Needle bearings on front drive
/ Needle bearings on front drive #1
choffman41
Sierra Foothills of California
Yanmar 2301
This is a 2301D which I hope is the same parts as a 276D. I have some play in the front wheels which I am pretty sure can be attributed to the needle bearings on the shaft that goes into the final gear case. Has anyone dealt with this, and what is the parts availability? Anything to watch out for in the removal? Any advice/experience greatly appreciated. Thanks.
Chuck
Well, got it apart and the needle bearings are the problem. Unfortunately, the shaft and gear that the bearings ride on are also bad. I'm thinking that these 4wd tractors that lived in the rice paddies probably got a lot of water in these final drive boxes and the mortality rate is probably high. Hope I can get the parts......
/ Needle bearings on front drive #3
If all else fails, try EFC. He has a machine shop and has made many gears etc for these. It might be an option to weld and turn down the shafts.
/ Needle bearings on front drive #4
The spindle, bearings & gears are available for your YM2301D.
Danny
Well, got the parts (thanks Danny), got them in, and darned if the wheel ain't straight and quit wobblin around.
UNUSED WOLVERINE HYD AUGER (A64281)
UNUSED WOLVERINE...
2020 GMC AT4 CREW CAB TRUCK (A62130)
2020 GMC AT4 CREW...
UNUSED INDUSTRIAS AMERICA 170-7' SCRAPE BLADE (A64280)
UNUSED INDUSTRIAS...
2017 Ford F-450 Liftmoore 5000W 2 Ton Crane Service Truck (A61573)
2017 Ford F-450...
2002 Bobcat 863 Compact Wheel Loader Skid Steer (A61572)
2002 Bobcat 863...
2015 CanAm Commander 800 BRP Side by Side (A62613)
2015 CanAm...
