Tiller Roto Tiller Features
/ Roto Tiller Features #1
whstein
Vancouver Island
Kubota B26 TLB
The next implement purchase is a rototiller. My dealer sells Land Pride, Maschio and Sitrex. My questions are about forward rotation vs. counter rotation and shear pin vs. slip clutch models. My dealer favours forward rotation because of cost and less soil compaction and says they outsell counter rotation models by 20:1. He also favours shear pin models and says the slip clutch types require much more maintenance i.e. slip mechanism must be re-torqued every time you hit something that causes slippage and if left outside in the rain for an extended period of time while shear pins can be replaced quickly in the field. He sells all types so it is not a matter of trying to get rid of in-stock inventory. What do you guys think? TIA. Wally Stein
/ Roto Tiller Features #2
I have a reverse rotation tiller. Love it. But it does not like rocks over 8". Will stop tines and cause slip clutch to work. I would never consider a tiller without a slip clutch. I do not store tiller outside. So rust is not a problem. I would think the reason that forward tiller out sell reverse tillers is cost.
Biggest reason for a reverse tiller is one pass tilling to desired depth. I do not understand the less soil compaction statement. My tiller does not require me driving over already tilled soil to do next row.
/ Roto Tiller Features #3
I have the 5 foot Land Pride reverse till and it does great. Big rocks and logs will jam it up easier than a straight till, but they are easy enough to dislodge, and it does a much better job tilling than a straight till. I always use a slip clutch on all of my stuff. Pins are too much of a bother. That Land Pride comes with a newer kind of clutch that I am not all that familiar with. It does not have any adjustment on it. If you get one, make sure to read the manual and do the run in procedure before you start working. It will not work if you don't.
/ Roto Tiller Features #4
I have a forward rotation KK II.
It will usually ride up and over roots and rocks that are too big to "process", I regard this as a feature.
I have a slip clutch on it, which it came with, I havn't considered replacing that with shear pins - maybe the forward rotation's ride up and over feature has kept me from slip clutch problems.
I generally prefer problem avoidance to problem solution.
I till at a ground speed lower than the tiller's tip speed, i.e. the tiller "pushes" the tractor and throws soil back.
My guess is that reverse rotation blends the soil a bit more, might fluff it too much in some cases and would be problematic if/when hooked under roots or some shapes of flat rocks - just guessing.
/ Roto Tiller Features #5
I am sure if you ever happen to break a slip clutch you will realize why shear pins could be more popular. I had to purchase a replacement hub for the slip clutch on my 38" Simplicity tiller, it was $100. If I had been unable to find that part and had to purchase the whole thing, it would have been $280. Granted, a slip clutch hub breaking should not be a common occurance, but I would rather change ten shear pins as opposed to waiting a week for a replacement part and having to tear the gear box off the tiller.
As far as the rotation goes, mine is forward rotating and does a pretty nice job. The only counter rotating tiller I had was a walk behind model. If you hit a rock with that puppy it would jolt you pretty good.
Mark
/ Roto Tiller Features #6
can't you just go in reverse to 'counter-till'? i have the KKII 6' and wouldn't spend any more as this has been flawless so far (knock on wood!)
since you won't need anytime soon, wait until after Christmas and you'll get another $100 or so off at TSC i'd bet. the toliet economy will be great for non-business owners with cash ;)
/ Roto Tiller Features #7
No you can't just go in reverse. They are not designed to be pushed. The skid plates/depth adjustment only work going forward. There is no way for the dirt to get out of the way once it has been tilled.
I have a forward rotating 6' Befco with slip clutch. It does a fine job and I don't find a slip clutch to be that much of a challange to maintain.
/ Roto Tiller Features #8
Do not the forward rotating tillers require more Horse power?
I have a slip clutch on my little tiller. Adjustments are not a problem and it does sit outside.
A person could always remove the slip clutch and take it inside. I've done that also.:D
/ Roto Tiller Features #9
So do I.
I have the 5 foot Land Pride reverse till and it does great. .
