Miller 225g welder replacement engine
/ Miller 225g welder replacement engine #1
jayste
"Sold the 1/4 of a 1/4 but still tractorin' "
2004 Kubota M4800 SU
Anyone out there ever replace the Onan engine on a 225g with another maker? These Onan's may be good engines but they are pricey to fix. I'm needing a crank, piston, rod, etc. I'd like to retrofit with another maker.
/ Miller 225g welder replacement engine #2
I'm guessing that you have a Bobcat...I've got a Trailblazer with the Onan 20HP...Yeah, parts are getting harder to find and more expensive...Miller has now gone to Kohler V-Twins...you might ask the local Miller dealer if a "swap" is possible...if not, see what they can do with your's....how many hours do you have on your Onan??? BobG in VA
Yes, it is a Miller Bobcat. I'm not sure of the hours. It's been used pretty hard by an oilfield company and not taken very good care of. I think it's worth salvaging if I can get the engine going for the right money. I'm considering going with another horizontal shaft engine if I can get the adapter to work. This one is a 16hp onan. I'm guessing this unit is a 90's model.
/ Miller 225g welder replacement engine #4
I would look at the later model Bobcats, and go with the Kohler.
I am guessing, pure speculation, but guessing that you could use some of the controls from a later model on yours if they could not be adapted or fabricated from what you have.
I would look at a current one with a Kohler and get the model and that other # they use which escapes me at the moment, and that should get you base height and shaft diameter and length etc.
You are probably looking around the $1500 neighborhood for a new motor.
Small Engine Warehouse - Repower Outdoor Power Equipment is great too work with, but I have also had good luck working with my local tractor / mower dealer.
/ Miller 225g welder replacement engine #5
I've rebuilt 4-5 of the Onan's on Miller Welders. If yours has an oil filter it is probably an Onan Performer. If no filter it is a CCK.
IIRC the crank can be turned .040 under but I might be thinking about the cyl bore.
You are not going to get a replacement engine cheaper than repairing yours if you are looking at new. And then you will need the engine adapter.
If you look around there are a lot of RV generators from scrapped RV's. I just bought one on craigslist for $160. that has the control PC board missing. These gens run at 1800 RPM so the engines last forever.
The crank is also tapered so a regular engine won't work, it has to be a generator version. The gen has no bearing on the engine end.
Stimw, are you saying that I could possibly use a generator engine for this welder? How about parts in your area? I like the idea of being able to find and engine online and using it. I thought of adapting another brand of engine to it but was unsure of the ability of making the adapter plate work.
/ Miller 225g welder replacement engine #7
The Onan engines should be interchangeable from welder to generator. You would have to change sheet metal and some other parts but they will be interchangeable. They both use a tapered output shaft. Most direct drive generators use a tapered shaft.
The Onans will run almost forever if you keep oil in them and an air cleaner on them.
Do a search on ebay or craigslist for Onan and see what's available in your area.
/ Miller 225g welder replacement engine #8
If the RV's use 1800 rpm engines, they probably won't work in place of the 3600 rpm Onan. I don't know for sure the Onan is 3600, but they one I had purchased in early 90's was one fast running engine when it came off idle. Need to find a motor that runs the same under load, or your going to have to build a step up system for the generator.
If I thought an 1800 rpm engine would work, I would suggest that Kubota diesel I have out back...
David from jax
/ Miller 225g welder replacement engine #9
The difference between a 1800 and 3600 RPM Onan engine? The governor! All you need to do is change the external governor linkage and the idle control solonoid.
/ Miller 225g welder replacement engine #10
The primary difference is internal. A fixed speed 1800 RPM Onan engine has a 10 ball governor, 10 ball bearings in the cam gear.
A 3600/3750 RPM Onan has a 5 ball governor. The external governor spring is also different for the two engines.
As far as using an Onan genset engine on a welder it is possible if the cranks are the same. This is not always the case on Miller welders since they changed the design of the way the crank mates up to the rotor several times.
Early miller welders used a fat tapered shaft identical to the early Onan gensets. They then changed to a smaller tapered shaft and in the late 90's to a threaded straight shaft.
