2544 4X4 or locker rear end dually
   / 2544 4X4 or locker rear end dually #1
evan4434
Iowa
Cub Cadet 3184
I have a 2544 and was wondering if anyone knows how to add 4X4, or add a locking rear end, or has used a dually kit. I pull a trailer with fire wood often and get stuck a lot. Currently I have have been using 90 lbs of wheel weight and chains on my tires.
   / 2544 4X4 or locker rear end dually #2
Are you pulling up a hill? Muddy/slick terrain? Do you have rear ag tires now? I would start with the easiest solution and work up.
1st - rear ag (bar) tires.
2nd - dual wheel adapter, with ags.
chains and weights accordingly.
I would personally forgo the 4wd and locking rear end, just for the significant added expense. (and time)
Keep in mind this will adding a workload to your transmission, fortunately the 2500 series is fairly stout....but I don't know much wood you're pulling and how often!
If this is an ongoing task, I would personally look at a 3000 series with diff lock, or up to a 4x4 subcompact.....understanding the cost increases with each level. The 3000 diff lock makes a huge difference over the 2000 series (having owned both) and the price is ~reasonably~ more.
Good luck!
   / 2544 4X4 or locker rear end dually #3
You could buy a 4x4 compact utility tractor for the price of modding a 2544 into 4x4. There's no changeable/interchangeable parts on the transaxle. You could weld the spiders solid in the diff to achieve a locked rear, but then you'd defeat any decent mowing/maneuvering out of it. I don't think a 3K series rear would fit in a 2K machine. Some of the 3K series had lockable rears. Even though it's a cast iron case, the guts won't take that kind of pounding. They are awesome for the price, but after all, they are just a lawn/garden tractor.
Joel
Maybe the dually kit with super lugs is the way to go. This would give me more load weight and better traction.
Do you think a dually kit with super lug tires and the 90 lbs wheel weights is better thank the stock setup with wheel chains and the 90 lbs wheel weights?
   / 2544 4X4 or locker rear end dually #6
Heck yes. That would be the ultimate traction setup for a 2544 IMO. In dirt you'd probably pull a wheelie before those 4 tires would spin. Either that or the internal pressure relief valve on the hydrostat would lift and you'd loose motion until you let off.
Joel
I think the dually setup is the way to go as well. I am sure that is what I will do. The adapter is like $100 and then it is about $60 a tire.
   / 2544 4X4 or locker rear end dually #8
There was a discussion about "Super Lugs" versus "True Powers" on another forum the other day and everyone recommended the "True Powers" over the "Super Lugs". ANd I really do mean everyone. No one recommended the "Super Lugs".
AJ
   / 2544 4X4 or locker rear end dually #9
Be carefull , The Cub Cadet 2544 is a Garden tractor that is designed only to pull a 14 to 16 cu. ft. dump cart behind it.
You may want to look into a SC2400 Cub Cadet Yanmar Sub-Compact Tractor.
CubCadetYanmar anding Page
Kevin
500BBL WHEELED...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Altec AT41M Boom (A55302)
2016 RAM 5500...
HOBBS 48FT FLOAT (A55745)
HOBBS 48FT FLOAT...
2018 John Deere 4066R (A53314)
2018 John Deere...
1992 CATERPILLAR 14G MOTORGRADER (A52709)
1992 CATERPILLAR...
2013 VOLVO VNL (A55745)
2013 VOLVO VNL...
