2320 Curtis Cab questions
/ 2320 Curtis Cab questions #1
kernal
Rochester NY
JD 2320
After a good amount of searching for posts, I guess I just need to ask.
If you have a Curtis Cab, or any other, on a 2320 can you give me some measurements?
Floor to top of Cab, or floorboard to top of cab.
Wondering if I can still fit under the garage door if I get a cab.
Thanks,
Scott
/ 2320 Curtis Cab questions #2
I am 99.9% sure that the cabs go just under the ROPS, so the overall height of the tractor does not change.
/ 2320 Curtis Cab questions #3
Thanks,
Scott
Scott, I just bought a Jd 2320 this summer and had the same questions. I now have a curtis soft sided cab on my tractor and love it. I have turf tires on mine and have a 9x7 garage door and my tractor is sitting in the garage as we speak. It all depends how your gargage door is framed (for the height opening) but I had lots of clearance. But you will have to fold down the ROPS bar. I did not want to mess around folding the bar up and down all the time. So I had a professional fabrication shop plasma cut the brackets off of the upper portion of the roll bar. I then cleaned up the brackets and reinstalled them on the tractor and put the upper portion of the roll bar back into the brackets so I could adjust the height of the roll bar. I adjusted it so that it stuck up 1" taller than my tractor cab. Therefore I had enough clearance to get into my gagage. I am a good welder, but I had the welding shop tig weld this all back together, they did a better job than John deere did! I then painted it with some Blitz Black I purchased at my local John Deere dealer. You wouldn't know it had ever been touched. I know that alot of people would say its taboo to shorten the rollbar, but what good is it if its always folded down. Tomorrow I will measure my total cab height if you want. If you would like I can take a few pictures too. But to answer your questions it does fit!!!!
I have R4's but if you could measure from the bottom of the ROPS to the top of the cab that would tell me if it will fit. We got a cutris cab for my mom's 2305 and it is very nice. I saw a 2320 with the hard doors today at the local college but he was going to fast for me to see how much shorter than the rops the cab was.
/ 2320 Curtis Cab questions #5
I shortened the top of my rops but I can get you a measurement from floorboard to top of cab and measurement from floor to the top of cab. Well get this for you tomorrow!
Dale,
If you could measure from the floorboard and / or the ROPS mounting plate on the fender. I found a Rolly Door that I can make work if the garage door itself is in the way.
I should just build another garage.....
/ 2320 Curtis Cab questions #7
Dale,
Scott, I just measured my Curtis Cab, I just measured from the top of the ROPS mounting plate to the top of the Curtis Cab, it is 42" , I also measured from the top edge of the floorboard to the top of the cab, this was 59 1/4". Hope this helps, if you need anything else just holler! Were you thinking of getting softsided door or hardsided? I have soft sided, I just couldn't spend the extra $1000.00 they wanted. I would rather put it on another attachment.
Thanks, need to measure tonite and see.
/ 2320 Curtis Cab questions #9
Not trying to hijack the thread, but Dale1995, do you have pics of your cab installed?
Ryan
/ 2320 Curtis Cab questions #10
No I don't tonight, but I can take some tomorrow if you would like:)
/ 2320 Curtis Cab questions #12
Are you looking for any special pictures or just want a general view of the outside with various angles. I will shoot anything you want to see!:D
/ 2320 Curtis Cab questions #13
Just a couple of inside and outside pictures. I'm thinking of buying one, but I want to see what it looks like installed on the machine.
Thanks
Ryan
/ 2320 Curtis Cab questions #14
Thanks
Ryan
I will take some tomorrow night when I come home from work, and will also show you a step that I fabricated for that tractor, and my heater modifications, and ROPS bar modifications I also made on this tractor. I can now put this tractor in my garage that has a 7' door, and I'm loving it:p
/ 2320 Curtis Cab questions #15
Well I just came in from outside and took some pictures of my Curtis cab, I also have some pictures of my step that I fabricated, which can be quickly removed if need be. Notice on these pictures that I have lowered my ROPS bar, so now I can get in and out of my garage without having to lower and raise it. I also have a magnetic mount quad strobe this is wired with an external waterproof connector. If I want to remove my strobe in the summer, and use the power supply for other items such as a rear tank sprayer etc... I am all set to go. Hope this helps.:D
/ 2320 Curtis Cab questions #16
Thanks for pics Dale! Looks like a real nice set-up. Couple of questions for ya:
1. Does it feel cramped inside the cab?
2. Does the cab amplify the engine noise inside the cab?
Thanks
Ryan
/ 2320 Curtis Cab questions #17
Thanks
Ryan
The cab does not feel cramped at all, I was very pleased by the overall room in the cab. I am 6' tall and 375 lbs and feel very comfortable in this cab. The engine noise is amplified a little bit but I can deal with it. In the summer I will remove the doors, etc.. so that will help. I usually wear ear protection most of the time, and listen to the radio with my headphones, I purchased at Lowes for around $50.00. I did add a hand grip so you have something to hang on to when you enter or leave the cab. I also removed one of the pieces of clear plastic in the front of the cab and replaced it with a piece of steel plate, that I ground to the same shape as the glass. I then bored a hole in the plate and mounted my snow deflecter cable in this hole. I also had to lower my heater 2" so that I would have enough clearance for my deflector cable. (The glass was useless because the heater was in its way) I am pretty fussy and love to fabricate items. I also machined a set of shafts so I can store my mower in the off season and roll it around the shop if its in my way. I was very impressed with this cab, I had a X485 before it also had a Curtis Cab, and it was a nice cab also. But this one is a little more polished. I couldn't see buying the hard side cab for $1000.00 more, I would rather put the money on some attachments. I am in the process of building a set of forks for this unit now:)
Dale,
Thanks for the pics. Nice setup.
/ 2320 Curtis Cab questions #20
Nice cab and nice step Dale. I won't let my wife see the step or she might start bugging you to take orders!:D
2020 INTERNATIONAL MV607 REEFER (A67714)
2020 INTERNATIONAL...
2017 Caterpillar DP70N1 15,500lb. Straight Mast Diesel Forklift (A64194)
2017 Caterpillar...
2021 Komatsu PC210L Hydraulic Excavator (A66734)
2021 Komatsu...
2016 Nissan Sentra Sedan (A66738)
2016 Nissan Sentra...
2018 Ford F-750 IMT 6025 7 Ton Crane Mechanics Truck (A64194)
2018 Ford F-750...
CATERPILLAR H95-S HYD HAMMER (A65056)
CATERPILLAR H95-S...
