closed loop...really?
/ closed loop...really? #11
... When I had a 425, I once cranked it in cold weather to let it warm up. I was amazed at how fast the oil reservoir got warm, even though the tractor was not moving. This suggested to me that a lot of oil was being moved and was under pressure to some degree. I guess the gear pumps are always working and moving oil around too....
The the main PTO pump and the smaller pump that provides steering, lift and power to the quick attach (aux PTO) are always on. That is what warms up the reservoir. In the winter, I fire up the PT, set it at about half throttle and go shovel the narrow walks and steps. By the time I get back, usually about 10 minutes, I can feel the heat on the side of the tank. Then it is good to go for plowing with quick steering and FEL response. Once I left it that way for about a half an hour, as I got sidetracked, and came back to find the cooler fan running. :rolleyes:
/ closed loop...really? #12
The charge pump is a small pump, normally pumping about 10 percent of the gpm's of the VSP pump. The main purpose of the charge pump is to keep fluid at some pressure, about 320 psi if I remember correctly supplied to the VSP. because some fluid is lost through hydraulic wheel motors, and is also used to help cool the case side of the VSP pump. I believe the motor case lines come back to the pump case drain, or meet somewhere and then goes to the cooler. The charge pump doesn't need to be large, because it is only a makeup pump, making up what is sent out of the wheel motors case drains and pump case drain. Another thought here is that not all wheel motors have case drains, so maybe the charge pumps on that system might be smaller. My main thought here is that it is not pumping a lot of fluid all the time, like when sitting still, and therefore it is pumping less, and filtering less, just enough to keep the charge pump side pressurized.
In my system, the PTO and the steering pumps are always running. They will build up heat just sitting there with the engine running. If relief valves come on a lot they generate heat. Attachment motors working hard, generate heat.
Someone mentioned about putting a high pressure filter in the attachment return line. I suggest a better place would be in the return outlet on the PTO block, and that would catch any debris from any attachment. There should be a gage in the line before the filter to give you an indication when the high pressure filter might be getting clogged. If you do this , I would note down the normal operating psi of the attachment. If it starts to run higher, it might be time to install a new one. Yes, you could put one on each attachment, but it will get expensive.
If the 2 gpm charge pump was pumping fluid at full capacity, it could filter 20 gal of hydraulic fluid in 10 min. This can not happen in our system, because we are not filtering fluid in a linear fashion. Contaminants are not injected in a linear fashion, but random, like when plugging in the quick disconnects, or opening the tank cap. Otherwise, we don't filter the entire tank of fluid and then we quit, what we are doing is to keep mixing filtered fluid in with unfiltered, and I don't know the math to compute the total filtering sequence since the oil is circulating in a continuous loop. A visual concept would be to put some kind of dye in the hyd fluid, and run it through a filter to remove the dye, and see how long it takes to completely filter the dye from the 20 gal.
T0 clear up things. To protect the tank and keep it clean, filter the return line from that circuit, and each circuit. . To protect the motor, with a high pressure filter, put it before the input to the motor.
/ closed loop...really? #13
The 1850 I have (I assume 1845 and I think the 1445) has a second filter. The primary is the big one from the tank to the Wheel Motor Inflow pump. This is the biggest mystery to me. Change this filter every 50 hours but it filters very little, right? There is no return back to the tank on this system. It is only providing filtered oil at a limited rate to the wheel motors, right? The thing is that if this is to a closed loop system, why such big supply hose? 1" from the tank to a 3/4" to the wheel motors. But like I said I do not see any return line, although there is a mystery hose hanging off the back of the pump so maybe that is it.
The other is on the lift / tilt / brake section (Known as the Accumulator / charging valve, just after the PTO actuator. (They call it the RPS Valve). It is high pressure filter, A Schroeder N-25 but I can't find any specs. I assume 10 micron at 30GPM.... This is after the pumps, but before the actuator. This filter I was told to change just once a year......
This is the one that I would think is taking on a lot of crud.
So anyone want to lay on some insight on this? Truly a mystery to me. The whole filtering methodology of PT seems pretty hap hazard.
Saw this bad boy, If I had $300 and the time I might consider it, but where to put it would be the question.
Flow Meter With Thermometer | Hydraulic Accessories | Northern Tool + Equipment
/ closed loop...really? #14
How does the variable volume pump that drives the wheel motors work?
I know about the swash plate.
When pushed to forward, oil flows into the wheel circuit to turn the wheel motors forward.
When pushed to reverse, oil flows into the wheel circuit to turn the wheels in reverse.
But what happens when the swash plate is in neutral? Is the pump sucking oil from the reservoir and sending it back to the tank or is it just circulating oil inside itself, building up heat?
/ closed loop...really? #15
Attached is the Army Field Manual for hydraulics. A good source for knowledge.
It is in ZIP format because it was a little over one meg in size PDF.
/ closed loop...really? #16
David, I am commenting on this subject from the viewpoint of my 1445 and the Eaton VSP pump I believe that the oil in the neutral position is recirculated back to the input of the VSP. There are some relief valves in the pump that help keep the input of the VSP primed, and keep fluid on both sides of the swash plate. These same relief valves are used to allow the PT to be moved with the engine off. So what happens is that once the relief valve are relieved, by turning the half nut, so as you roll the wheel motors, the fluid in the circuit is recirculated through the closed loop system pushing the fluid back the VSP pump and around again back to the motors. This process will build up heat, and should not be done for a long period. The oil from the charge pump does not go back to tank on my system. The only oil that goes to the cooling system is a mix of motor case drain and VSP case drain.
Here is some good reading and pictures.
http://www.tractorbynet.com/forums/power-trac/114509-hydrostatic-drive-pump.html
/ closed loop...really? #17
That info is here.
/ closed loop...really? #18
My system says that the zipped file is invalid or corrupt.
/ closed loop...really? #20
That info is here.
After reading the data from the Danfoss pump, I notice two differences, Your pump has two VSP pumps each driving two motors, if I read this right. The other difference is that the excess from the charge pump goes into the case and then to the reservoir, I am assuming through the cooler on your system.
Maybe the differences in your systems, and mine and others, is related to the differences about which wheel motors are powered such as opposite corners, both same side, or all 4 equally.
2023 Kubota SVL75-3 (A60462)
2023 Kubota...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
40' CONTAINER (A52706)
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
2025 AGT Industrial MX-CRT23 (A60463)
2025 AGT...
MINI KID DIRT BIKE (A56859)
MINI KID DIRT BIKE...