I back the tiller up into dirt piles to get fine dirt for lawn and landscapeing projects.
I don't think a reverse rotation tiller would work very well for backing into a pile of dirt.
Forward or reverse / tilling is a dirty dusty job.
/ Roto Tiller Features #10
Egon
I believe just the opposite is true. The reverse rotating ones have a lot more soil to move and don't have the tractor forward motion to help.
Andy
/ Roto Tiller Features #11
I've got a Sitrex RH-4125 for my little JD 2305 and it does a great job, if there's a lot of material to be tilled in it may take a second pass, but I don't find that to be an issue. it has a slip clutch, but I haven't hit anything to make it come into play yet.
/ Roto Tiller Features #12
I have a Woods GTR72 reverse rotation tiller. It works extremely well. My soil has very few, if any, rocks so that is not an issue for me. It has a slip clutch and is kept inside. I went with the reverse rotation based on personal research and various "test" reports. I think the concept is what keeps most people from buying one since the forward rotation style has been around for so long. I have found it to do a MUCH better, one pass job then a standard tiller.
/ Roto Tiller Features #13
[I believe just the opposite is true. The reverse rotating ones have a lot more soil to move and don't have the tractor forward motion to help./QUOTE]
Boys oh boys did I put both feet in this time. :D:D:D
Yes, I did get the rotation wrong.:eek::eek:
/ Roto Tiller Features #14
Whoa... 8" rocks! :eek: (I won't be dropping my tiller off at your place anytime soon..)
I've got a John Deere 660 tiller. Forward rotation and slip clutch. It's stored outside on a pallet and double tarped. Never a problem with the slip clutch. I think the clutch is a better safety feature and helps to avoid more costly damages whenever you encounter situations that are unforeseen; like 12' of buried 3/8" chain! (Maybe that's worse than an 8" rock..)
Interesting info regarding the advantages of a reverse tiller. My next tiller could very well be a reverse machine.
AKfish
/ Roto Tiller Features #15
I think what your saying about the one pass is true if your talking about virgin sod/pasture etc. I used a chisle plow on my field in the fall and in the spring when I tilled it one pass made it super fluffy.
/ Roto Tiller Features #16
I've done numerous "one pass" runs on awful, hard, dry soil and it still gets much "fluffier" then a forward rotation tiller does. At least this is my experience....your experience may differ ;).....no animals were hurt during this test ;).....you pay only shipping and handling :D .
/ Roto Tiller Features #17
AKfish
An 8" rock is nothing to find under the surface in my field. I have hit BIG rocks just under the surface that make the slip clutch squeel and the tiller jump in the air. Here is a picture of one of them after I dug it up.
/ Roto Tiller Features #18
I vote for the slip clutch, too. I have a CCM tiller. They include the clutch in the price of all their tillers. I don't think they would do that if it wasn't really needed.
It's the only implement I own that has a clutch.
/ Roto Tiller Features #19
Yikes...!! That would definitely leave a mark! :D
/ Roto Tiller Features #20
Yeah, I have those rocks on the "Packer" side of the river. If I only had to worry about 8" rocks, I wouldn't worry at all.
7 years with the KK 60" tiller and no major issues.
Reverse till may be better, but it costs 3x. If you have rock and root free soil, a slip clutch is not needed.
jb
UNUSED JCT 4 PRONG BALE SPEAR (A62131)
UNUSED JCT 4 PRONG...
2013 Ram 1500 Crew Cab Pickup Truck (A61568)
2013 Ram 1500 Crew...
2026 Steel Pines Cargo 7x16 Enclosed Trailer, VIN# 7FWBE1622T1037829 (A61166)
2026 Steel Pines...
2012 Mack CHU613 T/A Wet Kit Day Cab Truck Tractor (A61568)
2012 Mack CHU613...
2016 Chevrolet Express 2500 Cargo Van (A61568)
2016 Chevrolet...
UNUSED JCT HYD TRENCHER (A62131)
UNUSED JCT HYD...
