2544 4X4 or locker rear end dually
   / 2544 4X4 or locker rear end dually #1
evan4434
Iowa
Cub Cadet 3184
I have a 2544 and was wondering if anyone knows how to add 4X4, or add a locking rear end, or has used a dually kit. I pull a trailer with fire wood often and get stuck a lot. Currently I have have been using 90 lbs of wheel weight and chains on my tires.
   / 2544 4X4 or locker rear end dually #2
Are you pulling up a hill? Muddy/slick terrain? Do you have rear ag tires now? I would start with the easiest solution and work up.
1st - rear ag (bar) tires.
2nd - dual wheel adapter, with ags.
chains and weights accordingly.
I would personally forgo the 4wd and locking rear end, just for the significant added expense. (and time)
Keep in mind this will adding a workload to your transmission, fortunately the 2500 series is fairly stout....but I don't know much wood you're pulling and how often!
If this is an ongoing task, I would personally look at a 3000 series with diff lock, or up to a 4x4 subcompact.....understanding the cost increases with each level. The 3000 diff lock makes a huge difference over the 2000 series (having owned both) and the price is ~reasonably~ more.
Good luck!
   / 2544 4X4 or locker rear end dually #3
You could buy a 4x4 compact utility tractor for the price of modding a 2544 into 4x4. There's no changeable/interchangeable parts on the transaxle. You could weld the spiders solid in the diff to achieve a locked rear, but then you'd defeat any decent mowing/maneuvering out of it. I don't think a 3K series rear would fit in a 2K machine. Some of the 3K series had lockable rears. Even though it's a cast iron case, the guts won't take that kind of pounding. They are awesome for the price, but after all, they are just a lawn/garden tractor.
Joel
Maybe the dually kit with super lugs is the way to go. This would give me more load weight and better traction.
Do you think a dually kit with super lug tires and the 90 lbs wheel weights is better thank the stock setup with wheel chains and the 90 lbs wheel weights?
   / 2544 4X4 or locker rear end dually #6
Heck yes. That would be the ultimate traction setup for a 2544 IMO. In dirt you'd probably pull a wheelie before those 4 tires would spin. Either that or the internal pressure relief valve on the hydrostat would lift and you'd loose motion until you let off.
Joel
I think the dually setup is the way to go as well. I am sure that is what I will do. The adapter is like $100 and then it is about $60 a tire.
   / 2544 4X4 or locker rear end dually #8
There was a discussion about "Super Lugs" versus "True Powers" on another forum the other day and everyone recommended the "True Powers" over the "Super Lugs". ANd I really do mean everyone. No one recommended the "Super Lugs".
AJ
   / 2544 4X4 or locker rear end dually #9
Be carefull , The Cub Cadet 2544 is a Garden tractor that is designed only to pull a 14 to 16 cu. ft. dump cart behind it.
You may want to look into a SC2400 Cub Cadet Yanmar Sub-Compact Tractor.
CubCadetYanmar anding Page
Kevin
2005 INTERNATIONAL 4200 24FT BOX TRUCK (A57880)
2005 INTERNATIONAL...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2018 CATERPILLAR 249D SKID STEER (A57880)
2018 CATERPILLAR...
2016 John Deere 5055E 4WD Utility Tractor (A55973)
2016 John Deere...
2005 FORD F-150 XL (A55745)
2005 FORD F-150 XL...
1991 International 4900 Box Truck (A55315)
1991 International...