Other parts to consider are the oil pan/base and oil pump pickup tube. You may or may not have to drill and tap the PTO end of the block to match up the mounting points of the welder adapter/stator housing.
Hey, thanks for all the valuable information. I'm in the stage of figuring out which direction I need to go. I'm thinking worst case is rebuilding. Adapting another engine may have it's hurdles but cost of rebuilding might not be feasible. If I could find a replacement engine from a generator that would be great. Especially if it was only 160.00!!
/ Miller 225g welder replacement engine #12
Another issue with trying to use a genset is the starter. On early models battery voltage is applied to windings in the genset to make it "motor" or spin and start the engine.
On later models the starter is mounted to the adapter that connects the generator head to the engine. The ring gear is located inside the adapter. Onan engines used on tractors and welders have the starter mounted to the engine block in several locations and engage the ring gear on the flywheel.
The BGD 4.5KW series gensets use the same internal parts as a P218G. Rods, pistons, valves, cam etc. Your Bobcat should have a P216G. Swapping the internal parts from a BGD to your block would give you an 18HP engine.
My experience over the last 20 years is mainly with the Onan engines used on tractors and welders. BG, BF, B43, B48, P216, P218, P220, P224 etc.
I just picked up a BGD genny for parts and will be stripping it down soon. I'll let you know if in fact the PTO end of the crank is the same type of taper as the miller bobcat.
/ Miller 225g welder replacement engine #13
I've got a '99 Trailblazer with the P220 Onan on it. I picked it up "used" about 3 years ago with 11 hours on it...I was told by the Miller dealership that sold that unit originally that those Onan engines are known to last well over 4000 hrs with decent maintenance...Can you confirm that??/PS: I still only have about 60 hours on it....Thanks for any info. BobG in VA
/ Miller 225g welder replacement engine #14
4000 hours is about average with normal maintenance before an overhaul would be called for on the Onan Performer series engines.
Definition of an overhaul on Onan engines with no issues other than burning oil.
Valve job and replace rings. Polish crank and put it back together. As long as the pistons, bore, rods & mains are within specs, this is true more often than not, that's it.
Unlike some other brands the Onan is not a disposable engine. It's designed to be rebuilt many times, and even though production ended in 2004 all the parts required to keep them going are still being produced and are made right here in the U.S.A.
Onanparts.com, sounds great. Keep me posted on the parts you're talking about. I'd like to tap into your knowledge on this internal part swap to obtain the 18hp rating if the costs are feasible.
/ Miller 225g welder replacement engine #16
Thanks for the info....looks like I'm gonna have to start looking for someone to pass this unit on to after I'm gone...BobG in VA
/ Miller 225g welder replacement engine #17
Update:
I stripped the BGD down today and discovered a few things. The PTO taper is "close" but not the same as the crank used on the Miller welders. The genny tapered crank is a little longer and smaller in diameter. So no go in that department.
The block is identical to those used on the welders. The mounts are there to hang a starter for use with the normal flywheel ring gear setup. The timing cover does not have the stator mounts drilled and tapped but the ignition module mounting location is tapped.
Mounting points for the welder adapter at the block are the same and will bolt right up for a miller.
So bottom line is to use a BGD genny as a donor you would need to use the following parts off the welder engine.
Starter, oil base, timing cover, exhaust/muffler, intake and carb, crank, rods, flywheel, ignition components, shrouding.
If your crank is ok or can be turned then a BGD donor would work fine if your block is junk or shot.
Onanparts, see email correspondence from me through your website. Thanks for the information and I hope between your parts and whats left of my engine we can get this thing going without too much hassle.
Pallet of Forks (A61567)
Pallet of Forks...
UNUSED KJ 14' EXPANDABLE SITE FENCE (A62131)
UNUSED KJ 14'...
FORD 3600 TRACTOR (A62130)
FORD 3600 TRACTOR...
Snap-On Southern Thunder Edition 24-drawer tool box (A63118)
Snap-On Southern...
John Deere 4230 Tractor w/ Loader Bucket and Hay Spear (A64047)
John Deere 4230...
UNUSED JCT 4 PRONG BALE SPEAR (A62131)
UNUSED JCT 4 PRONG...
