Jinma 284LE won't turn over
/ Jinma 284LE won't turn over
I tested the starter per DiamondPilot's post. The starter did run spin with that hookup. In a previous post I put a drawing of how I hooked it up. The large post at the bottom of the picture is connected to the copper strap that attaches to the starter. The top is where the positive battery cable is hooked up. This is the opposite post where I put the positive cable on my connection so do I have the solenoid posts hooked up wrong?
Thanks again for all the help.
Mark H
/ Jinma 284LE won't turn over #43
Mark,
Here is what my wiring looks like at the Starter/Solenoid.
RonJ
/ Jinma 284LE won't turn over #44
Ok, I went out and looked at my old starter/solenoid sitting on the shelf. The small post for the red wire of the solenoid is farthest away from the starter just like the picture above.
Then there is only one possible way to hook up the copper strap from the starter motor to the solenoid. The remaining big lug gets the small white wire and the large wire coming from the battery.
Its possible you have the solenoid turned 180 deg which may have some affect on how it operates.
If you do change the solenoid 180 deg and still can not get it to work you need to just order a new solenoid since you starter motor seem to be fine after you checked it as I suggested.
If you have any questions and its easier to talk on the phone you can call. I will PM you with my phone number.
Chris
/ Jinma 284LE won't turn over #45
Mark,
One other thought occurs to me.
When you had the Starter and Solenoid removed, did you do any disassembly of the Solenoid?
RonJ
My solenoid is hooked up as shown in the picture. I was confused because for the test the positive hooked up to the post with the copper strap. I did have the solenoid apart and the contacts weren't very clean so I cleaned them. Now that I know the starter is OK I am going to take it apart per Greg G's suggestin and check the wiring in the solenoid.
Mark H
/ Jinma 284LE won't turn over #47
Mark,
When you disassembled and reassembled the Solenoid, did you put it back together with the single wire and double wires in the correct positions?
RonJ
erj,
The wires are connected correctly because I made notes of what went where when I took it apart.
Mark H
/ Jinma 284LE won't turn over #49
Mark,
Thank you for the response. I thought that perhaps this might be the problem that you are having now with trying to 'short' the starter.
RonJ
The wiring on the starter looked OK. When I put it back on the tractor I had a good spark but didn't try and start it because it was late. The next day with the key it sounded like something grinding but not the starter. Then I had nothing on the solenoid. I am going to order a new solenoid. Will respond when I get it in and installed. Appreciate all the input.
Mark H
Put on a new solenoid last night and at first it turned over but very slowly with a noise that almost sounded like grinding. Then all I got was a click when I turned the key. I am getting plenty of spark at the solenoid now so the other solenoid was bad. When I jump it with a screw driver I also only get a spark. So now is it the starter that's bad or do I need to check elsewhere.
Mark H
/ Jinma 284LE won't turn over #52
Are you getting 12v to the small terminal of the Solenoid when the key is in the Start position?
RonJ
/ Jinma 284LE won't turn over #53
Maybe, but first you need to start over with a freshly charged and load-tested batter. And some good battery connections - both cables, both ends. Sometimes the lugs get enough corrosion between the copper strands and the steel lugs - to the point that insufficient current from an otherwise good battery gets to the starter.
//greg//
Battery checked out OK and all connections were cleaned when I took it apart. If I am using a screwdriver to jump it then don't I have 12 volts which eliminates the switch. This was the voltage when I checked it.
Mark H
/ Jinma 284LE won't turn over #55
Mark H
I notice from your profile that this is a 2003 tractor. Is it the original battery?
I'm not sure what your mean 'battery checked out OK'. Merely testing voltage at the terminals doesn't mean anything - a specific gravity test or load testing is what you need. The ability to deliver current under heavy loads (starting a diesel qualifies as a very heavy load) is critical.
Take the battery in to NAPA or some such and have it tested. 5 years is pretty good for one of these batteries.
The battery is less than a year old.
Mark H
/ Jinma 284LE won't turn over #57
When you say spark what are you meaning? This is confusing to me, maybe its my Indiana public SKOOL'N. Does the tractor start when you use the key? If not does it start when you use the screwdriver?
Try this. Park your truck near the tractors starter side. Hook jumper cables up to the stater, not the battery. Make sure you get a good ground on the stater for the negative side. If it starts no problem it has to be your wiring, battery, or ground. I actually made up a ground cable that goes from the battery to the base of the starter under one of the stater bolts.
I had a lug fall out of one of the wonderful GM crap side lug batteries when it was only 1 year old. Up to that point I had problems starting and could not trace it.
Chris
It won't start with the key or the screwdriver. I get a click with the key and a spark with the screwdriver. I will try jumping it that way and see what happens. Is the hookup the same as you mentioned before except with the starter on the tractor? If it doesn't start then what should I check next or does that definitely mean it's the starter. I don't have internet at home because all we can get is dialup unless we go with satellite internet. If I can get more to check if this doesn't work it would be helpful.
Mark H
/ Jinma 284LE won't turn over #59
Mark... all the trying won't help if the starter is bad..remove it and bring it to a electical motor repair shop and have them test it...or better yet just tell them to overhaul it. If no repair shop in your area..you may need to replace it. You've been messing with this long enough...It's time to address the seven hundred pound gorilla in the room.(the starter)
You've replaced the solenoid...so..You either have poor electrical connections,(you clean and checked them) .. not enough amps (you tried jumping it)...or a bad starter...of course this could be mechanical...but lets hope not (rotating the engine by hand with the glow plugs out could confirm that)
Good luck..
2020 DRAGON ESP...
1986 MURRAY WEST COAST STYLE RGN (A60736)
1986 MURRAY WEST...
2005 Isuzu NQR 4 door box truck with folding gate (A61307)
2005 Isuzu NQR 4...
2021 FORD RANGER (A60736)
2021 FORD RANGER...
Strickland MFG 24" Excavator Bucket (A60463)
Strickland MFG 24"...
WINCH CABLE DRUM (A58214)
WINCH CABLE DRUM...
