ,hes one smart cookie.Then after that im gonna show you guys my cab it is really awsome for a homemade job.By the way on mytractorforum.com Ihave the complete makings of my cab if your interested in viewing .Icouldnt get on TBN last winter because of a computer clitch ,so i started the thread there.Good bunch of guys,just more bota guys here and much more posting.
Next big project for the bota??Log arch to haul my firewood out.Already got the axle.Gonna take a break for a bit and enjoy the cab and blower,and of course my snowmobiling.
Hey i wonder if you can get a hotter thermostat for the bota?
ALAN
/ BX2200 Heater Installation #38
Not to resurrect an old thread, but.....
I got tired of eating twice-blown snow, so I got the local Massey dealer to install a cab on the GC2310 and hydraulic chute rotator on the Puma. Found a heater on eBay, it's either the Maradyne 5000 or a clone. The day the tractor was ready, the heater came in the mail.
I spent a cold Sunday morning plumbing the heater up. I plumbed in to the water pump/thermostat bypass loop. On the little Iseki engine a 3/8 hose fit loosely, but 5/16 fit perfect. Some brass barb fittings and a couple of brass 1/2" threaded couplers, and I had it adapted up to the 5/8 pipes on the heater.
It was a hurry-up job just to get it working before the storm, and is not in it's final form. I'm going to add a diverter valve and tee so I can shut off the flow to the heater in the Summer, and I have to wire up a SPDT toggle for the two speed fan.
It doesn't throw massive heat, but it certainly keeps the cab warm. I think the 5/16 hose might be too small for massive heat, although, grabbing the brass fittings to check for temp shows it's plenty hot.
My opinion is that the bypass is the best spot to plumb in to for a heater. Any and all heat the engine puts into the coolant goes through that bypass until such time as the thermostat opens, and the flow through there stays hot after that. Plumbing into the radiator hoses can delay heat until the thermostat opens, not my idea of fun.
/ BX2200 Heater Installation #39
JMYNES,
I agree the by pass works good .Im simply gonna re install my bypass line this spring and hook the hoses togeather.Might lose an ounce of antifreeze tops,and will save on alot of extra stuff under the hood.
The one thing i did notice,is if i idle the tractor,the heater dont put out the masses of heat ,that it does at operating speed.Iwonder if a car thermostat will fit ,if so id like to get a hotter one. .
What part of the state are you from? My winter home is near FARMINGTON,im closer to RANGELY in the summer.
ALAN
/ BX2200 Heater Installation #40
Escavader,
Greetings, neighbor! I live in Auburn, only about an hour away.
I've noticed the decreased heat at idle too. I've always been taught that combustion temps in a diesel are higher than a gasser, but it seems that gas burning engines warm up quicker. I guess a good portion of the heat is going out the exhaust, rather than into the coolant.
Covering up about half the radiator with cardboard might be easier than trying to find a different thermostat. I think I would want some kind of temp gauge rather than waiting for the idiot light to come on.
2018 Ford F-250 Service Truck, VIN # 1FD7X2A60JEB74871 (A61165)
2018 Ford F-250...
KJ K0720 7'x20' Metal Gate (Deep) (A60463)
KJ K0720 7'x20'...
Case skid steer wheels and tires (A61307)
Case skid steer...
2011 John Deere 5085 70HP Utility Tractor (A60352)
2011 John Deere...
SKIDDED FRAC TANK (A60736)
SKIDDED FRAC TANK...
PALLET OF 12IRON GATES (A58214)
PALLET OF 12IRON...
